some crypted fields in martech 3.9 hello @all, i found the new martech software 3.9 ;-) new is, that some things (like phonecode, simcard id, simlock) readed from the phone. but all fields are crypted? is there any possibility to decrypt this stuff? http://www.klar-im-kopf.de/martech.jpg steinchen0815 |
unlock functions are still only available if you have the box ... ! :-( http://sp.izhevsk.net/Martech_siemes...39_cracked.zip |
is it possible to unlock phones with this cracked version WITHOUT the proper box?? |
no, because part of the code located in the box. Dont try to unlock your phone with this software, if you dont have a box. Only flash read/write aviable! Firecell |
It is not even possible in most cases to unlock with cloned dongle it can drop out and kill phone |
where to get a "cloned" dongle ?? are such a dongle much cheaper? |
does read/write really work? If I do not want to unlock any code are you sure that writing of Flashes (they should be FullBackups then) and Eeproms works correctly ? So if I read out the flash and want to reprogramm my handy (because it crashed while trying to downgrade etc.) it works? Its the first soft I see supporting M55 without TestPoints! |
if no parameter is differt to the original, may be it works?! i donīt even try it ...... goog luck ;-) |
With M55 it not works correctly without BOX. Checked. |
please say detailed, what isnīt working with m55? is the "write flash" button not active? |
I killed M55 after read and then write the same flash.Dont know why:( |
Is there a working flasher for the m55 out??? Why not using Siemens Flasher 1.3??? You just need the correct addresses. Or is the flash-type of the M55 not supported ... ? |
what's the fact now ? M55 ... write flash button is there ... you maybe should use the load file button before ! But 1 killed his mobile with it, one said it's working. Anyone else who made experiences with the M55 ? Usually i'd expect it to work fine since writing Flash/Eeprom doesn't require the Box-Functions ! |
i kiler m55 with new martech software 3.9 .who can help me? |
