E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
06-18-2008, 15:56 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Colombia Age: 48
Member: 197360 Status: Offline Thanks Meter: 25 | A70 Boot2 does not answer!! i have this problem, test point ok but says: Start... Loading BootsModel(A70)... Sending StartBoot Ok. Error: Boot2 answer code(00)! Start... Loading BootsModel(A70)... Sending StartBoot Ok. Boot2 does not answer!! |
06-18-2008, 16:39 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
regarding to your problem, seems to you don't have the good testpoint or your cable is "data cable" type, not the "service cable". BTW, which type of cable you use??? dagos | |
06-01-2009, 06:04 | #6 (permalink) |
Junior Member Join Date: Jul 2008 Location: Dhaka Age: 38
Member: 821394 Status: Offline Sonork: Shaon Thanks Meter: 1 | Boss i'm using Siemens DCA-510 master cable and i've done flash so many sets by that cable. I've also used ufs-c55 cable but it works same. Plz, help me.....b4 cut the testpoint the set was blinking problem after cutting testpoint now its dead. |
A70 "StartBoot does not answer!" after full flash | GRIFFFMAN | E-Gold Based Phones | 9 | 04-25-2006 11:34 |
Boot2 does not answer !!! | hacktek | Siemens Hardware Repair Area | 2 | 12-30-2005 09:07 |
A70 - Joker: "MainBoot does not answer!" | paullovinicius | E-Gold Based Phones | 2 | 12-04-2005 19:50 |
Boot2 does not answer!! AX75???? | GRAVE_DIGGER | Siemens-Benq RingTones and WallPapers | 4 | 11-12-2005 22:00 |
Legija does not receive or it does not answer the support email. | TORRES | UniMoto | 0 | 10-16-2005 18:51 |
