E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
02-12-2008, 06:29 | #1 (permalink) |
Crazy Poster Join Date: Sep 2003
Member: 38918 Status: Offline Thanks Meter: 4 | A52 dead After make unlock with freia15 he is dead... I try to put a full flash to see if he get alive again but nothing. I don't know what I have done but now I get this message with joker: Start... Loading BootsModel(A51)... Sending StartBoot Ok. Sending MainBoot Ok. Warning: HASH data error! SIEMENS A52 lg1 Sw05 Soft FlashID: 002C/0016 FlashID: 002C/0017 Flash Size: 8Mb, WriteBuffer: 32 bytes Region(1): Blocks 64, Size 128Kb Warning: Not valid Flash Size in set phone model! Start EEPROM segments at addres 0xBA0000 FSN: 4B6F5E80 -> PhoneID: 805E6F4B OTP IMEI: **************** HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Read EEP0067 block (ver00), size 20 bytes - Ok. Read EEP0076 block (ver00), size 10 bytes - Ok. Read EEP5005 block (ver00), size 64 bytes - Ok. Read EEP5007 block (ver00), size 10 bytes - Ok. Read EEP5008 block (ver00), size 224 bytes - Ok. Read EEP5009 block (ver00), size 10 bytes - Ok. Read EEP5012 block (ver00), size 12 bytes - Ok. Read EEP5077 block (ver00), size 232 bytes - Ok. Read EEP5093 block (ver00), size 32 bytes - Ok. Read EEP5121 block (ver00), size 56 bytes - Ok. Read EEP5122 block (ver00), size 6 bytes - Ok. Read EEP5123 block (ver00), size 14 bytes - Ok. EEPROM blocks is written in ".\Backup\A52lg1Sw05_Backup080212052220.eep" file. CRC error in transfer buffer or bad RAM! (Block at 0xA20000). thanks devil24 |
02-13-2008, 18:02 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | .................................................. ........ Hi, I see your log file and seems to the bootcore is damaged (of course, using Freia for unlocking...). To know how to flash/unlock using Freia or Joker, see bellow: 1. if use the Freia software: Flashing: -connect the serial cable -open Freia -select phone model -enter "Configuration function" and set the Com port of cable, check RTS and DTR, speed on 115200, Process information to Medium, boot tipe to the Normal and OK. -enter to "Write flash to phone" and open your fullflash file (".fls" or ".bin" file from SST software, not ".bin" file from Joker!!!). -preset to "Firmware" (on the Count window you have the fullflash file dimension) and click to OK. -press short the phone red key (not working autoignition) and wait ~ 20 minutes to finalise (see on the Process information window). Unlocking: -enter to "Unlocking functions", select "Direct unlock no map is saved" and OK. If your phone make BZZZ (and/or shortly splash display), something is wrong (fullflash file low version or not correct unlocked). -disconect serial cable and start normaly your phone. 2. If use the Joker software: Flashing: -connect the serial cable -open Joker -set phone type,COM port, COM speed (115200), Boot typ (Normal). -click on "Flash" tab and select Fullflash, Protect BCore (verry important!!!) and click on the Write tab. -select the file for write on the flash and "Open" IF YOU RECEIVE THE MESSAGE "The file size is not equivalent to a size of area!To record?" CLICK ON "NO" AND SEARCH THE GOOD FULLFLASH FILE!!!! -wait to finalise fullflash process Unlocking: -click on "Skey" tab and click on "ReCalc All Keys". Remember: After each fullflash you need to unlock your phone. Otherwise...make short splah on display and (or) Bzzzz on speaker. To solve your problem, now, you need first to flash the bootcore area, after you need to make fullflash. For flashing the bootcore area you need to have same firmware version with the flash version in the phone.Download from http://www.gsmsimlocking.com/Gsm/ind...l_Support/A52/ user: gsmsimlocking password: freefornow file "a52_v05.rar". Flash using Joker. First use "A52_80-02_BC.bin" file (remember to select BCORE in the Flash tab) and after use "A52_80-80_FF.bin" file (select Fullflash and check ReCalc Keys - to make automatically unlock after fullflash). Remember, in this two step, you need to have "Protect Bootcore" checked, otherwise, you need to repeat the all steps... That is. dagos |
02-15-2008, 05:59 | #5 (permalink) |
Member: 38918 Status: Offline Thanks Meter: 4 | Thanks to both I try to find flashes to freia but without sucess ... So I use joker but always get this message: IF YOU RECEIVE THE MESSAGE "The file size is not equivalent to a size of area!To record?" CLICK ON "NO" AND SEARCH THE GOOD FULLFLASH FILE!!!! dagos Is this the flash that I must use file "a52_v05.rar". It appears the message too. I try many flashes but all say this message... What means this: FlashID: 002C/0017. regards devil24 |
02-29-2008, 20:09 | #6 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | dear devil24 please send me a52 flasher software at my email [email protected] |
a52 DEAD after test point,help me please | mohammed | E-Gold Based Phones | 2 | 06-02-2004 00:17 |
A52 dead please......../.. | lahham | E-Gold Based Phones | 2 | 04-06-2004 21:29 |
help a52 dead | hekker | E-Gold Based Phones | 1 | 02-24-2004 14:44 |
a52 dead | archil | E-Gold Based Phones | 2 | 01-09-2004 08:04 |
A52 Dead | drnele | E-Gold Based Phones | 9 | 10-16-2003 02:39 |
