12-12-2003, 19:38 | #32 (permalink) |
Insane Poster Join Date: Dec 2003 Location: Ukraine Age: 49
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** KTM. Keylocked_auto_TimeOut_Modification *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 11, 2003 0x560DD0: 60EA 3075 ;The value is representing time before auto keylocked in milisecond ;(original = EA60 = 60000 ms). Modify with your own value. ~~~~~~~~~~~~~~~~~~~~~~~~~ |
12-12-2003, 19:40 | #33 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** ISK. Invert Softkey Display *** ;Firmware : SME45iv04 ;Author : RizaPN ;This patch will invert the soft key display ;black text with white background 0x27F557: 60 00 0x27F65F: 97 07 ~~~~~~~~~~~~~~~~~~~~~~~~~ |
12-12-2003, 19:41 | #34 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** AAA. Assign Any ringtone to Any number *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 11, 2003 ;This patch is work based on Addressbook data. ;Use 2 digit "Post code" as a ringtone ID, for example: ;01 is for ringtone no.1, etc... 0x2DDAB8: DAF9FA79 DA8780C9 0x07C980: FFFFFFFFFFFFFFFF E002D7503C00F2F1 0x07C988: FFFFFFFFFFFFFFFF 262BF6F2262B27F2 0x07C990: FFFFFFFFFFFFFFFF 30008D0B27F33000 0x07C998: FFFFFFFFFFFFFFFF 8D08C02D5C3D00D1 0x07C9A0: FFFFFFFFFFFFFFFF 00D1C03100D166FD 0x07C9A8: FFFFFFFFFFFFFFFF 3F00FAF9FA79FFFF ~~~~~~~~~~~~~~~~~~~~~~~ |
12-12-2003, 19:42 | #35 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** BEW. Modify Battery Empty Warning Sound *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 11, 2003 0x25FFB9: 3C 0C ; no sound ;0x25FFB9: 3C 1C ; tut-tut-tut sound ;0x25FFB9: 3C 2C ; high "tit" sound ;0x25FFB9: 3C 4C ; "click" ;0x25FFB9: 3C 5C ; "tit" sound ;8C = "tuuuuuuuuuuuuuuuuuuuut" ;9C = "tu-tu-tu-tu" ;AC = "tu-tu-tu-tu" ;BC = "tut" ;CC = "tu-tu-tu" ;DC = "tu-tu-tu"x3 ;EC = "tu--tu" ~~~~~~~~~~~~~~~~~~~~~~~~~ |
12-12-2003, 19:44 | #36 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** NAM. Add New "Application" Menu *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 12, 2003 ;This patch will create a new "Application" menu under the ;Setup menu to provide the ability to enable/disable some ;function provided by patches. ;After applying this patch, you need to REAPPLY the Digital ;Clock patch with the latest version. 0x05B9CC: 810AEF04 1A0C1A0C 0x05B9F6: 7284F600 D0C98700 0x07C9D0: FFFFFFFFFFFFFFFF E6F32200EC00E600 0x07C9D8: FFFFFFFFFFFFFFFF 4400E6F11638E6F2 0x07C9E0: FFFFFFFFFFFFFFFF 8839D7401F02D4C3 0x07C9E8: FFFFFFFFFFFFFFFF E00AE6F459058841 0x07C9F0: FFFFFFFFFFFFFFFF E0348841E0048841 0x07C9F8: FFFFFFFFFFFFFFFF 8841884188C188C1 0x07CA00: FFFFFFFFFFFFFFFF E6F41A028841E6F4 0x07CA08: FFFFFFFFFFFFFFFF 30098841E6F48700 0x07CA10: FFFFFFFFFFFFFFFF 8842E6F480CA8842 0x07CA18: FFFFFFFFFFFFFFFF 06F124002832ADE1 0x07CA20: FFFFFFFFFFFFFFFF 0824E6F4F6008842 0x07CA28: FFFFFFFFFFFFFFFF E6F472848842FC00 0x07CA30: FFFFFFFFFFFFFFFF F0CEF0DFE00E88E0 0x07CA38: FFFFFFFFFFFFFFFF E6FFA40AE6F11F02 0x07CA40: FFFFFFFFFFFFFFFF 881088F0E6FEB40A 0x07CA48: FFFFFFFFFFFFFFFF F0F1DAFAA8470806 0x07CA50: FFFFFFFFFFFFFFFF DB00E00348E02D07 0x07CA58: FFFFFFFFFFFFFFFF F02EBB0A60212D02 0x07CA60: FFFFFFFFFFFFFFFF E0130D01E0238830 0x07CA68: FFFFFFFFFFFFFFFF DAFA3A2B0802DB00 0x07CA70: FFFFFFFFFFFFFFFF E01128214C12D740 0x07CA78: FFFFFFFFFFFFFFFF 4200F2F23C3FCB00 0x07CA80: FFFFFFFFFFFFFFFF 88C088D0DAFAE42B 0x07CA88: FFFFFFFFFFFFFFFF F024BBF25021D740 0x07CA90: FFFFFFFFFFFFFFFF 4200F6F23C3F98D0 0x07CA98: FFFFFFFFFFFFFFFF 98C0E6FE1100E00F 0x07CAA0: FFFFFFFFFFFFFFFF FAFADC3500000000 0x07CAA8: FFFFFFFFFFFFFFFF 65000C00243A1602 0x07CAB0: FFFFFFFFFFFFFFFF 1A0CFF7F00000000 0x07CAB8: FFFFFFFFFFFFFFFF 0000000000000000 0x07CAC0: FFFFFFFFFFFFFFFF 0000000008091A02 0x07CAC8: FFFFFFFFFFFFFFFF FE081A0281020000 0x07CAD0: FFFFFFFFFFFFFFFF 52CA870004384400 0x07CAD8: FFFFFFFFFFFFFFFF 4439440011008002 0x07CAE0: FFFFFFFFFFFFFFFF 0000220322032203 0x07CAE8: FFFFFFFFFFFFFFFF 2203220322032203 0x07CAF0: FFFFFFFFFFFFFFFF 220322032B02A304 0x07CAF8: FFFFFFFFFFFFFFFF 3800B60285032E01 0x07CB00: FFFFFFFFFFFFFFFF AA06EF04FFFFFFFF ;~~~~~~~~~~~~~~~~~~~~~~~~~ |
12-16-2003, 02:53 | #37 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | FLS. Flash SMS Directly from the Phone (vs Unicode) ;*** FLS. Flash SMS Directly from the Phone *** ;Firmware : SME45iv04 ;Author : RizaPN,$Lava ;Release : December 15, 2003 ;Updated : December 17, 2003 (v3.1) ;Give a possibility to send a Flash SMS directly from the phone ;Add 1 space in the beginning of the message to send it as a flash ;SMS, otherwise it will send as a normal ones. ;Added Unicode support and possibility to change "Flash" symbol 0x4904A6: E6FCFA39 DA87D0CB 0x07CBD0: FFFFFFFFFFFFFFFF E6F2F020D7505700 0x07CBD8: FFFFFFFFFFFFFFFF F3F34E39F3F24D39 0x07CBE0: FFFFFFFFFFFFFFFF 2D0241252D044135 0x07CBE8: FFFFFFFFFFFFFFFF 3D06E7F41800D740 0x07CBF0: FFFFFFFFFFFFFFFF 5700F7F43F39E6FC 0x07CBF8: FFFFFFFF FA39DB00 ;change "Flash" symbol ;0x07CBD3: 20 21 ; '!' ;0x07CBD3: 20 23 ; '#' ;0x07CBD3: 20 24 ; '$' ;0x07CBD3: 20 25 ; '%' ;0x07CBD3: 20 3A ; ':' ;0x07CBD3: 20 3F ; '?' ~~~~~~~~~~~~~~~~~~~~~~~~~ Last edited by patch_me; 12-18-2003 at 22:36. |
12-16-2003, 02:58 | #38 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** RKL. RED Longpressed Key Light *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 15, 2003 ;Enable illumination flag for RED longpressed key light when key ;is locked. After applying this patch, the light after pressing ;RED key when the key is locked, is only turn ON if the Illumination ;is enabled (normally, the light is always ON). 0x2CDF28: 9A09 0DF3 ;~~~~~~~~~~~~~~~~~~ |
12-16-2003, 03:04 | #39 (permalink) |
Member: 46164 Status: Offline Thanks Meter: 1 | ;*** BLANK. Blank Screen when Keylocked *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 15, 2003 ;Need 'RKL' patch ... ;Function is selectable from Setup->Application->Screensaver menu ;Display will be blanked if the key is locked, ;by long-pressing # button or by auto-keylock function. ;Dispaly will become normal if the key is unlocked, ;or call/message/appointment arrived, or RED button is ;long-pressed. 0x24FDEE: FACC82DF FA8734CC 0x57D41E: F3F2AF2E DA8710CC 0x07CC10: FFFFFFFFFFFFFFFF D7504500C2F40036 0x07CC18: FFFFFFFFFFFFFFFF F7F9003641892D05 0x07CC20: FFFFFFFFFFFFFFFF DACAC633C08CDACA 0x07CC28: FFFFFFFFFFFFFFFF 327DD7405B00F3F2 0x07CC30: FFFFFFFFFFFFFFFF AF2EDB00D7404200 0x07CC38: FFFFFFFFFFFFFFFF F3F83C3F9AF40850 0x07CC40: FFFFFFFFFFFFFFFF E00CDACA327DE014 0x07CC48: FFFFFFFFFFFFFFFF D7404500F7F80036 0x07CC50: FFFFFFFFFFFFFFFF FACC82DFFFFFFFFF ;~~~~~~~~~~~~~~~~~~~~~~~~ |
12-16-2003, 17:11 | #40 (permalink) |
Junior Member Join Date: Dec 2003 Location: Poland Age: 39
Member: 46590 Status: Offline Thanks Meter: 0 | in this patch I found bad adress: ;*** ISK. Invert Softkey Display *** ;Firmware : SME45iv04 ;Author : RizaPN (corrected by CooKee) ;This patch will invert the soft key display ;black text with white background 0x27F556: 60 00 0x27F65F: 97 07 and now it works Last edited by CooKee; 12-16-2003 at 21:16. |
12-17-2003, 19:06 | #41 (permalink) |
Junior Member Join Date: Jun 2003 Location: SPAIN Age: 49
Member: 30734 Status: Offline Thanks Meter: 0 | ;** ANIMATED OPERATOR LOGO AND DIGITAL CLOCK ** ;Corrected. It works well seems to be but some address are overlapped with other patches like: ;**NAM.Add New Application menu**, **FLS.FLASH SMS**, **BLANK.Blank screen when keylocked**, ;perhaps with more... ;Enjoy it!!. ;eaXier ;Firmware: S/ME45i 040315 ;Version 0.3 ;Modified: 11.12.03 ; ; ;*** Original patch for SL45 (C) by RizaPN ***** ; Adaptation for S/ME45i (C) by REDKIN ; Instructions: ; 1. Undo Other Animated Logo Patches (don't forget to UNDO pictures!). ; 2. Apply this patch to phone AND to prevoiusly downloaded fullflash (or ; download FF after applying this patch). ; 3. AFTER that change in SiemensPictureChange pictures 310-321 for ; digital clock and 320-333 for animated logo (or see comments below ). ; 4. Save patch in SPC. Open it in V_Klay. Delete unwanted CRC check. Apply it. ; 5. If Operator Logo is disabled - enable it! ; Menu-Setup-Phone-Display-Bitmap Viewer-Load. ; 6. Enjoy! ; COMMENTS: ; - Alpha version! Bugs may vary. Report to [email protected] ; - WARNING! DON'T INCREASE in SPC picture sizes (i mean this patch only)!!! Results ; could be realy bad. ; - You can use Pictures from original Patch for SL45. Try to look here: ; http://www.calver.cz/luke/index.htm ; OR you can use created by me .vkp file: ; http://dredkin.narod.ru/siemens/digclock/digits.rar ; and this animation: ; http://dredkin.narod.ru/siemens/digclock/globus.rar ; in this case, you can skip step 3 of instruction ;- your comments and bug reports on e-mail above are very appreciated. ;- See patch customization below. 005610A6: DACBF86E DA8700CB 005607E0: 46FC2300 DA8710CB 0055C8F8: D7405B00F2F65224 DA8724CBCC00CC00 00565096: DAC40AFE DA872ECB 0007CB00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E016D7405B00F7FC8A1FDACBF86EDB00 0007CB10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48C1FD05E004D7405B00F7F88A1F46FC 0007CB20: FFFFFFFF 2300DB00 0007CB24: FFFFFFFFFFFFFFFFFFFF D7405B00F2F652240DF3 0007CB2E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC40AFEF094E01448902D02DAF4F400 0007CB3E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402D010D02BB040D01BB1EF049DB00 0007CB4E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405B00F3F48A1F49402D15D7405B00 0007CB5E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FE881F08E146FE0A008D01E00ED740 0007CB6E: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5B00F6FE881F06FE4201E6FC0000E6FD 0007CB7E: FFFFFFFFFFFFFFFF 0900DAC89C43CB00 0007CB86: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7405B00F3F88A1F2D33E00CE0BEBB27 0007CB96: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00CD7503C00F2F1503DF2F24E3D8820 0007CBA6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB28E6FEFFFFD7405B0054FE881FDD03 0007CBB6: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 06FC0D000D04E0AEBB1226FC09009810 0007CBC6: FFFFFFFF BB01CB00 0007CBCA: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE 0007CBDA: FFFFFFFFFFFFFFFFFFFF 0EFEBB0398E0BB01CB00 0007CBE4: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C006FE3601E09DDAC89C4398C006FC 0007CBF4: FFFFFFFF 1600CB00 0007CBF8: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E0A2F6F10EFE5B22F2F10CFE8810F2FE 0007CC08: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0EFE48E02D02BBEA0D0206FC160098E0 0007CC18: FFFFFFFF BBE5CB00 ; Changes in picture table (pictures itself come separately): 000DE8E0: 21230100D62735021C1D010085283502 162F0100AC282902162F010039292902 000DE8F0: 1B1F0100F92835021B28010075293502 162F0100C6292902162F0100532A2902 000DE900: 15270100152A35021A2701008A2A3502 162F0100E02A2902162F01006D2B2902 000DE910: 17230100262B3502182601008F2B3502 162F0100FA2B2902162F0100872C2902 000DE920: 15270100012C350215210100762C3502 162F0100142D2902162F0100A12D2902 000DE930: 1A280100D92C350213280100792D3502 0D2F01002E2E2902652F01008C2E2902 000DE940: 16260100F12D350228160100632E3502 652E010050112902652E0100A6132902 000DE950: 15270100D12E35021B250100462F3502 652E0100FC152902652E010052182902 000DE960: 18230100DA2F35021326010043303502 652E0100A81A2902652E0100FE1C2902 000DE970: 1B220100B53035021D2101003D313502 652E0100541F2902652E0100AA212902 000DE980: 23200100C13135021723010061323502 652E010000242902652E010056262902 ; Patch Customizaton ; 0007CB66: 0A 0X ; X - number of frames in animation. Max. 10 frames. ; 0007CB41: 01 XX ;What is drawn when keys are UNLOCKED: ; 04 - Default Logo ; 03 - Digital Clock ; 01 - Animated Logo ; 0007CB43: 02 XX ;What is drawn when keys are LOCKED: ; 03 - Default Logo ; 02 - Digital Clock ; 00 - Animated Logo Last edited by eaXier; 12-17-2003 at 19:12. |
12-18-2003, 10:53 | #42 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** CLST. Call List via GREEN button (SME45) *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 18, 2003 ;Use GREEN button to access ALL Call List. ;1st access will go to Calls Dialled, ;2nd will go to Calls Received, and the last for Call Missed. 0x5609B8: DAF8220D DA87B0CD 0x07CDB0: FFFFFFFFFFFFFFFF D7404400F3F2FE37 0x07CDB8: FFFFFFFFFFFFFFFF 092149238D01E102 0x07CDC0: FFFFFFFFFFFFFFFF D7404400F7F2FE37 0x07CDC8: FFFFFFFFFFFFFFFF 3D02FAF8D20D4921 0x07CDD0: FFFFFFFFFFFFFFFF 3D02FAF8020DFAF8 0x07CDD8: FFFFFFFFFFFFFFFF 260DFFFFFFFFFFFF ;~~~~~~~~~~~~~~~~~~~~~~~~~ RizaPN, Jakarta - Indonesia |
12-18-2003, 10:58 | #43 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** MSC. More Shortcut *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 16, 2003 ;Get 12 more fixed shortcut (button 0-9,*,# followed by LeftSoftKey) ;Assign your favourites function to them, and you can use ;all button for phone numbers shortcut ... 0x55DA78: DA8770CC 0x27F966: DA8714CD 0x07CC70: FFFFFFFFFFFFFFFF 46FF0B003D1AF04C 0x07CC78: FFFFFFFFFFFFFFFF D7404400F3F4FF37 0x07CC80: FFFFFFFFFFFFFFFF 48413D0249402D06 0x07CC88: FFFFFFFFFFFFFFFF 2841D7404400F7F8 0x07CC90: FFFFFFFFFFFFFFFF FF370D0BBB0B0822 0x07CC98: FFFFFFFFFFFFFFFF E005D7601F0299A2 0x07CCA0: FFFFFFFFFFFFFFFF 9992A982DAE2FAFF 0x07CCA8: FFFFFFFFFFFFFFFF E00CDB00D7405B00 0x07CCB0: FFFFFFFFFFFFFFFF F3F45B2427F43000 0x07CCB8: FFFFFFFFFFFFFFFF 9D0509463D02E1A4 0x07CCC0: FFFFFFFFFFFFFFFF 0D01E1B447F40B00 0x07CCC8: FFFFFFFFFFFFFFFF EDFCC042F0125C21 0x07CCD0: FFFFFFFFFFFFFFFF 002106F2D80CCB00 ;Modify this list as you like. ;The first 2 byte is text code for LeftSoftKey ;and the last 3 byte is function entry-point ;Example: 01EC is "Calc.", and F65D38 is its entry-point 0x07CCD8: FFFFFFFFFF 01ECF65D38 ; 0.Calendar 0x07CCDD: FFFFFFFFFF 00A5E994CA ; 1.Inbox 0x07CCE2: FFFFFFFFFF 01ADE99466 ; 2.SMS 0x07CCE7: FFFFFFFFFF 0057E99508 ; 3.Outbox 0x07CCEC: FFFFFFFFFF 02F1E99548 ; 4.Archive 0x07CCF1: FFFFFFFFFF 0097E99624 ; 5.New email 0x07CCF6: FFFFFFFFFF 04DAF65EAA ; 6.Notes 0x07CCFB: FFFFFFFFFF 01FEF65D50 ; 7.Appointment 0x07CD00: FFFFFFFFFF 0109F65D44 ; 8.Calendar 0x07CD05: FFFFFFFFFF 0287F65DAA ; 9.Internet 0x07CD0A: FFFFFFFFFF 01BFF65D1C ; *.Games 0x07CD0F: FFFFFFFFFF 0447F65D64 ; #.Explorer 0x07CD14: FFFFFFFF 48603D13 0x07CD18: FFFFFFFFFFFFFFFF 46FC2A013D10D740 0x07CD20: FFFFFFFFFFFFFFFF 5B00F3F45C243D0B 0x07CD28: FFFFFFFFFFFFFFFF D7404400F3F4FF37 0x07CD30: FFFFFFFFFFFFFFFF 3D06BBBCD7501F02 0x07CD38: FFFFFFFFFFFFFFFF 9932A922F0C14861 0x07CD40: FFFFFFFFFFFFFFFF 3D0946FC42013D06 0x07CD48: FFFFFFFFFFFFFFFF E7F4FF00D7405B00 0x07CD50: FFFFFFFFFFFFFFFF F7F45C24F0D65C2D 0x07CD58: FFFFFFFFFFFFFFFF DB00FFFFFFFFFFFF ;~~~~~~~~~~~~~~~~~~~~~~~~ RizaPN, Jakarta - Indonesia |
12-18-2003, 10:59 | #44 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** VIS. Vibra Toggle Shortcut *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 16, 2003 ;Update : December 17, 2003 ;Use '#' followed by RightSoftKey to become a Vibra Toggle ;If you want to use another button, just use 87CD80 as a ;Vibra toggle function entry-point ... 0x5645E8: AA 9A 0x5648A8: DAF17684 DA8780CD 0x07CD80: FFFFFFFFFFFFFFFF DAF7A6D4E6FC1000 0x07CD88: FFFFFFFFFFFFFFFF E6FEF70048402D04 0x07CD90: FFFFFFFFFFFFFFFF E6FDCCD4FAC66014 0x07CD98: FFFFFFFFFFFFFFFF E6FDBAD4FAC61814 ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ RizaPN, Jakarta - Indonesia |
12-18-2003, 11:00 | #45 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** VIN. Vibra Indicator *** ;Firmware : SME45iv04 ;Author : RizaPN ;Release : December 16, 2003 ;Modify an unknown indicator (hope it is not used in a "normal" ;phone usage) to become a Vibra ones. 0x565012: DAC5B401 DAF7A6D4 ;Vibra image sample (image is taken from SL45 thread) 0x0D94FD: 807F9F 010000 0x0D9500: 408D5F4D76BF5175 25E4804912402514 0x0D9508: 3F5376BF238D5F 8049B240255480 0x0D9510: 7F9F E000 ;~~~~~~~~~~~~~~~~~~~~ RizaPN, Jakarta - Indonesia |
S/ME45i-v04: Flash Patching ... | rizapn | x4x, x5x Flashpatching | 1282 | 07-05-2015 12:16 |
821sc flash patch cid3 dead after flash | cetech | Z3X-Team Products | 26 | 07-17-2009 12:12 |
L760 flashing patched flash problem | Steph | NSPRO | 4 | 12-05-2008 11:04 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Need flash patched with Spanish lang for Neptune ! | Kilowat | Mitsubishi | 4 | 05-21-2002 07:24 |
