I have to write a eeprom file out from MC60 FUBU. Someone suggested to use smelter, but I can not write a eeprom file out from FUBU like it normally is the capacity of 256k by using smelter. (it is saved with many small files of every block together with but not one big eeprom file.) How to write a eeprom file out from fullflash in smelter. Need your help!!!! If there are more easy ways can do this by using other softwares .please give advices. Thanks very much!!!!! |
Load that fubu in V_klay. Select work with: File with part of flash. Then use the flasher and just read EEPROM area like a phone was connected ;) Then you've extracted the EEPROM from your Fubu |
Enter your HWid (or just 123, if you don't know it) |
Yeh, I have done it before but have no result why? Quote:
That's it!!! Thanks very much!!!!! Quote:
Thanks very much!!!!! :) |
V_Klay, WorkWithFile, open your fubu, Flasher, choose EEPROM, ReadMemory, SaveFile |
Yeh, you're right.thanks!!! Quote:
