12-21-2005, 15:04 | #1 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Bangkok Thailand Age: 43
Member: 114558 Status: Offline Thanks Meter: 4 | How to modify this patch for not vibra when connect. Quote:
Help me please. Thank you vert much. | |
12-22-2005, 01:05 | #3 (permalink) |
Member: 114558 Status: Offline Thanks Meter: 4 | Default for this patch is 3 times(0x27E6C1: FF 3C). So i changed to "0x27E6C1: FF 0C" but phone vibra 1 time at outgoing call is connected. I'm not want vibra in both outgoing and incoming call,when connected. Help me please. Thank you very much. Last edited by ^NaT^; 12-22-2005 at 16:13. |
12-22-2005, 08:49 | #4 (permalink) |
Junior Member Join Date: Apr 2005 Location: Sosnowiec, Poland Age: 47
Member: 141416 Status: Offline Thanks Meter: 0 | Hello, I got the same problem with this patch. Setting 0x27E6C1: FF 0C is not enough. The only way to skip vibra when connected is to turn vibra flag off completely :-( But I want vibra when ringing and don’t want when connected. Could someone modify this patch, please? |
12-22-2005, 09:15 | #5 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Code: ;------------------------------- ;#name VWC. Vibra When Connected ;------------------------------- org 0dac4c8h ; orig mov r12,r8 & mov r13,r9 calls vwc_setCounter org 0dac51ch ; orig mov r12,r8 & mov r13,r9 calls vwc_main org 0c7e6c0h vwc_setCounter: mov r12, #3 jmpr cc_UC, vwc_exit vwc_main: extp #pag(VWCRAM), #1 mov r12, pof(VWCRAM) jmpr cc_SLT, vwc_exit2 calls cekVibraFlag jmpr cc_Z, vwc_exit2 mov [-r0], r12 calls doVibraOnce mov r12, [r0+] sub r12, #1 vwc_exit: extp #pag(VWCRAM), #1 mov pof(VWCRAM), r12 vwc_exit2: mov r12, r8 mov r13, r9 rets |
12-22-2005, 18:46 | #7 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | Or try other recording patch by rc-flitzer (this uses midlet to start dictaphone but works also very well). I use this version so I don't need the VMC Patch Sorry Nat and Sutek for my reply - I just reed the patch instructions but didn't test it |
12-24-2005, 02:24 | #9 (permalink) | |
Member: 114558 Status: Offline Thanks Meter: 4 | Thank you very much for all solutions. I'll try it. Quote:
Merry Christmas. @all Merry Christmas. Last edited by ^NaT^; 12-24-2005 at 02:43. | |
I have combo cable for E210, how to modify this cable for B320. i want pinouts | IkaMazini | UST Pro II | 2 | 12-04-2008 21:24 |
How to modify USB cable for unlocking NEC E616V? | zhouxing | NEC | 6 | 01-06-2005 22:37 |
how to Modify Small box for external power ? | shakeelajmal | Redbox | 7 | 11-18-2004 16:00 |
how to modify a cable for A300 Unlocking ? | the_frightener | VLSI, Conexant, Skyworks and Old Models | 2 | 03-18-2004 19:36 |
how to modify a cable for A300 unlocking with Padref ??? | the_frightener | VLSI, Conexant, Skyworks and Old Models | 0 | 12-17-2003 16:13 |
