S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
05-22-2010, 04:54 | #556 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Jakarta, Indonesia Age: 49
Member: 90127 Status: Offline Thanks Meter: 1 | Is there any new solution for calculating the ESN and SKey for E71 beside buying the BootKey? I'm just curious about how can some forums been able to provide BooKey only based on the IMEI provided by the users. |
05-22-2010, 11:05 | #558 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: POLSKA Biesy... Age: 40
Member: 133762 Status: Offline Thanks Meter: 242 | Quote:
if I'm wrong someone correct me | |
05-22-2010, 11:10 | #559 (permalink) | |
First try with repair FuBu - from Landy site - there You will finde all files Index of ./downloads/ | |
05-24-2010, 06:00 | #560 (permalink) |
Member: 90127 Status: Offline Thanks Meter: 1 | It's not totally wrong, only it's not working for E71fw45. Problem is for this series, the ESN is 32-digit instead of 8-digit as other NSG. |
05-24-2010, 08:36 | #561 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 46
Member: 163721 Status: Offline Thanks Meter: 148 | the ESN is still 8 digits only the Skey is not longer needed (the BKey makes the Job out now) use your readed IMEI, HWID and ESN type 8 Digits in the SKey field then press Button "Calc HASH and BKEY fom ESN and SKEY" recalc with this keys a Fubu and Write it into the Phone |
The Following User Says Thank You to Gehstock For This Useful Post: |
05-24-2010, 09:33 | #562 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: indian ocean
Member: 320858 Status: Offline Sonork: 100.1602961 Thanks Meter: 25 | thanks Quote:
I didnt find Bcore or eeprom for s65 pliz share if anyone has. thanks. | |
06-11-2010, 20:48 | #563 (permalink) | |
Junior Member Join Date: Jun 2010 Location: Green Planet
Member: 1322831 Status: Offline Thanks Meter: 0 | Quote:
Just to make sure the neccessary tools are bsReader, x65PapuaSoft and DCA-110? Correct me if I am wrong... | |
06-13-2010, 07:29 | #564 (permalink) | |
Junior Member Join Date: Jun 2010 Location: Earth Planet
Member: 1323745 Status: Offline Thanks Meter: 0 | Quote:
Just to make sure, the beginning step is getting HASH and ESN by using bsReader, isn't it? After that key in this HASH and ESN into x65PapuaSoft_1.1.1. Please confirm me. Thanks for all. | |
06-16-2010, 14:26 | #565 (permalink) |
Member: 1323745 Status: Offline Thanks Meter: 0 | Hello Gehstock, ra1ex, BB-gsm and others...I need your support for the next steps. Here is my first step to calculate SKEY and BootKEY and change to Factory Mode for my E71v.37 : 1. Install bsReader to Data/Java/Applications on E71 using SiMoCo. 2. Run bsRedaer from Data/Applications from E71 and wait for few seconds and get HASH and ESN. 3. Run x65PapuaUtils_v111b. 4. On tabs Settings, click Information and I got information from Power On phone as below : Should I go to tab Codes and writedown (manually) the ESN and HASH, I get using bsReader? And what column do I have to click for the next? Thanks in advance for all of you. |
06-16-2010, 15:41 | #566 (permalink) |
Member: 163721 Status: Offline Thanks Meter: 148 | Tab "Flash"-> Check only Recalc All Keys-> "Button Do It" The Orginal Hash (readed with BS Reader) is not Valid for Calculation (Other Algo(No SKEY)) on All E71 and EL71 Sw Version >= 41 |
06-17-2010, 13:44 | #567 (permalink) | |
On Tab "Flash" I didn't find "Recalc All Keys" and "Button Do It". What I find is "Recalculate Keys" and "Do the Job!" I put check mark on : in Flash, in Bcore, 76,5008,5009,5077 and Master codes. Are they correct? Please see picture below : No Test Point neccessary, isn't it? | |
All about EL71 here and only here ! | pepik | S-Gold Based Phones | 221 | 02-06-2011 05:50 |
All about gsm unlocker for all phones download here | rahulk99k | The Market Feed Back | 1 | 01-31-2009 19:41 |
All About Spst Here. | Platijet | Sharp | 56 | 09-27-2007 18:22 |
ALL ABOUT lg 8380 -HERE ONLY | samirsana | VygisToolbox | 17 | 07-04-2005 11:04 |
