Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 11-28-2005, 02:52   #1 (permalink)
^NaT^'s Avatar
Member: 114558
Thanks Meter: 4
How to change AppMenu v1 is AppMenu v3a without undo many patch in SL45.
I'll change AppMenu v1 is AppMenu v3a but my old AppMenu v1(16 selectable item) applied many patch.
How to change AppMenu v1 is AppMenu v3a without undo many patch in old AppMenu v1(16 selectable item old)? Thank you very much.
Old 11-28-2005, 08:08   #2 (permalink)
trustkill's Avatar
Member: 27745
Old v1 is compatible with v3a...
Old 11-29-2005, 09:48   #3 (permalink)
^NaT^'s Avatar
Member: 114558
Thanks Meter: 4
OK.
I applied APP,Application Menu v3a Corrected,already. It's work.
But selectable item profile2-3(item 17-48) not remember unchecked item. When restart my phone all item of profile2-3 checked again.
Before restart my phone,i unchecked it. But after restart my phone all item of profile2-3 checked again.
It doesn't remember unchecked.
How to fix it.
Old 11-29-2005, 16:41   #4 (permalink)
trustkill's Avatar
Member: 27745
Hmmm, I dont know. The only thing I know is that these items are checked at the FIRST TIME you apply v3a... After unchecking and correct restarting phone it is uncheched...
Old 11-29-2005, 19:44   #5 (permalink)
Member: 42457
as trustkill mentioned... after correct phone shutdown, settings are saved. Means if you remove battery and phone switches off instantly NO paramter is saved. Try again please
Old 12-01-2005, 08:38   #6 (permalink)
^NaT^'s Avatar
Member: 114558
Thanks Meter: 4
I tried again with other SL45,it's work(settings are saved at remove battery and without remove battery).But my SL45,it doesn't saved, at remove battery and without remove battery. My SL45 hardware is damaged?
Old 12-01-2005, 13:49   #7 (permalink)
trustkill's Avatar
Member: 27745
Arent´t these settings stored in EEprom ? Maybe you eep is damaged...
How to apply this both patch in SL45.It's possible? ^NaT^ x4x, x5x Flashpatching 2 11-16-2005 01:56
who can tell me how to change the imei for SL45 linhchip83 x1x to x45/x50 2 03-18-2005 09:04
how to change languges for sl45? Nightmare x1x to x45/x50 3 12-15-2003 22:03
How To change volume without sidekeys "+","-" in SL45? HELP! Phalanx x1x to x45/x50 3 08-22-2003 22:02
How to change change chinese language to asian language in T10/T18. AD Old Ericsson Phones & Sony Phones 7 05-03-2001 06:15
Page generated in 0.16212 seconds with 9 queries
