E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section. |
02-27-2004, 10:36 | #1 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Croatia Age: 54
Member: 45796 Status: Offline Thanks Meter: 13 | C55 Wrong Software When I uppload higher version of software then original,I can switch phone,I can make the call,but when I quickly press the butons,phone is shut it down,and this is hapened in all 3 peaces of C55.What was wrong whit these? Please some help here. Thanks! |
The Following User Says Thank You to BVC-PROJECT For This Useful Post: |
02-27-2004, 11:22 | #3 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Croatia/Zd Age: 44
Member: 26670 Status: Offline Thanks Meter: 5 | try writing fullflash, and after that change IMEI function by entering your original IMEI... |
The Following User Says Thank You to 3aTmr For This Useful Post: |
02-27-2004, 11:48 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Try the free Siemens Service Toolbox, it worked for a C55 with Wrong Software that I had, just push the Repair phone button |
The Following User Says Thank You to byteforce For This Useful Post: |
02-27-2004, 19:59 | #5 (permalink) |
Member: 45796 Status: Offline Thanks Meter: 13 | I think that is hardware problem ( I have original Martech box ),so if somebody has similar problem,please post it. Thanks! |
02-27-2004, 22:05 | #6 (permalink) |
Freak Poster Join Date: Feb 2004 Location: New York Age: 47
Member: 55964 Status: Offline Thanks Meter: 12 | I've seen a lot of such phones(made in china,hungary) ussual problem - CPU desoldering |
The Following User Says Thank You to Botya666 For This Useful Post: |
02-28-2004, 13:45 | #7 (permalink) | |
Junior Member Join Date: Feb 2004
Member: 56040 Status: Offline Thanks Meter: 0 | Quote:
02-28-2004, 17:00 | #8 (permalink) |
Member: 55964 Status: Offline Thanks Meter: 12 | To BVC-Project: To detect the CPU contacts problem just press 1 or 4 on the phone harder then ussual, if phone powers down and then it is wrong soft - that's it. |
02-28-2004, 17:31 | #9 (permalink) |
Registered User Join Date: Dec 2003 Location: Algeria Age: 47
Member: 47936 Status: Offline Thanks Meter: 20 | use all siemens no test pte soft with option where you write the original imei |
The Following User Says Thank You to .::Moby World::. For This Useful Post: |
03-10-2004, 14:05 | #10 (permalink) |
Insane Poster Join Date: Feb 2004 Location: India
Member: 54805 Status: Offline Thanks Meter: 2 | thanx & u are right! two c55 phones both with 'wrong software' solved simply by using this repair function!! |
The Following User Says Thank You to manuka For This Useful Post: |
03-13-2004, 12:07 | #12 (permalink) |
Member: 54805 Status: Offline Thanks Meter: 2 | @Snake14, Thanx all the same! @ALL, btw, i have another C55 which i unlocked...but after that the phone remains in 'Searching for Network' and unable to conect to any network.... any help anyone please.... tks! |
03-13-2004, 22:01 | #14 (permalink) |
Member: 47936 Status: Offline Thanks Meter: 20 | hi manuka they r 2 possiblts: if this phone was working well in the original opirator it is soft pb solve it by full flash+repair imei the other it is hardware pb and it is PA change and poste results. |
06-02-2004, 07:49 | #15 (permalink) | |
No Life Poster Join Date: Jan 2003
Member: 20069 Status: Offline Thanks Meter: 131 | Quote:
u like to tell me any link plz where i can get free Siemens Service Toolbox ??? Big thanx in adv | |
The Following User Says Thank You to the_frightener For This Useful Post: |
C55 Wrong Software | Seed_Mobile | E-Gold Based Phones | 15 | 02-02-2009 17:19 |
C55 wrong software after 2minuts working | moustafatch | E-Gold Based Phones | 19 | 09-04-2003 16:45 |
c55 wrong software | Burnt Cobba | E-Gold Based Phones | 4 | 07-25-2003 18:00 |
C55 wrong software repair solution | postas99 | E-Gold Based Phones | 14 | 05-27-2003 22:34 |
