09-03-2004, 13:15 | #78 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | I did test both JBC and JNBS using my SL45, and it works as it should be. So, I think it is also work in the S45 platform (S45 is 'newer' than SL45) ... rizapn |
09-03-2004, 23:55 | #79 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | Thanks for reply, friends! Also I could believe they weren't implemented but I was unable to use them. Morover, I've looked in fw if they were used sometime and didn't find them anywhere. SO, either I'm using them in a wrong way (dw optcode: AA(BA)QQrrq0 , where QQ=GPR, rr(jumpr of n word), q=bit number) or they aren't really implemented. Can you tell mw if I'm wrong? |
09-04-2004, 00:24 | #80 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | They are not used (by Siemens firmware compiler, none of the firmware function is converted to that JBC/JNBS assembler), but they are supported by the chip/platform. rizapn |
09-04-2004, 01:03 | #82 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | I use this source : Code: org 37h:3700h mov r12, #1235h jbc r12.0, loc_jbcok mov r12, #0 loc_jbcok: extp #37h, #1 mov 3740h, r12 rets Write to the RAM location 37h:3700h: at+cgsn.w.37.3700.E6FC3512AAFC0100E00CD7403700F6FC 4037DB00 Run from RAM (000D:F700): at+cgsn.r.d.f700 Dump memory from RAM: at+cgsn.d.37.3700 ;~~~~~~~~~~~~~~~ rizapn |
09-07-2004, 22:19 | #84 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | @RizaPN In patch *** SDS. SMS Delete Shortcut *** you wrote: Quote:
09-13-2004, 09:48 | #85 (permalink) |
Junior Member Join Date: Sep 2004 Age: 39
Member: 81758 Status: Offline Thanks Meter: 0 | @anybody_who_knows What is the meaning of r13 passed to function at 0xE6F1C8 (info box display). For example calculator short help (LeftSoft key) shown at 0xA59628 passes #0E21h. Is it some kind of id, or offset (if so - what segment)? I can't find it in func. |
09-13-2004, 11:34 | #86 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @viraptor: r13 in that function (I call it msgBox2) is a firmware textID. 0xE21 is ID for calculator sign text. If you have sfe, you can try this command : sfe l sl45ff.bin e21 @abomin: If you explore the fullflash starting from offset 0x18AE8E : you will see this hexa values : 6F 00 52 00 4B 4E 1E 00 52 00 59 00 1D 00 52 00 1D 02 29 00 52 00 7E 01 etc-etc ... 6F is button code, 4E4B is text code for button (image move to archive) 1E is button code, 0059 is text code for button (Reply) 1D is button code, 021D is text code for 'Send' 29 is button code, 017E is text code for 'Delete' etc-etc ... means : 6F -> move to archive, 1E -> Reply, 1D -> Send, 29 -> Delete ... and you can modify them as you like. You can also check, the function written in the address : 0xD9E9C8, it is smsSoftKeyHandle() function. rizapn |
09-13-2004, 13:52 | #87 (permalink) | |
Crazy Poster Join Date: Jun 2004 Location: Szczecin (Poland) Age: 41
Member: 68809 Status: Offline Thanks Meter: 0 | Quote:
-EDITED- OK, found it (0x18AE94), thanks again! HeCToR Last edited by H3ct0R; 09-13-2004 at 14:47. | |
09-14-2004, 03:39 | #88 (permalink) |
Junior Member Join Date: Aug 2004 Location: Italy
Member: 78902 Status: Offline Thanks Meter: 0 | Can somebody please provide some example about how to read the EEPROM through assembler coding (e.g. in order to point to the content of EEPROM Block "5089=* WAP Profile 4b (CSD Dialup) *")? Thanks. amacri |
09-14-2004, 05:11 | #89 (permalink) |
Member: 50673 Status: Offline Thanks Meter: 2 | For SLIK: Read Data from EEPROM (method 1) : mov r12, #0 mov [-r0], r12 mov [-r0], r12 mov [-r0], r12 mov r12, size mov [-r0], r12 mov r12, EEPROM_Block mov r13, dst_Offset mov r14, dst_Page mov r15, offset calls 0C2h, 2F3Eh add r0, #8 Read Data from EEPROM (method 2) : mov r12, size mov [-r0], r2 mov r12, EEPROM_Block mov r13, dst_Offset mov r14, dst_Page mov r15, offset calls 0C2h, 30BAh add r0, #2 |
09-14-2004, 11:08 | #90 (permalink) |
Member: 81758 Status: Offline Thanks Meter: 0 | @RizaPN Thanks for dialogs explanation, Master @all Assembler question - can someone explain me how this works (from begining of item handler in SMS menu): Code: mnu_sms_itemhandler: csegD9:0D30 F0 1E mov r1, r14 csegD9:0D32 F0 2F mov r2, r15 csegD9:0D34 28 12 sub r1, #2 csegD9:0D36 38 20 subc r2, #0 csegD9:0D38 2D 05 jmpr cc_Z, loc_D90D44 If I'm wrong, then what are exact meaings of r14 and r15? edit: new question - i'm trying to make a dynamic message - looks like this: Code: my_text: db 95h,'My text',0 org 0EBBCE0h my_patch: mov [-r0], r12 mov [-r0], r13 mov [-r0], r14 mov [-r0], r15 mov r12, #8B9h mov r13, #0h calls 0E65B5Eh ; resetStringID mov r12, #8B9h mov r13, q(my_text) mov r14, p(my_text) mov r15, #0h calls 0E6599Ch ; convert2ID mov r13, #8B9h mov r12, #1h calls 0E6F1C8h ; showCustomDialog mov r15, [r0+] mov r14, [r0+] mov r13, [r0+] mov r12, [r0+] rets Last edited by viraptor; 09-14-2004 at 23:11. Reason: new question |
BB5 - Technical Discussion | adihack | Nokia Base Band 5 ( BB-5 ) | 220 | 10-14-2011 05:31 |
x65 patching technical discussion | Acidmrp | x6x and x7x Flashpatching | 42 | 10-10-2009 07:06 |
Iphone 3G Technical Discussion and SP Unlocking theory | GraveSlayer | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 11-15-2008 06:04 |
Technical discussion sharp705sh | celluniversal | Sharp | 0 | 05-17-2007 17:26 |
Technical discussion BB5 unlocking | twisterfan | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 19:36 |
