E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
11-07-2007, 13:05 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Age: 47
Member: 76390 Status: Offline Thanks Meter: 0 | A75 blink Error Read Flash block 0x800000 size 0x004000! Here is a log of Joker, please somebody: Open file "C:\Documents and Settings\une\Desktop\A75\A75_80-80_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A75 Sw20 lg98 RealLgPack: lg98 Start... Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: D84B3153AB22CA987F41B77D31C68398 Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A75lg98Sw20_Backup071107121543.eep" file. Restore EEP0067 - Ok. Restore EEP5005 - Ok. Restore EEP5007 - Ok. Restore EEP5012 - Ok. Restore EEP5093 - Ok. Data file "C:\Documents and Settings\une\Desktop\A75\A75_80-80_FF.bin". Write Flash addr: 0x800000 size: 0x800000 - Ok. Open file "C:\Documents and Settings\une\Desktop\A75\A75_80-01_BootCore.bin" for write in Flash. Start... Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: D84B3153AB22CA987F41B77D31C68398 Data file "C:\Documents and Settings\une\Desktop\A75\A75_80-01_BootCore.bin". Write Flash addr: 0x800000 size: 0x010000 - Ok. Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 237 (A75) A75 lg98 Sw20 19.05.05 14:07:25 IMEI: 358089002137678 DisplayID: 46, Wintek STE2020 Code(05): OTP closed Code(09): BootKEY is written in EEPROM Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3942 mV. SecurityMode: Customer Instance Format... Delete Instance "Voice Memo" - None. Delete Instance "Voice Dialing" - None. Delete Instance "Browser Cache" - None. Delete Instance "File System" - Ok. Delete Instance "Tegic" - None. Delete Instance "Address Book" - Ok. ReStart Phone! Backup EEPROM blocks... SecurityMode: Customer Work only in FactoryMode! Use Skey! HWID: 237 (A75) EELITE Info: free buffer 43686 bytes, free at all 44402 bytes, free for deleted 44402 bytes. EEFULL Info: free buffer 75568 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Read All EELITE blocks from 1 to 310 ... Read All EEFULL blocks from 5000 to 5439 ... Ñ÷èòàíî âñåãî EEP áëîêîâ: 388 øò. Backup Blocks saved in ".\Backup\A75lg98Sw20_Backup071107123733.eep" file. Format EELITE... EELITE Info: free buffer 65360 bytes, free at all 65392 bytes, free for deleted 65392 bytes. Write 189 EELITE blocks... Format EEFULL... EEFULL Info: free buffer 86864 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Write 199 EEFULL blocks... EELITE Info: free buffer 44338 bytes, free at all 44402 bytes, free for deleted 44402 bytes. EEFULL Info: free buffer 43916 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Defrag EEPROM blocks - Ok. Read Keys... Not read HASH! Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 237 (A75) A75 lg98 Sw20 19.05.05 14:07:25 IMEI: 358089002137678 DisplayID: 46, Wintek STE2020 Code(05): OTP closed Code(08): BootKEY is unknown Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3916 mV. SecurityMode: Customer Read Keys... SecurityMode: Customer Work only in FactoryMode! Use Skey! Start... Phone off! Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: 61EED61DBED2B30FD76CB5735C5EA9EA Use OTP IMEI: 358089002137678 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... Error Read Flash block 0x800000 size 0x004000! Start... Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: 61EED61DBED2B30FD76CB5735C5EA9EA Use OTP IMEI: 358089002137678 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... Error Read Flash block 0x800000 size 0x004000! Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. HWID: 237 (A75) A75 lg98 Sw20 19.05.05 14:07:25 IMEI: 358089002137678 DisplayID: 46, Wintek STE2020 Code(05): OTP closed Code(08): BootKEY is unknown Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 3912 mV. SecurityMode: Customer Instance Format... Delete Instance "Voice Memo" - None. Delete Instance "Voice Dialing" - None. Delete Instance "Browser Cache" - None. Delete Instance "File System" - Ok. Delete Instance "Tegic" - None. Delete Instance "Address Book" - Ok. ReStart Phone! Backup EEPROM blocks... SecurityMode: Customer Work only in FactoryMode! Use Skey! HWID: 237 (A75) EELITE Info: free buffer 44338 bytes, free at all 44402 bytes, free for deleted 44402 bytes. EEFULL Info: free buffer 87012 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Read All EELITE blocks from 1 to 310 ... Read All EEFULL blocks from 5000 to 5439 ... Ñ÷èòàíî âñåãî EEP áëîêîâ: 388 øò. Backup Blocks saved in ".\Backup\A75lg98Sw20_Backup071107124159.eep" file. Format EELITE... EELITE Info: free buffer 65360 bytes, free at all 65392 bytes, free for deleted 65392 bytes. Write 189 EELITE blocks... Format EEFULL... EEFULL Info: free buffer 87012 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Write 199 EEFULL blocks... EELITE Info: free buffer 44338 bytes, free at all 44402 bytes, free for deleted 44402 bytes. EEFULL Info: free buffer 44064 bytes, free at all 87224 bytes, free for deleted 21832 bytes. Defrag EEPROM blocks - Ok. Start... Phone off! Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: 61EED61DBED2B30FD76CB5735C5EA9EA Use OTP IMEI: 358089002137678 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... Error Read Flash block 0x800000 size 0x004000! Start... Loading ServiceBoot... Sending ServiceBoot Ok. BFB Speed 115200 Baud - Ok. The block 5008 misses! Open file "C:\Documents and Settings\une\Desktop\A75\A75_80-80_FF.bin" for write in Flash. FullFlash file info: FlashID: 0001/220C SIEMENS A75 Sw20 lg98 RealLgPack: lg98 Start... Phone off! Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: 61EED61DBED2B30FD76CB5735C5EA9EA Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 76 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 12 bytes - Ok. EEPROM blocks is written in ".\Backup\A75lg98Sw20_Backup071107124359.eep" file. Restore EEP0067 - Ok. Restore EEP5005 - Ok. Restore EEP5007 - Ok. Restore EEP5012 - Ok. Restore EEP5093 - Ok. Data file "C:\Documents and Settings\une\Desktop\A75\A75_80-80_FF.bin". Write Flash addr: 0x800000 size: 0x800000 - Ok. Start... Loading BootsModel(A75)... Sending StartBoot Ok. Sending MainBoot Ok. Com6 115200 BAUD: Ok. SIEMENS A75 lg98 Sw20 Soft FlashID: 0001/220C FlashID: 0001/227E-220C-2201 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 128, Size 64Kb Start EEPROM segments at addres 0xFC0000 FSN: C5B659A0 -> PhoneID: A059B6C5 OTP IMEI: 358089002137678 HASH: 61EED61DBED2B30FD76CB5735C5EA9EA Use OTP IMEI: 358089002137678 USE SKEY: 12345678 *#0000*12345678# - Network Lock *#0001*12345678# - Service Provider Lock *#0002*12345678# - Corporate Code *#0003*12345678# - Phone Code *#0004*12345678# - Network Subset Lock *#0005*12345678# - Only Sim Read BCORE addr: 0x800000 size: 0x010000... Error Read Flash block 0x800000 size 0x004000! Start... Loading ServiceBoot... Sending ServiceBoot Ok. The phone was switched off on an error: EXIT: E002 08 006C |
11-07-2007, 13:12 | #3 (permalink) |
Member: 76390 Status: Offline Thanks Meter: 0 | I don't have Martech, I need a solution with what I've got. P.S. To moderators, please delete my double post, because of my Internet connection, sorry for inconvenience, thanks a lot. |
11-07-2007, 13:19 | #4 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | You can also do it by Joker, just use repair file download it from here Code: http://samer4zen.free.fr/abigore/siemens/jokerflashes/A75.rar Code: http://samer4zen.free.fr/abigore/siemens/jokerflashes/A75_8Mb_010C_FF.rar Code: http://samer4zen.free.fr/abigore/siemens/jokerflashes/A75_eeprom.rar |
A75 blink lcd | bmg | E-Gold Based Phones | 1 | 09-27-2006 00:25 |
siemens A75 phone blink before and after flash do not power one | leroi | E-Gold Based Phones | 10 | 08-14-2006 16:31 |
A75 still blinking after flash | ASHIF | DreamBox | 4 | 03-02-2006 15:51 |
