a65 need flashfile to repair network for friea by nutzo a65 need flashfile to repair network for friea by nutzo amd chipset! any one have? the format of the flashfile is .FLS.............................. thanks in advance |
...for A65 -AMD freia flasher, download files from: http://rapidshare.com/files/211111002/A65_AMD_freia.rar dagos |
no need to spend time in search just ask dagos !me too am loking for this file :) , you are the best my friend keep it up! br |
thank u mr DAGOS, i tried your flash file but again no network!!!!!!!!:( |
Please post log file from Joker. I send you link from the Joker fullflash file. In which country you live??? http://rapidshare.com/files/17685583...7_AMD_16MB.rar dagos BTW: before fullflash your phone, try to unlock with Joker (not by Freia). Maybe working after :) |
dagos |
everytime i use joker this message appears Open file "D:\CELLPHONE TECHNICIAN TOOLS BY DARWINBAGSIK\FLaSHFiLeS\SieMeNS\A65\A65_AMD_No_Net _Fix_FF\A65_AMD_No_Net_Fix_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/2212 SIEMENS A65 Sw15 lg98 RealLgPack: lg5 Start... Loading BootsModel(A65)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A65 lg5 Sw06 Soft FlashID: 0001/2212 FlashID: 0001/227E-2212-2200 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 256, Size 64Kb Start EEPROM segments at addres 0x7C0000 FSN: AE7B4ABB -> PhoneID: BB4A7BAE OTP IMEI: 354494007302430 HASH: 68F74045495650DF29E446B19B70C636 ClearFlashSeg at 0x000000 does not answer! in friea by nutzo flashing continue! my problem is i cant flash with joker only in friea, i cut the testpoint already! no service!!! THANKS mr. DAGOS |
Try to fullflash using the older version of Joker. dagos |
Open file "C:\Documents and Settings\MaRGie\My Documents\JokerV0324\A65_AMD_No_Net_Fix_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2212 Start... Cancel. Open file "C:\Documents and Settings\MaRGie\My Documents\JokerV0324\A65_AMD_No_Net_Fix_FF.bin" for write in Flash. FullFlash file used FlashID: 0001/2212 Start... Loading BootsModel(A65)... Sending StartBoot Ok. Sending MainBoot Ok. SIEMENS A65 lg5 Sw06 FlashID: 0001/227E-2212-2200 Flash Size: 16Mb, WriteBuffer: 32 bytes Region(1): Blocks 256, Size 64Kb Window RAM block: 512Kb Start EEPROM segments at addres 0x7C0000 FSN: AE7B4ABB -> PhoneID: BB4A7BAE OTP IMEI: 354494007302430 HASH: 68F74045495650DF29E446B19B70C636 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A65lg5Sw06_Backup090323165434.eep" file. ClearFlashSeg at 0x000000 does not answer! |
...you set baudrate to 115200 bauds??? dagos |
thank you again mr. dagos but it seems my a65 doesnt flash in joker with any baudrates! same logs! do you have a fls file amd repair network for friea? @pepot |
Fullflash file "A65_AMD_No_Net_Fix_FF.bin" working only with SST software, not with Joker. For Freia I don't have any fullflash wile with firmware up to FW6. So, use SST for flashing your phone, after repair using this function from SST software and finally unlock your phone using Joker software. Download archive from http://rapidshare.com/files/212830609/sst_install.rar , run SST5_Setup.exe and replace installed file "SST.exe" with file from archive. The other way is to use fullflash backup from Joker (amd FULLFLASH - FIRMWARE 17). http://rapidshare.com/files/212831318/a65_sw17.rar That is. dagos |
everytime i flash my a65 in sst it shows writing flash but there is no status bar! in short no flashing, i set all the baudrate but it gaves me the same result. THANKS again mr. DAGOS i appreciate your goodness. waiting again for your reply! |
Try to fullflash with Joker (lower version) sended fullflash file (with FW17). dagos |
