x65 repair solution i have one c65 dead after wrong unlock is there any solution to revive no-patched phones thank u for help |
put to service mode,pull cable out . phone will be in service mode so you can make all unlocking/repairing |
now with free software can't do that because you can't write the 4 blocks on eeprom that is imei. with martech box 2 with x65 update can be possible revive the fone. |
gain more info from forum before start to explain me |
use martech its the best for this |
i have the same problem, but with c65 v25 dead. and dont have the bootcore patched. how can solve the problem? |
Use Acid's Unlocker or as mentioned Martech/SST |
sst solution works,and it is not expensive |
just read my first post in this topic. all is explained what else you need ? to explain all from A to Z ? why you all stuck here on java patch sol ? |
you can be more explicit? Leslie_B. thanks |
hello every body i have a problem with cx65 v12 i used "Unlockx65ed1" soft and the phone only make a buzz. don't know solution tryed the' tornado soft but don't work .please help. |
anyone can send me the software SST SERVICE TOOLBOX V 5.20, please. thanks |
@cacau Joking? :D Without patched bootcore or generated papuas keys, you won't be able to repair phone. Except you are using SST Logger (10 Logs free at the moment). But I doubt that you'll be able to repair your phone with the logger if you destroyed EEFull Blocks 5121, 5122, 5123 |
See SST's web page please! regards yaren |
