01-20-2003, 01:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Flash Patching: Create New ShortCut (Inbox and Outbox) anybody using SL45 v56 who need shortcut for Inbox and Outbox SMS (located in the SIM Card), just follow this patching action (using your full-flash file) : *) Patching for Outbox (overwrite 'Conceal ID' shortcut) : 0x18E38A : 49 ==> 92 0x18E3BE : 4A 01 ==> 69 00 0x18E416 : 49 01 49 01 ==> 92 01 92 01 0x3AE308 : DA DA 04 A3 ==> DA D9 F8 0A remark: 0x18E38A is address in the full flash file, 49 is the original value(s), and 92 is the new value(s)... *) Patching for Inbox (overwrite 'Profile' shortcut) : 0x18E3AC : 2A 08 ==> 5A 03 0x18E3E0 : 0B 02 ==> D3 00 0x18E524 : 2A 08 2A 08 ==> 5A 03 5B 03 0x3AE412 : DA DF 94 4C ==> DA D9 EE 0A Good Luck, RizaPN Last edited by rizapn; 01-23-2003 at 04:23. |
01-21-2003, 01:35 | #3 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @Proggy: Sorry, but I will concentrate more in the patching, not in the flashing anymore (we already *have* UniSiemens, and I think it is the best flasher). @All: For fast modification, if there is no full-flash yet, just download the flash from address 0x180000 with size 0x10000 and from 0x3A0000 size 0x10000 (partials). Name the first one as sl45_18.bin and the 2nd as sl45_3A.bin Addresses to be modified from file sl45_18.bin is : E38A, E3BE, E416 (for outbox), and E3AC, E3E0, E524 (for Inbox). Address to be modified from file sl45_3A.bin is E308 for Outbox and E412 for Inbox. After the modification, upload sl45_18.bin to the phone at address 0x180000 with size 0x10000, and sl45_3A.bin to 0x3A0000 size 0x10000. RizaPN Last edited by rizapn; 01-22-2003 at 09:52. |
01-21-2003, 21:13 | #4 (permalink) |
Insane Poster Join Date: May 2002
Member: 12263 Status: Offline Thanks Meter: 1 | RizaPN i have made your modifies! U are great! and a very good searcher of mistery of flash!:-) There is something "wrong" that i want to say u.... The message when i select "Incoming message" is "Start: Conceal ID"..... is the option overwritten i know....but can be modified and point to correct string....? I have only a new voice Incoming msgs so i think a little error in write bytes in your post, perhaps this.... 0x18E524 : 2A 08 2A 08 ==> 5A 03 5B 03.......? can be new values: 5A 03 5A 03.......? Another very interesting thing.....that perhaps depends of something wrong byte..... after change when i push number 9 now i shortcut to calendar like pushing number 2..... so in this part of flash (tables?) these bytes seem to set also option phone numbers.... Always more interesting!!! |
01-22-2003, 01:22 | #5 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @Wind: Is your flash v56? I can not reproduce your problem in my own SL45v56. Do you mind to explain it more detail, so I can check it with my own? ps: - 5A 03 and 5B 03 is pointing to the same string (Incoming msgs and Incoming<0D>Message) NEW PATCH (still for SL45v56 *only*) : Eliminate the additional "_nnn_nnn" string when we move SMS to the archive folder 0x39FE5C : 88 60 F0 C8 ==> FA D9 02 FF Good luck, RizaPN Last edited by rizapn; 01-22-2003 at 09:59. |
01-22-2003, 16:48 | #7 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @SL45_6688i: *) I'm not masters. *) Please read my reply in your mailbox... New Patch. >>>Get access to "SIM Location" directly using front UP Arrow key<<< original: 0x3B0366 : EA 20 3C 04 48 C3 EA 20 0x3B036E: 3C 04 46 FC 20 00 EA 20 0x3B0376 : 5A 04 48 C6 EA 20 82 04 modify to: 0x3B0366 : 2D 6A 48 C3 2D 68 46 FC 0x3B036E: 20 00 2D 74 48 C6 EA 20 0x3B0376 : 82 04 46 FC 21 00 2D 7E original: 0x3B0474: E0 0C E0 0D E0 0E DA D4 AC 70 modify to: 0x3B0474: DA DB 3C EF 0D 02 DA DB 46 EF Good luck, RizaPN |
01-22-2003, 20:58 | #8 (permalink) |
Member: 12263 Status: Offline Thanks Meter: 1 | Hi RizaPN i have made a mistake sorry!, your solution is good! I hadn't overwritten the byte in the first offset 18E38A! Works very well now! But now i want to patch in your second way, it is the best solution i think! Thanx! Wind |
01-23-2003, 01:01 | #9 (permalink) |
Major Poster Join Date: Jan 2002 Location: Poland
Member: 9095 Status: Offline Thanks Meter: 0 | RizaPN, you are really great! Could you please patch flash to eliminate that annoying playing ringtones at very low volume level and then raising it, even if the volume is set to max? |
01-23-2003, 10:27 | #10 (permalink) |
Member: 12263 Status: Offline Thanks Meter: 1 | If can help i have recently found that settings volume are in Fullblock 5011 (no explanation about this block in InitMap), i have made some changes but not good result yet Wind |
01-25-2003, 01:46 | #11 (permalink) |
Junior Member Join Date: Jan 2003 Location: Washington
Member: 20338 Status: Offline Thanks Meter: 0 | Hi guys, Rizapn, You're a genius!! your ideas are magnificent!! Can you pls. tell me or give a link on PROGRAMS that will be used in these PATCHES and modifications that you created? Please reply coz i'm very interested to modify my phone!! unisiemens? flashers? Pls. give the software, all of them to create these mods!! pls..... |
01-25-2003, 02:05 | #12 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @r4rosal: 1) Please read old posts about read/write flash from/to the phone. 2) Please be very carefull while doing these activities. It can kill your phone, if you don't really know what's going on. 3) OK. Use UniSiemens or any other SL4x compatible flasher to read your flash, use hexa editor, such as WinHex, HexEdit, UltraEdit, etc to modify your binary flash file, and use UniSiemens again to write it back to your phone ... RizaPN |
01-25-2003, 21:33 | #14 (permalink) |
Major Poster Join Date: Nov 2002 Age: 46
Member: 17718 Status: Offline Thanks Meter: 0 | Callin icon....!!! hi guys , i have a problem with my siemens sl45 mobile when i make new entry in my address book with mobile , office, and home telephone for a person , then when this person ring on my mobile the phone dose not give me any icon or any sign to show me from any of theses phones he is calling ( i do not know if he is calling from mobile or office or home) this is very stupid thing in my mobile which disturbing me a lot and every time i think that siemens will correct this in the new firmware but this not happened. and do not tell me i have to put a new entry for each number for the same person(so why they do the multimedia card with these all options???!!!!, all other mobile (nokia or samsung or alcatel ) show u an icon to know from which phone the person is calling so why siemens dose not correct this stupid defect in thier mobiles ??!!! i know all of u have the same problem with ur siemens SL45 so if u can find away to correct it may be by editing some values in the bin file or firmware using hex editng programs , can u do it , u really do a very good work before by editing the bin file with the values u put here i got many usueful needed functions in my mobile (inbox and outbox shortcuts) and others .... so can u do it for the problem i have mentioned ???? u will be great |
01-26-2003, 15:15 | #15 (permalink) |
Member: 20338 Status: Offline Thanks Meter: 0 | hI gUYS! Can anyone please tell about START ADDRESSES and how to get them? also the SIZE of FLASHES, how do you get them? I tried using FFmodifier by RizaPN, i've modified some images and saved them as fullflash and partial flash. problem is i don't know the addresses and sizes to flash these files to the fone. do i need some table or calculator to know the size and address? Anyone please HELP!!! Rizapn i know you could give us some tutorials with hex editing and flashings and patchings!! Please help us!!!!!! |
how create a shortcut | xcit | Chinese Models & Cloned Phones | 1 | 09-07-2009 23:54 |
A60 bzzz and switches off when trying to create new sms... | Burnt Cobba | E-Gold Based Phones | 3 | 10-08-2007 04:48 |
help on creating new flash file for nokia dct4 supporting a new languge | greeni222000 | GSM Programming & Reverse Engineering | 0 | 01-14-2006 19:30 |
about flash patching: | zdob | x1x to x45/x50 | 2 | 06-07-2003 19:36 |
How to create a 5210, 3610 and 3350 option to flash the phone in a Dejan Flasher 2.15 | hooi76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-20-2002 09:40 |
