STEP by STEP of X65 Imei Change by Trixxi3 4 Attachment(s) STEP by STEP of X65 Imei Change by Trixxi3 Preliminar: - This works on phone versions <36 - After this you canīt upgrade with WSUP/Update, youīll lose your new imei. - After this you canīt unlock with any soft, youīll lose your new imei. - After this you can change ffs. Correct way. 1 - Downgrade with any way to <36 version. 2 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode" 3 - Go to "Codes" and press "Auto Open All" 4 - Go to "Flash", mark "Pause" and "New BCore V22" 5 - Press "Do Job" and wait for finish. 6 - Turn Off mobile if not auto off. 7 - Go to "Settings" and press "Service Mode" 8 - Go to "Flash" and mark "Recalculate Keys in Flash" (two more options will be auto mark, all itīs ok) If any advice of Wrong entry appear return to codes section and fill Skey and Bkey with any numbers. 9 - Press "Do Job" and wait for finish. 10 - Go to "Settings" and press "Service Mode" 11 - Go to "Codes" and press "Auto Open All" 12 - Press "Freia.log" and save file with any name, but remember this name later :) 13 - Press "x65flasher.ini" and save file in x65flasher dir. 14 - Open x65flasher.exe and Press "Connect" 15 - Change "Leght" to 40000 and Press "Read Flash", save file 16 - Open SSWx65.exe and write your ESN, calculated by Papuas, Inverted in "Phone Id" EX: In codes section of Papuas you get ESN: A1B2C3D4, then write in "Phone Id" of SSWx65.exe in this way: D4C3B2A1. 17 - Write new imei in "New phone Imei" and Press "Dissable OTP", select file saved in step 15. 18 - Save file. 19 - Open x65flasher, select Leght to 40000 and Press "Write Flash", select file saved in step 18. 20 - Press OK to Skip Write BCore confirmation. 21 - Open mapper.exe, select log file saved in step 12, write imei of step 17, MUST TO BE THE SAME! 22 - Open x65PapuaUtilsV038d_ENG.exe, Press "Service Mode", Go to "Codes" and press "Enter Skey in Phone" 23 - In right window must see "Telephone in Factory Mode" 24 - Open Siemens EEPROM tool.exe, Press "Init", Press "Load" and select map file saved in step 21, Press "Select All" in left side, Press Right Arrow, Press "Select All" in right side, Press "Save Selected". 25 - Turn OFF your mobile, and turn ON again for confirmation of new Imei. GOOD LUCK. PS: Sorry my bad english and thx to all people involved in development of all aplications used in this Step by Step. WBR Trixxi3 |
Hello to all, the same software q is for the change of IMEI of the C65 it will also be good me for the same thing in the C66? |
you have described the whole operation in 25 steps but it takes approx 3 minutes to do it :) but after some practicing ;) also without using papuasutils. Regards |
i will try it at weekend.thnx for sharing.. regards; maxijazz |
Can you tell me, is this solution change that IMEI, who is sent to GSM network or only visible IMEI seen as *#06#. |
Cell-manager: I have not tried in C66 :( , but I think youīll havenīt problems. surfman: both! Good luck and best regards. |
100% works on c65 and it's simpe 10x Trixxie |
tested on c66 it works but no need for me just for practicing |
i tested today on c65 v25 - work ok :) Thanx Trixxie! |
great Trixxxie , good info next task... we only have to decode tochogordo1 and tochogordo2 :) :) :) see u |
HEHEHEHEHEHEHEH! Thatīs right. Still undecoded? did you leave that investigation? Best regards. |
still in project trixxie! we have developed few apps for doing it more easy, next time we talk I will explain u ... but this project will finish, sure. :) nice to see u |
Many thx Trixxi tested S65 , phone working now without any problem |
hmm so I'm the first one who killed c65 :) maybe I've done sth wrong I will do it again :) and try to ressurect that phone :) |
