Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 01-31-2009, 09:02   #1 (permalink)
Member: 485983
Thanks Meter: 25
A55 Wrong softweare!
I have A55 which shows wrong sw or that stupid sound when i try to turn on phone!I have tryed with Joker to del instances but after that the problem remains.I havent flash these phone for a very long time and i have forgotten the flashing procedure for A55.So if some one can give me the files and softweares that i need and a tutorial how to flash A55 i would be very gratefull?!
Here se is log from Joker:
****** Joker Siemens EGOLD Phone Version 0.3.0.6 opened. ******
****** petak, siječanj 30, 2009, at 19:38:36 ******
Start...
Cancel.
Phone Off.
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
HWID: 196 (A55)
A55 lg1 Sw11 27.11.03 12:23:25
IMEI: 353350004403632
FlagStatus: 0
Code(05): OTP closed
Code(08): BootKEY is unknown
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 4096mV.
SecurityMode: Customer
Instance Format...
Delete Instance "Voice Memo" - Ok.
Delete Instance "Voice Dialing" - Ok.
Delete Instance "Browser Cache" - Ok.
Delete Instance "File System" - Ok.
Delete Instance "Tegic" - None.
Delete Instance "Address Book" - Ok.
ReStart Phone!
Start...
HWID: 196 (A55)
FlagStatus: 0
Battery Voltage 4052mV.
****** Joker Siemens EGOLD Phone Version 0.3.0.6 closed. ******
****** petak, siječanj 30, 2009, at 19:46:11 ******
Thanx.
Old 01-31-2009, 09:11   #2 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
Start...
Cancel.
Phone Off.
Start...
HWID: 196 (A55)
FlagStatus: 0
Instance Format...
ReStart Phone!
Start...
HWID: 196 (A55)
FlagStatus: 0
Thanx.
...not flash now..
Open Joker->SKey menu-> check OTP IMEI and click to "ReCalc All keys".
Push shortly power on button (from the phone) and wait.
Post Joker log to see if is OK!
dagos
Old 01-31-2009, 09:21   #3 (permalink)
Member: 485983
Thanks Meter: 25
This is what i get:
Loading BootsModel(A55)...
StartBoot does not answer!
do i need testpoint or...?!
Old 01-31-2009, 09:27   #4 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
This is what i get:
...to flashing/unlocking your phone you need to have testpoint (cut one track) and use the service cable (not data cable). For the testpoint picture see in Joker->TP
dagos
Old 01-31-2009, 09:55   #5 (permalink)
Member: 485983
Thanks Meter: 25
DAGOS THANX A LOT....you have just earned me 10 Euros and a happy customer.I hope i will be able to help you sometimes...thanx and best regards from Croatia!
I have done testpoint cut and have used usb to serial data cable...here is log:
No open Com4 Baud Rate 115200!
Start...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com4 115200 BAUD: Ok.
SIEMENS A55 lg1 Sw11
Soft FlashID: 0089/0017
FlashID: 0089/0017
Flash Size: 8Mb, WriteBuffer: 32 bytes
Region(1): Blocks 64, Size 128Kb
Start EEPROM segments at addres 0xFA0000
FSN: FC1027E6 -> PhoneID: E62710FC
OTP IMEI: 353350004403632
HASH: B5AD94AF0B7EFA736540C5B653F58BFB
Use OTP IMEI: 353350004403632
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
Read BCORE addr: 0x800000 size: 0x020000...
BCORE backup in ".\Backup\A55lg1Sw11_BCORE_090131094953.bin" file.
Write BCORE at addr: 0x800000...
Change BCORE HASH - Ok.
Read EEPROM addr: 0xFA0000 size: 0x060000...
EEPROM backup in ".\Backup\A55lg1Sw11_EEPROM_090131095040.bin" file.
Write EEPROM addr: 0xFA0000 size: 0x060000...
Change BOOTKEY - Ok.
Change EEP0076 - Ok.
Change EEP5009 - Ok.
Change EEP5077 - Ok.
Change EEP5121 - Ok.
Change EEP5122 - Ok.
Change EEP5123 - Ok.
Old 01-31-2009, 10:08   #6 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
Start...
FlashID: 0089/0017
USE SKEY: 12345678
...OK!
If you used "Del Instance" function, you need to upload in the phone FFSinit file. Otherwise, not have any data inside (except the manufacture file). If you leave in Croatia, I suppouse to needed the language pack for this country
For the FFSinit file, go to:
http://eh.student.utwente.nl/~landy/...?dir=A55_A55A/
user: mobile
password: elibom
and download: FFSInit_A55_1_Standard_11_0001.zip from the FFSInit folder
For the language pack, download file A55_110201w.zip
Best regards from Romania,
dagos
Old 01-31-2009, 10:14   #7 (permalink)
Member: 485983
Thanks Meter: 25
Hmmm...ok.But how to upload those files?
Old 01-31-2009, 10:21   #8 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...simple,
Power on your phone, open executable, configure comm and baudrate (faster because you use DCA510 cable) and wait. First you need to use FFSInit executable and after the Firmware update executable...
dagos
Old 01-31-2009, 10:33   #9 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...BTW: FFSInit executable working together with DES or other phone manager software. If not haved, download from:
http://rapidshare.com/files/19193909...tware_v267.zip
dagos
Old 01-31-2009, 10:50   #10 (permalink)
Member: 485983
Thanks Meter: 25
Ok.thanx...all is done...!
Old 03-21-2009, 09:54   #11 (permalink)
Member: 485983
Thanks Meter: 25
Hallo mr.DAGOS....
Now i have A52 which have the same stupid sound when trying to power on.I have recalc all keys as you exsplain before but that did not help....
What can i do?
Old 03-21-2009, 21:44   #12 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
Hallo mr.DAGOS....
What can i do?
...seems to be flash corrupted
Enter in service mode and post the log from this phone to see what is wrong.
dagos
Old 03-31-2009, 17:45   #13 (permalink)
Member: 485983
Thanks Meter: 25
Cant read....
Start...
No Ping Mobile!
Start...
No Ping Mobile!
Start...
No Ping Mobile!
Start...
No Ping Mobile!
Start...
No Ping Mobile!
Start...
Old 03-31-2009, 18:50   #14 (permalink)
Shiroko's Avatar
Member: 388209
Thanks Meter: 47
Download full flash files, with eprom, and bootcore, flash all three files, then do recalculalte keys and all will be ok 100%...
Old 03-31-2009, 20:30   #15 (permalink)
dagos's Avatar
Member: 416908
Thanks Meter: 398
...if you see in the log file, doesn't have any connection between PC and mobile phone.
In the future, please read carrefully the log file and after give solution.
Second, if you don't know, the fullflah file contain inside the eeprom, bootcore and language pack parts
Gorane, rehot CPU and after try again. If not working, verify (and change if is damaged) the EMI filter.
dagos
A55 Wrong Software virteksgsm E-Gold Based Phones 9 08-23-2004 11:52
A55 Wrong Software jabba E-Gold Based Phones 11 01-21-2004 23:51
A55 wrong SW now dead Tina_sk9 E-Gold Based Phones 2 09-08-2003 14:16
c45 wrong softwear akabigjoe x1x to x45/x50 5 09-02-2003 01:52
s25 repair (( wrong softwear )) iceman1 x1x to x45/x50 16 04-12-2001 12:09
Page generated in 0.31868 seconds with 10 queries
