E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
12-12-2003, 16:48 | #2 (permalink) |
Junior Member Join Date: Jul 2003 Age: 47
Member: 35277 Status: Offline Thanks Meter: 0 | hi dreamgsm , did you found some solution? i have the same problem freia canīt upload new flash imei correctly still write me this Eeprom Imei is 35081070230918 (its correct) and when i wanna write as new flash imei this is result ! SEC_AdjustOriginalIMEI : changed IMEI from '35081070230918' to '00000000000000' COMM_UpdateOriginalIMEI : desired new original IMEI is '00000000000000' O.K. phone only bzzzz i tried many solutions from net by all3/4v2.10 or swup, full flash but no soft works correctly with change flash imei like for example wizard for c55. can someone help me? thanx |
12-12-2003, 18:03 | #4 (permalink) |
Freak Poster Join Date: Feb 2001 Location: SPAIN
Member: 3377 Status: Offline Thanks Meter: 1 | well, i solved my problem with freia8 1.- select model M50 2.- go to unlocking functions 3.- select create map from phone 4.- only write the new imei without select any tip 5.- select ok and follow instructions 6.- go again to unlocking functions and select upload map 7.- select the file and upload it |
12-15-2003, 21:25 | #6 (permalink) |
Member: 3377 Status: Offline Thanks Meter: 1 | well mate! anyway remember that doing only i wrote before can change imei, is not needed change anything in flash. Try to write epp (the same version of the flash) then flash with update tool, then make map from phone writing the correct imei and upload it then. Good luck mate! Best regards |
12-16-2003, 12:13 | #8 (permalink) |
Member: 35277 Status: Offline Thanks Meter: 0 | i tried to full flash. than eeprom ... phone only bzzz after i used swup .... phone only bzzz than i change imei with freia ... phone only bzzz i tried to unlock with map ... phone only bzzz freia still write me eeprom imei - 350810.... (good) OTP imei corrupt - 0000.... i think there is problem |
12-16-2003, 14:03 | #9 (permalink) |
Member: 3377 Status: Offline Thanks Meter: 1 | take it easy, first of all , follow steps as it: flash phone with update tool, write epp of the same version of the flash uploaded, now with freia8 make map from phone writing the correct imei, then upload that map. Thatīs all, post result after operation please regards |
can some one please give a guide on how to change imei on k750i please | nokia_dan | Cruiser Suite | 0 | 11-26-2005 20:44 |
how to change imei of m50 china (3118) | cpl2003 | E-Gold Based Phones | 2 | 08-14-2003 05:41 |
How to change imei on bosch 909/909S ? | robbie | Various | 2 | 04-09-2003 20:58 |
How to change imei on S35? | NUGSM | x1x to x45/x50 | 2 | 10-29-2001 14:29 |
How to change IMEI on T28 ?? | Craig | Old Ericsson Phones & Sony Phones | 0 | 08-03-2000 00:31 |
