E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
10-26-2004, 11:43 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 46
Member: 85389 Status: Offline Thanks Meter: 0 | a60 & c60 dead after flash!! what to do thanks |
10-26-2004, 20:28 | #4 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Purwokerto, ID Age: 42
Member: 39539 Status: Offline Thanks Meter: 65 | use boot repair 1st 1.write boot repair 2.write full flash 3.unlock 4.repair contras if bad download file here www.sintenremen.net |
10-26-2004, 20:44 | #5 (permalink) |
Freak Poster Join Date: Nov 2003 Location: The upper limit Age: 40
Member: 44552 Status: Offline Thanks Meter: 3 | Hello friend. You need to flash FUBU file, because NOTHING else works. This is step 1. After that, write good eeprom file in phone. Check eeprom imei and original imei to be the same. If phone only "bzzz" on power on , unlock it using freia and write IMEI. Get FUBU flash files from here : http://eh.student.utwente.nl/~landy/ Username mobile Password elibom GOOD LUCK!!! NeXuSGTS[£] |
11-26-2004, 21:38 | #6 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
what is the steps? | |
11-26-2004, 22:48 | #7 (permalink) |
Freak Poster Join Date: Oct 2002 Location: Bulgaria Age: 49
Member: 16994 Status: Offline Thanks Meter: 157 | @ captainsky Probaly you use old freia. For these phones better to use Freai 9. Write fubu. Unlock use 'Direct unlock,no map saved','Use original IMEI' and go. |
11-27-2004, 08:47 | #8 (permalink) |
Member: 39539 Status: Offline Thanks Meter: 65 | boot file can download at www.sintenremen.net make test point use freia 10 select phone model c60 boot or use custom address 0x800000 |
11-27-2004, 19:57 | #11 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | what is the right address of flashing full flash, and what is the right address of eeprom file also? and when i try to read and patch bootcore with friea 15 , then i get this messege read and patch bootcore FREIA - Engine build 15, Frontend build 11 Thanks goes out for the following: Maxim, Rolis, Sergey, PapaJoe, Lead, TheWizard, Jozso (for hardware and cable support and of course beta testing), Nico, Pinker, Tom, Crew and all the others who supports ... COMM_LoadBoots : selected phone family is 13 TTY_OpenCOMPort : opening Prodigy COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_LoadBoots : internal loader version is 01.02 COMM_LoadBoots : EEPROM IMEI is 35197500240726 COMM_LoadBoots : original IMEI is 35197500240726 (locked) COMM_LoadBoots : found SIEMENS A60 lgX v0 (1) COMM_LoadBoots : flash ids are 0001220C [00000000] - C6F0 COMM_LoadBoots : phone ids are 0F51E64F [00000000] COMM_PatchBootcore : using BOOTCORE.FLS COMM_PatchBootcore : invalid bootcore what to do? Last edited by gsmsikar; 11-27-2004 at 20:09. |
11-28-2004, 16:11 | #13 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | Take Full Flash For C60 With 14 Mb Flash Size And Start Flash At Adress X200000!! And Then Unlock Using Original Imei!!! |
11-30-2004, 07:04 | #15 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | How ???? I took 14 MB flash and wrote it : Start address : 0x200000 Start offset : 0 Count : 14680064 and then UNLOCK using original IMEI and still buzzzzzzzzzzzzz !!! THX ! |
F480 Touch Screen & Buttons Dead After Flashing HELP!! | gadgetguyuk2005 | Z3X-Team Products | 1 | 03-13-2010 08:20 |
[B][/B]7260 & 3220 Dead After Flashing | remylebeau | Nokia Hardware & Hardware Repair | 5 | 06-25-2006 14:19 |
639 & 855 dead after flash | abasgsm | Multi-Box | 1 | 06-21-2006 13:59 |
big problem with P908 & P900 dead after flash with cruiser | nio | Sony Ericsson | 2 | 09-21-2005 22:33 |
C60 Dead After Flashing BuT With FULL Flash Phone OFF | Mierdita | E-Gold Based Phones | 6 | 12-01-2004 16:49 |
