Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 06-22-2009, 09:10   #1 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
A62 phone disabled phone code
when insert sim,it says hone disabled phone code.
how to remove this code.
I have no box for siemens.
need solution using joker or freia
Old 06-22-2009, 13:17   #2 (permalink)
Member: 369802
Thanks Meter: 82
u need to do testpoint on that model with joker, but u must have a data cable
Old 06-22-2009, 13:29   #3 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
u dont need tp, just choose bootcore bug on joker, go to skey and click recal all keys, phone will be unlocked.
Old 06-22-2009, 17:05   #4 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
Start...
Boots Already loaded!
SIEMENS A62 lg98 Sw07
Soft FlashID: 0001/220C
FlashID: 0001/227E-220C-2201
Flash Size: 8Mb, WriteBuffer: 32 bytes
Region(1): Blocks 128, Size 64Kb
Start EEPROM segments at addres 0xFC0000
FSN: AB9CC9EB -> PhoneID: EBC99CAB
OTP IMEI: 358000001138047
HASH: 0CC25AB08D5DEE70C8E0FDD85F622F13
Use OTP IMEI: 358000001138047
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
BCORE HASH is equivalent - not change.
Read EEPROM addr: 0xFC0000 size: 0x030000...
EEPROM backup in ".\Backup\A62lg98Sw07_EEPROM_090622220343.bin" file.
Write EEPROM addr: 0xFC0000 size: 0x030000...
CRC error in transfer buffer or bad RAM! (Block at 0xFC0000).
what kind of error this is boss???
Old 06-22-2009, 18:38   #5 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
Start...
USE SKEY: 12345678
...try with this methode:
-select Type; A60/A62, comport 1 or 2, COM Speed: 115200 and bootcore Typ: BCoreBug
- go to SKey menu and click to "Calc SKey. After calculation click on "Send Skey". If is OK, your phone enter in Factory mode (verify in Service Menu-> Service Mode). If give error, you need to cut one track from the seccond layer (click on TP tab to see picture) and repeat this steps in the "Normal" Boot Typ.
dagos
Old 06-23-2009, 08:49   #6 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
dagos
****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only opened. ******
****** Tuesday, June 23, 2009, at 12:35:05 ******
Start...
Loading BootsModel(A60)...
Sending StartBoot Ok.
Error: MainBoot answer code 0xÿÿÿÿ!
Start...
Cancel.
Start...
Sending MainBoot Ok.
Com1 115200 BAUD: Ok.
Boot terminated.
Test and Calc Skey...
BOOTKEY: F92682B09AA68262074AC47CBF4EBCC3
SKEY: 12345678
Start...
Error: MainBoot answer code 0xÿÿPV!
Start...
Boots terminated!
Loading ServiceBoot...
Error: ServiceBoot answer code 0xAD!
Start...
Start...
Error: MainBoot answer code 0xÿPVO!
Start...
Boots terminated!
Start...
Boots terminated!
Start...
Boots terminated!
Error: MainBoot answer code 0xÿÿÿP!
Start...
Error: Load StartBoot answer code 0xFF!
Start...
Boot terminated.
SKEY: 12345678
Start...
Start...
Boots terminated!
USE SKEY: 12345678
ReadFlash error CRC (0x3F75<>0x5B69)!
Start...
USE SKEY: 12345678
EEPROM backup in ".\Backup\A62lg98Sw07_EEPROM_090623121110.bin" file.
Start...
SetSpeedBaud: Com1 already use 115200 BAUD!
Boot terminated.
SKEY: 12345678
****** Joker Siemens EGOLD Phone Version 0.3.5.2 Test Only closed. ******
****** Tuesday, June 23, 2009, at 12:14:29 ******
Old 06-23-2009, 08:50   #7 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
****** Tuesday, June 23, 2009, at 12:29:17 ******
Start...
Start...
Start...
Boot terminated.
SKEY: 12345678
****** Tuesday, June 23, 2009, at 12:45:20 ******
unable to solve my proble after using test point.
Old 06-24-2009, 03:17   #8 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
Start...
Start...
Start...
Boot terminated.
SKEY: 12345678
...sems to be damaged bootcore area. After calculation, send this key to phone? If give to you error, you need to fullflash your phone using the good fullflash file and flash it including bootcore area (and activate option ReCalc keys).
dagos
Old 06-24-2009, 12:32   #9 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
dagos
thnx boss for replying.
but I have no flash file
and dont know how to flash it.
please provide me.(File+operating method)
Old 06-24-2009, 16:31   #10 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
OK,
download the following files:
A62 firmware 06 language pack 98 (multi flash files):
http://www.4shared.com/file/11388050..._bootcore.html
and/or
A62 firmware 07 language pack 91 (single flash file - use only the 8MB fullflash):
http://www.4shared.com/file/96828339...62_07_AMD.html
I propouse to use the last Joker software:
http://www.4shared.com/file/88732412...ker_0356c.html
So, open Joker, select Type; A60/A62, comport 1 or 2, COM Speed: 115200 and bootcore Typ: Normal. Go to flash menu, select FullFlash, check only ReCalc Keys and click to Write. Select fullflash file (file with 8MB dimension) and wait to finish.
I propouse to try first to flash only bootcore area (to not loose your stored files). Use flash file "A62_80-01_BC_bcore.bin" from the "a62_v06_bootcore.rar" archive. Set in the Flash menu "BCORE" option and remain checked only ReCalc Keys option. Wait to finish and enter in Service Mode to see if is OK (phone status Factory Mode). After try to start normarly your phone. If not working, remain to fullflash everything (Bootcore, EEprom,Language pack) using 8MB fullflash file.
dagos
The Following User Says Thank You to dagos For This Useful Post:
Old 06-24-2009, 17:16   #11 (permalink)
Member: 369802
Thanks Meter: 82
after u have done tp then recalulate skey it will work, tested by me several times. good luck
Old 06-24-2009, 20:20   #12 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...only if the bootcore area or begining of EEprom is correctly, if not, Joker give somme read/write error message. Try to write b*****t in the bootcore or to erase blocks from EEprom and calculate SKEY after
dagos
Old 06-25-2009, 09:27   #13 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
I act upon on above instruction.
but after that such logs received in the end.
in case of flashing and calc skey and recalc skey.
in all conditions above logs received.
Old 06-25-2009, 20:02   #14 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...this message apeair if you not have cut track (realyse testpoint). Verify again testpoint.
dagos
siemens A65 phone disabled phone code astana2007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-02-2010 12:07
C60 Phone Disabled Phone Code -Pls Help- dmaetrey E-Gold Based Phones 32 07-28-2009 04:54
Siemens S6 Phone Disabled Network Code Problem Brother_Nicky x1x to x45/x50 1 10-29-2001 12:12
Phone Disabled-Network Code marketmike x1x to x45/x50 5 06-06-2001 11:09
NEED HELP: c35 phone disabled network code v05 gsnbhagawan x1x to x45/x50 1 03-22-2001 16:34
Page generated in 0.37436 seconds with 10 queries
