GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   S-Gold Based Phones (https://forum.gsmhosting.com/vbb/f340/)
-   -   cx65==>cx70 how to (https://forum.gsmhosting.com/vbb/f340/cx65-cx70-how-207461/)
japunlock 05-19-2005 16:24
cx65==>cx70 how to
plz can someone tell me how to make the conversion???
Orpheus255 05-19-2005 17:07
Copy a FF from CX70 to CX65 and unlock
brandiber 05-19-2005 19:01
Use x65 Flasher 1060, generate boot password and use "Advanced" > "Change phone model"
Afterwards you'll be able to update and map with CX70 Firmware and mappings
Ilvio 05-19-2005 19:18
so, you need to downgrade your cx65 to fw25, generate bootpassword, change phone model, update with cx70's firmware, make a ffsinit and a map? only?
please show me what's a map! i'd glad for this, please!
arrowz 05-20-2005 11:01
is the PTT and 3D will work?
brandiber 05-20-2005 12:24
PTT won't work for your provider until you map your mobile...
maps are provider dependent preferences you transmit via mapr65 or Acid mrp's map65.
the latest mappings for your softwareversion (the jounger the better :)) can be found on http://allsiemens.com/flash/
map65 you'll find on http://www.gsmdev.de
So first of all
1. change phone model on your x65 with SWV <36
2. perform FFSInit for the desired phone model before you update (to avoid problems with your filesystem)
3. update with winswup update of the desired phone model (answer the "phone-model-change-dialog" with yes)
4. map your mobile with map65 by Acid[mrp] (write Standard map first and then write your provider's map to your phone)
5. if you want to change phone model in status-monitor do the following (*#06# > More: "Product")
Read your phone's flash with the following preferences (x65 flasher)
from 80000 size 20000 (128kb)
go to adress FD04 of your readed flashblock and reverse the folowing three bytes in order to get an firmwareaddress. For example you get 88 FD 09 (88 is address FD04). Reverse the bytes (always two digits): 09 FD 88 > this is the firmwareaddress where product is stored so we edit our read flashblock and rewrite it to the phone (cause 09 FD 88 is in our flashblock... otherwise you'll have to repeate read-process with new firmwareadresses and size)
so we go to 01 FD 88 of our Flashblock (09FD88 - 80000 = 01 FD 88) with our hexeditor.. some addresses before you'll find your Product (example CX65.1.0 or CX6V.4.0 or like that) so we change this to the desired phone model and flash the modified flashblock back to our phone (in our example from 80000 with size 20000... of course! If you are not sure, create a fullbackup before you write anything wrong to your phone!!)
Now *#06# > More > Product is changed, too
PYCON 05-20-2005 14:09
What are the advantages of this conversion? :confused:
brandiber 05-20-2005 21:44
Push and Talk (walkie talkie) function
japunlock 05-21-2005 16:50
So first of all
in english please
just kidding can you plz explain a little further especially the part of product change
brandiber 05-21-2005 17:15
Where are your problems? Don't know how or where to explain it more explicitly :)
tccat1 05-22-2005 10:23
hello need a little more help on converting my cx65 my sw version is 14 at the min has any1 got a good online russian web page translator many many thx
Sigma 05-22-2005 10:42
and what about c70 to c65? is it also possible?
brandiber 05-22-2005 16:33
I don't think, that conversion from c70 to c65 is possible... except you have a softwareversion <36
tccat1 05-22-2005 16:53
cant see why u would to go from cx70 to a cx65 as i thought the reason from goin from cx65 to cx70 is just to get the ptt function ?????
brandiber 05-22-2005 17:09
@tccat1
What is your Problem with my tut.. maybe i can help you with some details
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.13690 seconds with 6 queries
