Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 06-02-2006, 18:13   #1 (permalink)
Member: 287011
Siemens BenQ S68 unlock
Hi@all,
i've got an swizerland Siemens-BenQ S68 but its simlocked.
I've spend hours for searching a Tool, but can't find anything. Please help me,
thanks, Richard.
p.s. sorry, my english is bad... :-)
Old 06-03-2006, 10:30   #2 (permalink)
Axe Man's Avatar
Member: 221472
Thanks Meter: 8
Papua Utils will be helpfull.
Old 06-06-2006, 19:15   #3 (permalink)
Member: 289371
Originally Posted by richie_180781
Hi@all,
thanks, Richard.
Hi users !
Me from Germany and i have the Same problem whit S68 !
but cant stand (Papua Utils will be helpfull) , what is this ? is this a programm ? wo kann i download it ? pls help
Old 06-06-2006, 20:03   #4 (permalink)
Moderator
taoufik.om's Avatar
Member: 247448
Sonork: 100.108039
Thanks Meter: 2,099
Thumbs up big thanx to : gsm4maroc
Hi@all,
thanks, Richard.
use papua soft
test point :
Old 06-07-2006, 19:40   #5 (permalink)
Member: 289371
use papua soft
test point :
hm sorry dont stand !
Old 06-28-2006, 13:09   #6 (permalink)
Member: 198780
Originally Posted by taoufik.om
use papua soft
test point :
Are you sure that the testpoint is correct, i've problems with s68, the conection (with datacabel) is ok but papua says testpoint ist not conectet, but i am sure that the tespoint ist 100% connected.
Old 06-29-2006, 12:15   #7 (permalink)
Member: 10994
Thanks Meter: 3
TP must be connected to + ~2,9V (example to Vbat (4,3V) by 2 diodes 1N4148). It's working OK.
BR, Lukago
Old 07-10-2006, 18:19   #8 (permalink)
Member: 198780
thanks for the answere i'll test with the next device.
hope to get a s68 sone.
Old 07-11-2006, 22:04   #9 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,171
@Giggione Man go to an unlocker if don't understand Tp or Papua utils it's a little complicated for you and you have to open phone also.
Old 07-12-2006, 07:10   #10 (permalink)
Member: 35048
Thanks Meter: 17
Make TP at S68 and with Papua Utils do Unlock.
Old 04-11-2007, 15:42   #11 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
Anyone can throw some light on S68 TP..
i want to ask how to connect TP using two diodes and +2.9v ..
More precisely.. which end of diodes should go to TP and which end should be connected to voltages ??
I wish to unlock a S68 v32.
IF it can be done with MIDLETS then x75v1 midlet will do the Job ???
BUT again prob is - for MIDLET i ve not got the usb cable.
Old 04-11-2007, 16:09   #12 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@i_seeque
i never used usb cable for send midlet in any Sgold
we can use normal serial cable.
tp i think here is clear image
NOT TESTED ANY S68 TILL NOW
Old 04-11-2007, 21:37   #13 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
Originally Posted by stanner_austin View Post
@i_seeque
this testpoint works, but you must use a diode to contact this two points!
no diode = no testpoint
The Following User Says Thank You to oOXTCOo For This Useful Post:
Old 04-12-2007, 08:07   #14 (permalink)
Member: 49752
Thanks Meter: 6,085
@oOXTCOo
sorry but i can't see your image correct becuse red can't be read correct
hehe
diode.
which one?
n4148?
Old 04-12-2007, 18:09   #15 (permalink)
oOXTCOo's Avatar
Member: 2878
Thanks Meter: 9,123
@oOXTCOo
hehe
diode.
which one?
n4148?
yes, use N4148 or similar.
the only inprotent changes in the picture is the diode,
this you can see correct even in red color.
the other text in red is only my website adresses ;o)
Benq S68 unlock code gsm9l Phone Unlocking Codes & Maps 0 08-03-2009 09:09
siemens-benq A38 unlock bessem NON Siemens Brand (ODM Phones) 12 02-14-2007 09:45
siemen benq s68 dead with papua indian mobiles Siemens Hardware Repair Area 3 02-07-2007 08:10
>> Siemens-Benq AL26 Unlocked 100% << GsmTower DreamBox 3 12-27-2006 16:43
Siemens-Benq cf110 unlock 100% without TP Halas DreamBox 9 05-03-2006 16:30
Page generated in 0.23939 seconds with 10 queries
