Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > E-Gold Based Phones
E-Gold Based Phones This is the section for all E-Gold and E-Gold Lite based phones: A31,A52 A55, A57, A60, A62, A65, A70, AF51, AL21, AX72, AX75, C55, C60, CF62, CF110, M55, MC60, S55, SL55 And also post all about Joker & Freia in this Section.
Old 08-24-2005, 18:24   #1 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Siemens c60/mc60/m55 etc. PERMANENT contrast solution here
i had few m55 phones,
died on gprs, so i flashed software, and
tuned contrast with contrast tool / sst ...
but after reset to defaults contrast gone ...
here's the 100% solution :
- use sst/contr.tool to adjust desired contrast
- use SkyLord's eeprom tool 3.15,
- connect phone, from right select LOAD ALL
- select field 5007, transfer to left panel, save it as *.bin file
- use ANY hex editor and in second byte put same value as in first byte
- in eeprom tool (still opened in background) load edited file
- transfer it to right panel, press SAVE ALL, wait to finish, EXIT.
all done, contrast change in menu work ok now,
and after full factory reset contrast is ok.
p.s. BIG phuck to martech/sst and all PAY solutions.
b.r.
Alexandar.
Old 08-24-2005, 21:48   #2 (permalink)
MR PROTEC's Avatar
Member: 86655
Thanks Meter: 385
thx brka you always offer good soulition
wbr
Old 08-24-2005, 22:00   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
hi,
i offer solutions that i personally use,
or re-compile/fix many unusefull solutions that i found on forum ...
i'm glad you like it
and i will contribute more in different sections of forum
(i laredy contribute some in SonyEricsson HW section etc.)
b.r.
Alexandar.
Old 08-24-2005, 22:16   #4 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
Thank you BRKA (ALEXANDAR ) !
All your solutions were helped a memmbers in this forum ! Because all these solutions came from a gifted man as you !
Best regards !
Old 08-25-2005, 00:03   #5 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
thx for the permanent solution,no more reclamations
Old 08-25-2005, 00:09   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
hi,
no more reclamations, of course
one more thing ...
if you have display that you are not 100% sure if it's ok or not ...
use SST cracked, and tune value for display type 1 : from 45-47
and if not ok try value for type 2 : from 100-105
if yu dont see on display SERVICE MODE ...
then faulty display or hardware problem
(i solved almost all cases by rehoting CPU only)
b.r.
Alexandar.
Old 08-25-2005, 00:17   #7 (permalink)
ChIcO*GsM's Avatar
Member: 152205
okay but it's not workin with me
duno watz goin on
would u plz help?
Old 08-25-2005, 11:52   #8 (permalink)
GSM SNIPER's Avatar
Member: 27291
Thanks Meter: 81
duno watz goin on
would u plz help?
If all these good things gave by our friend BRKA dont work with you , so you are really outside the Matrix !
Old 08-25-2005, 12:28   #9 (permalink)
::.::SOUFIZ GSM::.::'s Avatar
Member: 59209
Thanks Meter: 19
u'r right man
brka still one ofthe best in gsm world
go man more
sure this solution will not work out side the matrix
Old 08-25-2005, 12:38   #10 (permalink)
Cheater -Don't Deal with him-
infogsm's Avatar
Member: 18022
Sonork: 1574868
Thanks Meter: 192
just search in forum you will find eeprom files that you can just upload to your phone using eeprom tool and all will be fine
br
Old 08-29-2005, 16:30   #11 (permalink)
dickwredniak's Avatar
Member: 71669
Thanks Meter: 783
b.r.
Alexandar.
In the right panel Select All and press SAVE ALL? Not Select All and SAVE SELECTED???
Old 08-29-2005, 16:42   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
whatever
b.r.
Alexandar.
Old 08-29-2005, 16:55   #13 (permalink)
XisiX's Avatar
Member: 37090
Thanks Meter: 42
If you follow instructions exactly step-by-step, you can use 'Save All'
It's important that you have loaded all fields in right panel of EEprom Tools
I suggest 'Save selected' anyway (be carefull what fields are selected)
Old 08-29-2005, 18:27   #14 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
1000000% tested. Its Working.
Brka --- toast for you! Thanks.
br
Old 09-06-2005, 11:02   #15 (permalink)
Member: 81780
Hi,
What is rehoting cpu, will it fix a notworking mc60. when i press power button it will just give a buzz sound for 2 secs and then nothing happen, I am a starter, please tell me step by step, i shall be thankful to you for that. i can use freia with datacable.
Thanks
Solutions for Siemens A60-C60-MC60 samirov-gsm Siemens Hardware Repair Area 0 07-02-2009 08:46
A55 C55 A60 C60 Mc60 M55 Cf62 S55 Sl55 Repaİr Fulll Download ceptel E-Gold Based Phones 4 12-09-2005 19:19
MC60,C60 ,A60 How To Fix CONTRAST??? Bokonda E-Gold Based Phones 4 09-08-2005 23:42
SL55, MC60, C60 & M55 "NO" Test Points ednacell E-Gold Based Phones 5 09-26-2004 03:00
C60,MC60 Siemens Photo here bolt_gsm E-Gold Based Phones 0 07-04-2003 02:48
Page generated in 0.27113 seconds with 9 queries
