S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here. |
01-08-2010, 10:54 | #1 (permalink) | ||
No Life Poster Join Date: Apr 2009 Location: Attock Pakistan
Member: 1002064 Status: Offline Sonork: 100.1594824 Thanks Meter: 131 | C72v Dead after Unlock Quote:
Coz keys are already calculated. it gives Error on this stage. Quote:
01-08-2010, 13:23 | #3 (permalink) |
Member: 1002064 Status: Offline Sonork: 100.1594824 Thanks Meter: 131 | with TP error BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0001,227E (32Mb) ...(amd) C72V SIEMENS 357364005018980 HASH: 72EC63D6118BB42A63CA48C420F43FD7 OTP ESN: 1E8F62EB OTP IMEI: 357364005018980 Established speed 921600 Baud. It was BCORE version: "main_1.0_V26 " Write BCORE version: "main_1.0_V26 " No answer to command to receive data A0000000! Error writing segment BCORE! Try again ! |
01-09-2010, 20:39 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
You make, manny,manny wrong steps. To solve: First, you need to set baudrate of COM to 115200 bauds, not to 921600 Second, if you use the AllbugsGold procedure, you NEVER connect to your phone with the normal way....only with TP. So, download X65flasher, one good fullflash of Siemens C72V phone (for AMD flash) and papuautils 1.1.1c. - start x65flasher with the DOS command "x65flasher /b" (enable bootcore writing). - connect your phone, set baudrate, COM and testpoint option. - click on Connect, make testpoint, push shortly on the phone red button. - after ignition, disconect testpoint (have 3 seconds). On the down part of window you will see C72 bootcore identification. Now click on Flash button, load fullflash file (from where you saved) and click on OK. Confirm the bootcore writing and wait...40...50 minutes After finishing, close x65flasher and open papuautils. Go to Flash menu, set COM, baudrate. NOW CHECK ONLY ??????OTP, Recalculate Keys - in Flash (automatically is checked other 3 options) and Pause. NOTHING ELSE!!! Click on Do the Job! quicly make testpoint and push on the phone red button. See on the right window, disconnect testpoint and wait to finishing (2 minutes). Now close papuautils, disconnect cable and...power on your phone If you make exactly the all steps, your phone start and working. That all! dagos | |
01-10-2010, 11:18 | #5 (permalink) | ||
Member: 1002064 Status: Offline Sonork: 100.1594824 Thanks Meter: 131 | Quote:
here is log Quote:
01-10-2010, 13:31 | #7 (permalink) | |
Member: 1002064 Status: Offline Sonork: 100.1594824 Thanks Meter: 131 | yes confirmed followed 100% ur steps. even run x65flasher with cmd with /b switch. but log is same. Quote:
01-13-2010, 04:22 | #8 (permalink) | |
Inside in your phone you have the AMD flash chip, not Intel. You have two choise: 1. Replace your flash chip with Intel flash 2. Find fullflash file for AMD, not Intel dagos | |
The Following User Says Thank You to dagos For This Useful Post: |
04-30-2011, 11:28 | #12 (permalink) |
Member: 416908 Status: Offline Thanks Meter: 398 | |
04-30-2011, 15:01 | #13 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Many many thanks to dagos Now my phone alive, and it's my first success story of S-Gold Based Phones Code: Checking value of SKEY from page "Codes"... Auto Ignition... Boot not loaded! Boot released. Checking value of SKEY from page "Codes"... Auto Ignition... Transfer boot... BOOT is loaded... Pause 2 sec... Getting Information... FlashID: 0001,227E (32Mb) CFI: 3 : 4*32768, 254*131072, 4*32768, C72 SIEMENS 357364003108007 HASH: 6137E167F38AFD3F59192107BBE5C2DB OTP ESN: DDEBF59D OTP IMEI: 357364003108007 Established speed 921600 Baud. Bcore R65 series found Reading of segment BCORE... Search of a segment EELITE... Search of a segments EEFULL... Find blocks: 52,76,5008,5009,5077,5121,5122,5123 In total EEP blocks: 233 SKEY in block 5122 = "X" 58522621 BKEY in block 52 = B4483FA92380092FBFC20CE83C7CE37F Replacement of blocks EEPROM in the buffer ... EEPROM: Block 76 does not require replacement. EEPROM: Block 52 does not require replacement. EEPROM: Block 5009 does not require replacement. EEPROM: Block 5122 does not require replacement. EEPROM: Block 5123 does not require replacement. EEPROM: Block 5121 does not require replacement. EEPROM: Block 5008 does not require replacement. EEPROM: Block 5077 does not require replacement. Work with BCORE in the buffer ... BCORE: HASH does not require replacemen. BCORE: IMEI does not require replacemen. Boot released. Everything is closed.! |
Nokia 2720 dead after unlock | unlocklleida | Cyclonebox | 3 | 03-31-2010 17:25 |
help urgently G1157 dead after unlock.. | razisamb | FuriousGold | 4 | 03-29-2010 15:38 |
***k608i dead cid 37 dead after unlock*** | zaccoyne | SonyEricsson (USB-Smart) | 4 | 04-21-2006 12:21 |
GD93 Dead, after unlock ON but after some time again Dead... | DrMobile | Panasonic | 1 | 02-14-2002 10:16 |
3310 Dead after Unlock then Alive after Upgrade | ed2k_7 | Nokia Hardware & Hardware Repair | 5 | 11-08-2001 21:21 |
