Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 12-12-2005, 09:31   #1 (permalink)
clinic*mobile's Avatar
Member: 20833
Thanks Meter: 5
Exclamation sl65 v50 test point power off
i want to unlock sl65 v50. i used sst cracked not connect only when power on connect and dont read data i used with test point but not connect and sl65 was power off
i tested with Papua v038_Eng read all data without test point but dont unlock and dont support v50 when i used test point not connect and dont read
can i downgrade to v12 then unlock this?
if no how unlock sl65 v50
i read old post but can not help me
Old 12-12-2005, 10:39   #2 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
Write log here,
Write all info you got without testpoint with Papuautils !
Old 12-12-2005, 15:59   #3 (permalink)
Member: 20833
Thanks Meter: 5
ieo÷åieå eioidiaöee:
Model: SIEMENS SL65 50 lg4
Telephone in "Normal Mode"
IMEI: 354220007088905
SecurityStatus: CustomerMode
HWid: 324
Battery voltage 3936 mV.
Error jump to mode BFB!
Reading keys supported up to version 36 !
Old 12-12-2005, 16:16   #4 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
Now I see u have never unlocked any with papuautils
It is not as easy as C35 unlocking with one button pressing (OpenALL in ur case)!
You have to read keys, save log, convert log to map, open map with eeprom tool and write it
Regards,
B
Old 12-12-2005, 17:05   #5 (permalink)
Member: 20833
Thanks Meter: 5
i know that it not easy.
do i must do with test point or without test point?
Old 12-12-2005, 17:21   #6 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
Read keys with TP(time is critical here), the rest without !
Old 12-14-2005, 08:32   #7 (permalink)
Member: 20833
Thanks Meter: 5
thanks my problem sloved for all member go link:
http://forum.gsmhosting.com/vbb/show...58#post1481158
can i unlock z-6 without test point. saniamirza MSS Box II 1 03-29-2010 21:06
K750 Power Off After Test Point E_TEC SETool2 1 02-08-2008 08:09
LG3G eXsecute Clip unlock without test point £10 off for platinum clip user datacablelondon Data1 Team Products 0 03-03-2006 02:25
SL65 power off when slide is closed ... dghersin Siemens Hardware Repair Area 0 06-23-2005 21:47
V50 test point kisa55 Motorola Old Legacy (EMMI) 3 03-26-2003 21:50
Page generated in 0.19823 seconds with 9 queries
