sl55 version 14 i can,t connect with pc i want to connect with feria and other unlocking program however its not version 16 which required test point and i can connect with gtcl siemence clip and i unlock it with out any problem but y i can,t connect with pc when its says power on the phone ......... i did but phone power on and nothing happened so i need cable configuration or test point waiting for reasonable reply regard uhk |
1 Attachment(s) Try this i hope it will help you |
what this is there any test point or what |
... no, no testpoint needed. ... is just the scheme of an interface (cable configuration) what works with freia. Unlock is not working with original cable. |
alright i will try thanks |
I have a problem with a SL55 version 14 too, it cannot be unlocked with any FREIA versions, when I press the power button Freia says "Phone is powered on", and after some seconds it looses contact with the phone and after that there is displayed "boot file not accepted". I tried many combinations, and played with many configuration options of Freia but no luck.. Any suggestions are aprecciated very much... Regards |
I think u have a new bootcore! U have to make testpoint! (connect R550 to GND; use search 4 more details!) |
yes chrise02 u helped me to revive my sl55 i conect the r500 to gnd then it conect to flash --- i full flash the phone and it work again thx alot anyone need help just ask what u want |
no problem ;) I hope u can help anytime too :D |
@UHT: did you have luck with sl55 (new bootcore?) @KISHEMOTO: did you unlock a new bootcore version, or revive an old one? @ ALL: anyone haveing luck unlocking new (v 14 or 16) sl5x? i have one sl56 that won't cooperate thanks |
i revive one but i dont know it version quz it was dead |
