Any idea for EL71 dead after papuas 0.9.1.a Hi, this post is for all papuas users who could give me any idea about repair EL71 flash id FlashID: 0089,887E , specially for gehstock :) I have tried to extract hash by normal way and I got this message: Press Red key ! Autostart... ÜTransfer Boot... BOOT geladen... Pause 2 Sec... Getting Information..... FlashID: 0089,887E (64Mb) BCORE Clean ! OTP ESN: ABF6A044 OTP IMEI: 358941003027284 Teste Daten Bus D0..D15...OK. Teste Adressen A2..A22...OK. Lese EELITE Blöcke... EELITE Blöcke nicht gefunden! Lese EEFULL Blöcke... EEFULL Blöcke nicht gefunden! EEP Blöcke nicht gefunden! Boot ist open.. Es gab Fehler! then I have checked by error the "NEW BCORE V22,V11,V7..." option, the log is: Press Red key ! Autostart... ÜTransfer Boot... BOOT geladen... Pause 2 Sec... Getting Information..... FlashID: 0089,887E (64Mb) BCORE Clean ! OTP ESN: ABF6A044 OTP IMEI: 358941003027284 Teste Daten Bus D0..D15...OK. Teste Adressen A2..A22...OK. Lese EELITE Blöcke... EELITE Blöcke nicht gefunden! Lese EEFULL Blöcke... EEFULL Blöcke nicht gefunden! EEP Blöcke nicht gefunden! Lese Segment A0000000 BCORE... Segment BCORE gespeicher ABF6A044_A0000000_BCORE_061127142617.bin Neue BCORE Version: "main_1.0_V11 " Fehler err:FFFF ęîėāíäû įāīčņč ņåãėåíōā A0000000! Fehler beim lesen des BCORE! Bitte wiederholen! Falschen HASH eingegeben! Now, the EL71 is dead, no beep and no service mode, and I don't have much more options for repair it because I can't connect Any idea would be appreciated wbr thecult |
@thecult check X85 in BCORE Tab , then check only Pause 2s and do job, post result about Flash type is 100% supported by Papua 091 or higher for Unlock, repair BCORE not work yet |
2 Attachment(s) U can repair with this : Segment BCORE gespeicher ABF6A044_A0000000_BCORE_061127142617.bin Use Vklay and the s75 bkey Loader Start it with testpoint and write ur old bcore back then calculate skey and bkey send skey and make unlock over the buttons Freia.log or 5008 Unlock Lese EELITE Blöcke... EELITE Blöcke nicht gefunden! Lese EEFULL Blöcke... EEFULL Blöcke nicht gefunden! EEP Blöcke nicht gefunden! this is normal for this phone papua can t read the eeprom on x85 devices i work on it In this Version Check Boot Type all not working functions for x85 are disabled |
hi... thanks! , but how can I calculate bkey and skey ? paupuas can't extract hash! wbr thecult |
use midlet i think ur sw is over 38 but this is not supported for now |
check X85 in BCORE ____ |
@bourri gsm: really thanks but x85 checked @gehstock: thanks but phone can't turn on, can't use midlet wbr thecult |
xtrange thing: now I can get "pause 2 sec" withouth making tp ... how??? its impossible, tp is clean and board is clean |
ur Bkey is in PapuaUtils on the keys/Schlüssel Tab |
thanks gehstock but bkey field only shows "?" I have entered manually "12345678" in skey and generated has with it, then I have generated bloader for vklay and flashed bcore backup... all fine and now my phone works :) but I don't know how to unlock , because I can't read bkey until now... can I use bkey generated with "12345678" trick for unlocking phone or I will kill it? thanks , really thanks wbr thecult |
is the phone alive then send skey and use button "5008 Unlock" |
can you tel me how to fix my bcore i have a backup but i dont know how to repair with v-klay i have v-klay3.0 |
@gehstock: but my problem now is when I send SKEY, phone doesn't change to factory mode, then I try to unlock 5008 without success |
for more information: I have tried also with bsreader and x65flasher (tried to read hash) ... both gives me hash: FFFFFFFFFFFFFFFFFFFFFFFFF I can't get valid skey |
