05-31-2008, 08:58 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | c55 light blinks only I face this problem 2 times before. problem solved both times using JOCKER. but this time problem is not solving. here the logs ****** Joker Siemens EGOLD Phone Version 0.3.5.6c Inofficial opened. ****** ****** Friday, May 30, 2008, at 23:33:52 ****** Start... Loading ServiceBoot... Sending ServiceBoot Ok. HWID: 130 (C55) C55 lg6 Sw24 03.06.03 13:58:40 IMEI: 351011521688921 Code(05): OTP closed Code(08): BootKEY is unknown Code(0D): Keys are registered in BCORE Code(10): Minimal access to BFB Code(15): Complete condition Code(19): Monitoring is switched on Code(1D): Blocks 5121,5122,5123 are present Battery Voltage 4200 mV. SecurityMode: Customer Instance Format... No Ping mobile |
05-31-2008, 09:03 | #2 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | ****** Joker Siemens EGOLD Phone Version 0.3.5.6c Inofficial opened. ****** ****** Saturday, May 31, 2008, at 01:01:46 ****** Open file "H:\Devices\Mix\siemens joker\Files\C55_full_v18_lg91\C55_full _v18_lg91.bin" for write in Flash. FullFlash file info: FlashID: 002C/0017 SIEMENS C55 Sw18 lg91 RealLgPack: lg91 Start... Loading BootsModel(C55)... StartBoot does not answer! ****** Joker Siemens EGOLD Phone Version 0.3.5.6c Inofficial closed. ****** ****** Saturday, May 31, 2008, at 01:02:44 ****** |
05-31-2008, 09:50 | #3 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: INNER SIDE OF MOBILE PHONES
Member: 369802 Status: Offline Thanks Meter: 82 | Quote:
05-31-2008, 11:39 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
seems to be bootcore. Verify first cable, COM port connection, baudrate to 115200 and try to enter in service mode. If enter, fullflash again (check ReCalc Keys). If not, try with Freia. BTW: make more times format, destroy your phone... dagos | |
06-01-2008, 05:33 | #6 (permalink) | |
In attachemment you have the Freia software. Select Phone Model: C55 and go to "Configuration Functions". Select on which port you used (I suppouse to you have serial cable), select speed to 115200 and boottype to normal. For flash: Go to "Write flash to phone" and select the fullflash file (.fls or .bin provided by V-Klay, not from Joker or SST!!!). If you want to flash bootcore area, you need to select Bootcore, for Eeprom select EEProm1 and for firmware upgrade select Firmware (this is fullflash, but not write the bootcore area). Click to OK, push shortly the phone Power On button and wait... For unlocking: Go to the "Unlocking functions", select "Direct unlock no map is saved", click on "Use original IMEI" and unlocking process is started. Note: after each fullflash, you need to unlock your phone. Working fullflash (backup from my phone) you finded on: -for Joker http://rapidshare.com/files/90826811/C55lg4Sw24_FF.rar -for Freia http://rs373.rapidshare.com/files/97767619/C55.rar Search on my responses to the other members to know detailed how to flash or unlock using Freia. dagos Last edited by dagos; 06-15-2008 at 15:45. | |
The Following User Says Thank You to dagos For This Useful Post: |
BLACKBERRY 7290 RED light blinking only ? | harish35200 | BlackBerry (RIM) | 2 | 12-24-2008 07:37 |
l7 keypad light blink only help | mobilejunc | Motorola Hardware Repair | 3 | 09-05-2008 14:50 |
6131 light blink only | ruvanw1979 | Nokia Base Band 5 ( BB-5 ) | 8 | 11-20-2007 21:35 |
Z520i lcd light blinking only | cellbhai | Sony Ericsson Hardware Repair | 1 | 11-25-2006 19:55 |
