Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 09-16-2006, 20:01   #46 (permalink)
fastlink Jogja's Avatar
Member: 192822
Thanks Meter: 18
Originally Posted by BB-gsm View Post
@ hallo
Have you tried to plug in charger to the powered off phone ?
hi i need 32mb symbian flash but the link is broken. can you give me another link? i need this sw urgently. thanks before
fastlink jogja
Old 09-16-2006, 23:38   #47 (permalink)
hacktek's Avatar
Member: 76629
Thanks Meter: 76
fastlink jogja
Here it is the Symbian file you wanted!
This goes with this E-gold flash file! Maybe you will need it, too!
Hurry up with the download, the link will stay only for 3 days!
Old 09-16-2006, 23:49   #48 (permalink)
hacktek's Avatar
Member: 76629
Thanks Meter: 76
Originally Posted by SRNOURI View Post
I need help about SX1,it comes to me off but it goes to update mode (By presing joystick center button + power) but when i want to flash with winswap program my computer couldn't detect phone as a usb device.I test another sx1 but no problem with that.What is problem??? CPU or Flash IC or power ic(Dialog IC)??
Please help me dear master in siemens.
B.R.
1.Make testpoint and flash fullflash using a normal COM cable or DCA-510 with Joker. Do an unlock (ReCalc All Keys).
2. Remove testpoint, and flash Only Core from WinSwUp using DCA-510 or a COM cable.
3. Flash using the DCA-540 (USB) with WinSwUp all flash parts, without CORE. At this step, repeat until the computer see the SX1 driver correctly. Sometimes it needs a computer restart!)
@dojran: Repeat step 3 until it will be ok!
Old 11-25-2006, 14:46   #49 (permalink)
Member: 192822
Thanks Meter: 18
hi hacktek link not working. can you upload again sx1 symbian file? thanks alot..
i have problem with another sx1 now. problem is phone cannot power on at all. lower machine is okey and i was flashed with martech. i tried to change upper board with working phone and work. what you suggest? i think i must flash symbian machine right? the older cases is phone cannot format manual just showing siemens and about 75% format phone will restart. lower machine is okey. any suggest?
thanks...
fastlink
Old 11-25-2006, 14:50   #50 (permalink)
Member: 192822
Thanks Meter: 18
sorry im too busy with many cases repairing phone and i forgot to read this forum. but phone problem not solved yet and i found another cases and i think i will need that symbian file. can you upload again..?
many thanks hacktek
fastlink
Old 12-12-2006, 13:29   #51 (permalink)
hackerbd's Avatar
Member: 247758
Sonork: 100.1574842
Thanks Meter: 259
To day 12.12.06. Now your link dos'nt work.Plz link again if possible.
Old 01-22-2007, 11:26   #52 (permalink)
Crazy Poster
Member: 94546
i have siemens sx1 dead when power on only beeping a sound of low battery
i need help.....thanks
Old 01-25-2007, 23:01   #53 (permalink)
samusprime's Avatar
Member: 189984
Thanks Meter: 112
Question
i have the same problem
any solution plzzzz
txs in advance
Old 01-29-2007, 17:39   #54 (permalink)
sid_vicious's Avatar
Member: 199469
Thanks Meter: 11
im desperd to sx 1...
here i have one sx1....firstime come to me in dead condition...i try pres joystick an push the power button...the phone can enter to swap mode...
so i swap the phone whit winswap 32 Egold/k1, version 3.05
after that...if i pres the power button the phone start up but only until siemens mobile...i flash again whit my martech, i put the last version flah file
i do repair imei and than unlock....
now it live again .....
pres the power button.....it show siemens mobile and then contac retailer ( 07 )<----i wonder what the sign meaning of 07 after the contac retailer word, and after show contac retailer the phone show insert simcard......but still contac retailer if we insert the sim......***...im frustrade.....
any body have solution..???
thx......
sincerly,
sid_vicious
Old 02-02-2007, 15:00   #55 (permalink)
B&B
Crazy Poster
Member: 395007
Thanks Meter: 2
Thumbs up ;)
Originally Posted by hallo View Post
..interesting...but I try that allredy....strang thing that nothing is hapening when I try to make Format by thewse way...propobli is some trouble with keyboard, but for now I'm waiting for *******r authorazition to move further...
write full flash(8m) first,i repair 3 in this way,after taht *#pw ,8m flash must be the same sw vs,i write`it with martech
good lock!
regards
Old 02-02-2007, 17:18   #56 (permalink)
Member: 199469
Thanks Meter: 11
the problem was on the cpu...
i reballing the cpu....and using usualy winswap...
now its work prefectly...
Old 02-11-2007, 23:01   #57 (permalink)
Member: 271922
Ok boys here is a tough problem
I came across V_klay and it seemed to me it can flash the OMAP symbian sofware in the sx1 using prolific cable as my usb cable is not detected anymore by my PC. So I used V_klay and unfortunately I overwrote the BOOTCORE section with garbage
So now my RED POWER button will not turn the phone flashing option on since the bootcore is gone
I go to joker and by pressing the red button will not wake the phone up
IS THERE ANY WAY to load the BOOTCORE???
Old 02-12-2007, 13:35   #58 (permalink)
tele-teknik's Avatar
Member: 64598
Thanks Meter: 54
thanx to nice solution keep up....
Old 02-13-2007, 10:27   #59 (permalink)
Member: 271922
aww no1 has a solution to my problem :'(
Old 02-16-2007, 10:20   #60 (permalink)
Member: 271922
I just got a new sxg75 phone I wish someone could put linux in it otherwise its soo limited
Repair all alcatel here!!! libra202 Alcatel TCL Hardware Repair 72 02-20-2016 18:28
Repair ALL A70 here BB-gsm E-Gold Based Phones 197 10-06-2013 01:12
Repair ALL A65 here ... ;-) BB-gsm E-Gold Based Phones 298 07-04-2011 21:06
Repair all A75 here .::Mystic::. E-Gold Based Phones 15 01-12-2008 15:10
Repair all CF62 here .::Mystic::. E-Gold Based Phones 34 12-01-2007 06:02
Page generated in 0.20193 seconds with 10 queries
