All vkp put into a bin file 2 Attachment(s) Use [adir] for ADD directory. Then all vkp file will be list. Click item will display its description. Del key will delete file. In file list box located on right top, double chick item will start file. Other list box will delete interrelated file. F6 for rename file. [all put] will put all vkp data for flash file in directory what program in, and create a new patched file in sub directory. If have same adress in the files data, next file will overwrite front file's data. If you modified some vkp file's data, reload program if you want collect adress again. The software provide that integrate vkp patches into a bin file, it can't check patch file's error, but can show used adress of patches. Before click [all put] button, make sure that all listed files are suitable for you. Thanks all friends who help me for learn to modify flash for some mobile phone. WWSSFF from http://bbs.0110.cn 2006.03.15 Another one is turn vkp file into bin file, vkp file adress must at 0x08XXXX, it is first ram adress. It can use at command prompt, such as: >VtoB try.vkp Will create try.bin file. If file sfe.exe in the directory, It even can turn asm file into bin file: >VtoB try.asm But this function work is not well, please wait a second before chick 'OK' button. |
Very, very great tool ! Thank you all ! |
not understand for for what it.... |
one put all paches into a file such as v56.bin, another one can make XXX.bin file as XXX.com of computer. |
why not v_klay? .... |
First use this software put all vkp into a bin file, next use v_klay put pathed bin file into mobile,you will fast modify you mobil. |
V_klay can worked with fullflash.... |
Software shows all conflicts and works good ! |
It works very good ~~~~ |
