06-24-2004, 18:36 | #271 (permalink) | ||
No Life Poster Join Date: Nov 2002 Location: INDONESIA
Member: 17360 Status: Offline Thanks Meter: 1 | Quote:
simply load the language pack 128KB .BIN file, and set addr: 0x5A0000 and size: 0x020000. You do not need to set the "buffer of program" because this option is only used if you need to write some part of loaded file. And for this case, you need to write all 0x020000 bytes file into your phone (or your fullflash file). Quote:
06-24-2004, 23:05 | #273 (permalink) |
Insane Poster Join Date: Dec 2003
Member: 46833 Status: Offline Thanks Meter: 0 | thnx alot KotSk it worked fine...i never knew that the developer menu cud also be tweaked!(are u "YudiYaN" from club-siemens.com?) ok i wanted to know if the following patches can be found for fw10 ;*** Remove access to grapchcache v3 *** © !Freeman!( i think this will help in turning mobile on and off faster riite?...without those animations?) and the patch of 3.625MB for fw10 is not there...i already put 3.75MB patch but i have to have T9, so i wanted this patch..and wanted a way to put it without resetting whole fw? thnx alot all!! love this forum for patching bye |
06-25-2004, 01:12 | #274 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Pancevo, Yugoslavia Age: 40
Member: 55726 Status: Offline Thanks Meter: 1 | hello m8's... im officialy starting to freak out.... this is the second time this happens..... i download disk B full patch, do everything as it says and while uploading the file it just works blank for hours and hours , and first time i had to reflesh my phone . luckily now i didnt have to ...... what tha heck is wrong ???? any ideas http://www.marcus.7p.com/anyideas.jpg <-> screenshot |
06-25-2004, 02:20 | #275 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: www.SiemensXP.com Age: 45
Member: 49922 Status: Offline Thanks Meter: 0 | Quote:
Wow, you dropped the phone couple of times but the service center only replace your keypad???? what a strange! I guess the phone hardware has minor damage and should to be replace (not just the KEYPAD ) | |
06-25-2004, 03:31 | #276 (permalink) |
Member: 46833 Status: Offline Thanks Meter: 0 | Pak_tani...i guess u forgot to read my last post...i need the patch for fw10, not 11 and its not posted yet....please read my last post for more details..its i think 4 posts above this one.. thnx |
06-25-2004, 06:37 | #277 (permalink) | |
and if you look at the "M55 flash patching" ( http://forum.gsmhosting.com/vbb/show...917#post754917 ) before you made your post, you will found what I already posted M55 v10 : Increasing disk A up to 3.625 mb (SAVES T9 with one language, decreases disk B down to 64 kb) So? Have fun! | |
06-25-2004, 07:27 | #278 (permalink) |
Junior Member Join Date: Feb 2004 Location: Russia, Ulyanovsk Age: 38
Member: 55771 Status: Offline Thanks Meter: 0 | Here is English T9 http://forum.allsiemens.com/download.php?id=1637 |
06-25-2004, 08:00 | #279 (permalink) | ||
what version your f/w is? | ||
06-25-2004, 18:57 | #281 (permalink) | |
Insane Poster Join Date: Jun 2003 Location: Croatia Age: 60
Member: 30592 Status: Offline Thanks Meter: 0 | Quote:
06-25-2004, 20:32 | #282 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 69063 Status: Offline Thanks Meter: 5 | Hello @ all. I have 2 questions: 1. Any news from the PATCH FIX (sw11 drive a bigger) ? 2. Is there any way to bind a softkey while talking, to record the conversation. Cause the way to "Dicta. Phone" is very long and takes a lot of time. Thank you |
06-26-2004, 00:40 | #283 (permalink) | |
Member: 55726 Status: Offline Thanks Meter: 1 | Quote:
T9_Rus_680000.bin with Address: 0x680000 , Size: 0x20000 hope this is what u were asking for cheers m8 take care | |
06-26-2004, 12:11 | #284 (permalink) |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | About my own patch and V_Klay2.6? today i made one graphic patch from SPC2 and i applied it to my fone with V_Klay2.6 while i applied , V_Klay told me program will created new patch if i stilled applied my own patch and when i open new repair patch there is msg like this "!!!WARNING!!! DO NOT UNDO THIS PATCH, IF YOU MAKE SOME MODIFICATION ; OF PHONE AFTER APPLYING PATCH WITH NAME: ; ;__________________________ PATCH FILE NAME: __________________________ ; C:\Documents and Settings\???????\My Documents\pic364378.vkp" i doubt if i need to applied another new patch. Should i undo my own patch with THE REPAIR PATCH before or can i apply new patch without undo my own patch sorry for my eng |
S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 13:47 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
