Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 12-05-2005, 03:42   #46 (permalink)
Member: 137411
Read Flash SMS by pressing Red Button
Author: Dingol
When there is unread Flash SMS, by pressing Red Button a new window will pop up and display the content of the SMS. You can save the SMS as well.
It is also useful to read Status Report of SMS and Cell Broadcast.
35ECD4: A8D8DAD0B0A8DAD65C14 E01CDAF334EDDAD504C0
Old 12-05-2005, 03:48   #47 (permalink)
Member: 137411
Warning when out of Network signal range:
Author: dingol
The phone will emit tone or vibrate when it gets out of Operator's Network signal range.
Bug: It will give warning also when it is searching for the Network.
35F2AA: DAF4FA3F DAC720D4
27D420:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAF4FA3FDAB5CED248403D04E6FC3B00
27D430:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAB502D2DAB570D548403D02DAB55AD4DB00
Old 12-06-2005, 08:23   #48 (permalink)
Member: 137411
Display Progress scale of Second on Mainscreen:
Author: Pinky
On the bottom of mainscreen, a time scale is displayed indicating the progress of second. The progress scale is not exact, seconds go roughly for reference purpose.
0x363B5C: 26FC1A00 DABFC063
0x1F63C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088108820D7403400F3F22B3E2D19
0x1F63D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400E00F2F18000D7400D00F2F2DC25
0x1F63E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 41422D01E103F1240932D7400E00F6F1
0x1F63F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8000F123E103F0C1E6FD3500E0DEDAB3
0x1F6400: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 04DF9820981098C026FC1A00DB00
0x500068: 06010100FC3FA203 04020100FC3FA203
0x48BFFC: 03FF 2F7F
Old 12-08-2005, 08:09   #49 (permalink)
Member: 137411
Enable the function of Hiding Own Number
Author: JunFeng
;Provided with the service support from the Network Operator
2522F4: 2D0D 0D0B
;If the above line is invalid, try the below patch:
;2522F4: 0D0B 0D09
Old 12-20-2005, 09:16   #50 (permalink)
Member: 137411
Picture(s) & Animation Functions
Author: Wise2008
These functions are built based on Softkey Animation/Picture.
;Entrypoint: DABF5086
;Function for 2 pictures, one positioned at (hex 00,41), the other positioned at (3e,41)
0x1F8650: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D088E0E00CE6FD4100E6FE2801;4100
0x1F8660: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAB304DFE6FC3E00E6FD4100E6FE1101;3E00,4100
0x1F8670: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAB304DF98E098D098C0DB00FFFFFFFF
;Entrypoint: DABF8086
;Function for 1 picture, positioned at (27,41), adjustable
0x1F8680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D088E0E6FC2700E6FD4100E6FE;2700,4100
0x1F8690: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3402DAB304DF98E098D098C0DB00FFFF
;Animation function entrypoint: DABF1026
0X1F2610: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403400F2FE2E3E08E146FE0c008D01;0c00 (12pics) -- pic numbers in a cycle
0X1F2620: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00ED7403400F6FE2E3E06FEb200E6FC;b200-- first pic ID
0X1F2630: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2800E6FD3c00DAB304DFdb00;DAA0CA15DB00;2700-X,3c00-Y
Usage:
We can have animation on MP3 screen by using the hooks below:
0x1F0726: DAB304DF DABFF025;selectable hook
0x1f25f0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAB304DFD7403600F2F1760D9AF10210 ;10-profile 3-function 2
0x1f2600: FFFFFFFFFFFF DABF1026DB00
;or just this hook:
;0X59FF60: DAB304DF DABF1026
;or
;0x1F06F8: 98C098D0 DABF1026
;or
;0x1F09c6: 98C098D0 DABF1026
Old 12-20-2005, 10:57   #51 (permalink)
Member: 184311
Author: Dingol
Somebody transfer this patch on fw5601
Old 12-20-2005, 13:24   #52 (permalink)
Member: 42457
;*** RFR. Read Flash by RED Button ***
;Firmware : SL45v56
;Author : rizapn
;Released : July 19, 2004
;Read existing Flash SMS by pressing RED Button
;This patch is overwriting the "RBF: Red Button when Flash exists" and vice versa,
;choose which one is more natural for you.
0x3B0698: A8D8DAD69809DADB8219 E01CDAF05083DADA9ECF
Old 12-20-2005, 14:58   #53 (permalink)
Member: 184311
oops!
big thanks!
Old 12-21-2005, 02:46   #54 (permalink)
Member: 137411
Change the response time at pressing a key
Author: iamhcy
The patch enables quick response in pressing keys.
;short pressing response
0x14AD2E: AD 35
;continual pressing response (especially when inputing letters)
0x14ABF2: 56 20
;long pressing response
0x14AC98: 82 40
Author: huajia
;speed up the change of different input methods.
0x43AE7C: 2A 00
;remove the info window when changing input methods.
0x43AF92: DAE1AAF9 CC00CC0
Old 01-04-2006, 08:38   #55 (permalink)
Member: 137411
Mp3 Playlist Modification
Author: dxl
The patch has solved the bug of the phone going dead when there are over 30 songs in the directory (a:\MP3) or on a playlist.
Notice: Before applying this patch, the phone can play at most 31 songs on a playlist, after applying it can now only play 30 songs on a playlist. Compared with Mamaich's >30 playlist patch, this is a limitation. But, with this patch, you do not have to select "Repeat mode".
0x36CE6E: 1E 1D;1E hex.=30, 1D hex.=29
;For SLIKv56:
;3BB82E: 26FC1E00 26FC1D00
Old 01-04-2006, 08:58   #56 (permalink)
Member: 137411
Pictures Viewer
Author: Wwssff
Put the entrypoint (0E3.C7EA60) on the Favorite Menu, then you can view series of pictures stored as bin files.
Need Ebin patch.
The patch use bin picture files named as Zqa.bin -- Zqq.bin.
Movement:
Side keys +/- = page up/down
Up/down arrow = up/down 10 pictures
Record key = previous file
Play key = next file
0x27EA60: E6F40010E6FCC519D7503400F6FC2C3E
0x27EA70: F6F42E3EDAE4507388908880E6FC8C89
0x27EA80: E6FDD300E6FEC889F0FDDAE24E7DF084
0x27EA90: F095F0C8F0D9E6FE7E2BE6FF1F03DAE2
0x27EAA0: 367FF0C8F0D9DAF382EA98809890DB00
0x27EAB0: F01EDC4FD44102003D03DAB304DF0D5C
0x27EAC0: D7403400F2FE2C3E26FEC51946F42000
0x27EAD0: 3D0306FE0A000D3C46F421003D0326FE
0x27EAE0: 0A000D3646F422003D0208E10D3646F4
0x27EAF0: 23003D0228E10D2C46F40E003D0228E1
0x27EB00: 0D2746F40D003D0208E10D2746F40800
0x27EB10: 3D010D1346F462003D010D0448413D18
0x27EB20: E004DB00D7403400F2F42E3E084146F4
0x27EB30: 1010BD98E6F400100D95D7403400F2F4
0x27EB40: 2E3E284146F40010DD8DE6F410100D8A
0x27EB50: 48E0DD0806FE3C000D0546FE3C00CD02
0x27EB60: 26FE3C0006FEC519D7403400F6FE2C3E
0x27EB70: E00CE00DDAB304DFE6F4FFFFDB000000
0x27EB80: 0000B0EAC7000000000036E6F300A83F
0x27EB90: 4303AA2B1F0300000000650050002C3E
0x27EBA0: 3400000000000000FF00B22B1F030100
0x27EBB0: FFFF03000300FFFF00000000FFFF0000
0x27EBC0: 0000FFFF05000500FFFF
;1st picture ID (C519) &h19C5=6597 (notice there are several C519 in various places in the above code)
numbers of pictures in a file: &h003C=60
;Method of preparing a bin file of pictures: you can download a software specially for making a bin file of pictures, see attachment "Bin pictures preparation".
;Picture indexes, please view previous post on this thread for the way to change a picture index so that it can be loaded as bin picture.
50CE20: 6550010000002000 ; 6597#
50CE28: 6550010010042000 ; 6598#
50CE30: 6550010020082000 ; 6599#
50CE38: 65500100300C2000 ; 6600#
50CE40: 6550010040102000 ; 6601#
50CE48: 6550010050142000 ; 6602#
50CE50: 6550010060182000 ; 6603#
50CE58: 65500100701C2000 ; 6604#
50CE60: 6550010080202000 ; 6605#
50CE68: 6550010090242000 ; 6606#
50CE70: 65500100A0282000 ; 6607#
50CE78: 65500100B02C2000 ; 6608#
50CE80: 65500100C0302000 ; 6609#
50CE88: 65500100D0342000 ; 6610#
50CE90: 65500100E0382000 ; 6611#
50CE98: 6550010000002100 ; 6612#
50CEA0: 6550010010042100 ; 6613#
50CEA8: 6550010020082100 ; 6614#
50CEB0: 65500100300C2100 ; 6615#
50CEB8: 6550010040102100 ; 6616#
50CEC0: 6550010050142100 ; 6617#
50CEC8: 6550010060182100 ; 6618#
50CED0: 65500100701C2100 ; 6619#
50CED8: 6550010080202100 ; 6620#
50CEE0: 6550010090242100 ; 6621#
50CEE8: 65500100A0282100 ; 6622#
50CEF0: 65500100B02C2100 ; 6623#
50CEF8: 65500100C0302100 ; 6624#
50CF00: 65500100D0342100 ; 6625#
50CF08: 65500100E0382100 ; 6626#
50CF10: 6550010000002200 ; 6627#
50CF18: 6550010010042200 ; 6628#
50CF20: 6550010020082200 ; 6629#
50CF28: 65500100300C2200 ; 6630#
50CF30: 6550010040102200 ; 6631#
50CF38: 6550010050142200 ; 6632#
50CF40: 6550010060182200 ; 6633#
50CF48: 65500100701C2200 ; 6634#
50CF50: 6550010080202200 ; 6635#
50CF58: 6550010090242200 ; 6636#
50CF60: 65500100A0282200 ; 6637#
50CF68: 65500100B02C2200 ; 6638#
50CF70: 65500100C0302200 ; 6639#
50CF78: 65500100D0342200 ; 6640#
50CF80: 65500100E0382200 ; 6641#
50CF88: 6550010000002300 ; 6642#
50CF90: 6550010010042300 ; 6643#
50CF98: 6550010020082300 ; 6644#
50CFA0: 65500100300C2300 ; 6645#
50CFA8: 6550010040102300 ; 6646#
50CFB0: 6550010050142300 ; 6647#
50CFB8: 6550010060182300 ; 6648#
50CFC0: 65500100701C2300 ; 6649#
50CFC8: 6550010080202300 ; 6650#
50CFD0: 6550010090242300 ; 6651#
50CFD8: 65500100A0282300 ; 6652#
50CFE0: 65500100B02C2300 ; 6653#
50CFE8: 65500100C0302300 ; 6654#
50CFF0: 65500100D0342300 ; 6655#
50CFF8: 65500100E0382300 ; 6656#
Old 01-05-2006, 21:42   #57 (permalink)
Member: 150519
Dear Xinshou! Please post Softkey Skins patch!
Old 01-06-2006, 01:57   #58 (permalink)
Member: 137411
1. Still pictures on left/right softkeys (selectable)
Author: Lishenglyx
0X3637CC: 26F00C00 DABF6085
0X1F8560: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C088D088E0D7400E00F2F8423A9AF8
0X1F8570: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0F60E00CE6FD4100E6FE2801DAB304DF;60-profile 1, function 7
0X1F8580: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC3600E6FD4100E6FE1101DAB304DF
0X1F8590: FFFFFFFFFFFFFFFFFFFFFFFF 98E098D098C026F00C00DB00
2. Animation on left/right softkeys (selectable)
Modified by Greenteas & xhjjxm
0X363820: DAA0CA15 DABFC026
0X1F26C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88108820883088408850886088708880
0X1F26D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 889088A088B088C088D088E0D7403400
0X1F26E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F4DE3046F4D6133D16D7403600F2F8
0X1F26F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 740D9AF81090E6F80100D7400D0062F8 ;"90"-profile 2,function 10
0X1F2700: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC25CC00DABF4026CC00CC000D04CC00
0X1F2710: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CC00CC00CC00CC00CC00CC00CC0098E0
0X1F2720: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98D098C098B098A09890988098709860
0X1F2730: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98509840983098209810DAA0CA15DB00
0X1F2740: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403400F2FE2E3E08E146FE0A008D01 ;0A00=10pics in a cycle
0X1F2750: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00ED7403400F6FE2E3E06FE0902E6FC ;0F01=1st pic ID
0X1F2760: FFFFFFFFFFFFFFFFFFFFFFFF 3600E6FD4200DAB304DFDB00 ;3600=X,4200=Y
Old 01-06-2006, 02:17   #59 (permalink)
Member: 137411
1. Functions of long pressing keys in SMS Editor
modified by: Greenteas
;long pressing key Up arrow: check SMS counter (counter patch installed first)
;long pressing key left arrow: T9 setup
;long pressing key right arrow: quit without saving
;long pressing key down arrow: illumination
0x34F7BE: 48C53D0C FABF20BE
0x1FBE20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FC24003D02DAB3A86246FC26003D07
0x1FBE30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8890888026F00800DAD5626ADB0046FC
0x1FBE40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 27003D02DAD0F69846FC25003D02DAE4
0x1FBE50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 7A5848C53D02FAD4C2F7FAD4DAF7FFFF
2. Functions of short pressing keys in SMS Editor
Author: Wise2008
A: Save messsage by pressing side key "-"
0x34F6F0: 46FE2F00 FABF3070
0x1F7030: FFFF 46FE
0x1F7032: FF 0D ;"-" key, 0e="+" key
0x1F7033: FFFFFFFFFFFFFFFFFFFFFFFFFF 002D0446FE2F00FAD4F4F6E6FC
0x1F7040: FFFFFFFFFFFFFFFFFFFFFF E835E6FD0E00E6FEB400E0
0x1F704b: FF 5F ;5F=save, or 3F=quick send message
0x1F704C: FFFFFFFF DAB44C72
0x1F7050: FFFFFFFF FAD4D4F7
B: Quick Send messsage by pressing side key "+"
0x34F6F0: FABF3070 FABF6070
0x1F7060: FFFF 46FE
0x1F7062: FF 0e ;"+" key
0x1F7063: FFFFFFFFFFFFFFFFFFFFFFFFFF 002D04FABF3070FAD4F4F6E6FC
0x1F7070: FFFFFFFFFFFFFFFFFFFFFF E835E6FD0E00E6FEB400E0
0x1F707b: FF 3F ;3F=send SMS, or use 4F
0x1F707c: FFFFFFFF DAB44C72
0x1F7080: FFFFFFFF FAD4D4F7
C. Disable Red key in SMS Editor, and Quit SMS editor while saving message by long pressing RED key
Based on Rc-flitzer's patch
0x34F73C: 46FE5A00 FAbf4061
0x1f6140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48E13D02FAD4D4F746FE5A00FAD440F7
Old 01-07-2006, 19:50   #60 (permalink)
Member: 150519
Author: Lishenglyx
Can you post static version of this patch? Without selection from Application-menu?
Other question: what picture this patch using(number)?
Download Dct4 Patch Imei Files from Support Celumoviles Fast Dongle Solution 3 11-25-2010 14:35
http://bbs.mydigit.cn--All mp4/mp5 firmware_Free _Jamuna Electronics Media babul_worldnet Game Consoles & Mp3/4 , HD players 3 02-11-2010 20:50
http://bbs.mydigit.cn--All mp4/mp5 firmware_Free _Jamuna Electronics Media babul_worldnet Game Consoles & Mp3/4 , HD players 3 02-03-2010 10:30
people from jdtx.com/cn InfernoNordOst The Market Feed Back 0 01-05-2008 14:31
Page generated in 0.25217 seconds with 10 queries
