04-28-2004, 09:23 | #61 (permalink) |
Major Poster Join Date: Apr 2004 Age: 46
Member: 63705 Status: Offline Thanks Meter: 0 | And what is the SMS char size? is it possible to be smaller? Last edited by .:JiM:.; 04-28-2004 at 09:36. |
04-29-2004, 08:31 | #64 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: EEPROM damaged Age: 44
Member: 15315 Status: Offline Thanks Meter: 1 | Quote:
S55 has no Drive B, so no way to change this size. And it's not possible to change size of Drive A because 1MB is the maximum S55's drive handler can allocate. So only posible with very tricky idea | |
04-29-2004, 08:41 | #65 (permalink) | |
Member: 63705 Status: Offline Thanks Meter: 0 | Quote:
04-29-2004, 12:55 | #66 (permalink) | |
Insane Poster Join Date: Dec 2003 Age: 39
Member: 46937 Status: Offline Thanks Meter: 0 | Quote:
that's will be better if you want to see hidden folder you can press '#' in flexmem explorer when developper menu is activated and hidden folders + files appears good luck | |
04-29-2004, 14:39 | #68 (permalink) |
Junior Member Join Date: Apr 2004 Age: 45
Member: 62929 Status: Offline Thanks Meter: 0 | @wael_nasreddine i forgot to ask ... developer menu? you mean netmonitor menu(menu->#) ? because if you mean netmonitor menu, it doesn't show me hidden folders after pressing # |
04-29-2004, 15:51 | #69 (permalink) | |
04-29-2004, 15:52 | #70 (permalink) | |
04-30-2004, 15:17 | #72 (permalink) |
Junior Member Join Date: Apr 2004 Age: 42
Member: 64010 Status: Offline Thanks Meter: 0 | Voltage over battery indicator and temp under it. Is there, or could someone make patch to show battery voltage over/inside the battery pic and temp under it. M55 has one I think. |
04-30-2004, 17:28 | #73 (permalink) | |
05-01-2004, 00:44 | #74 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Hungary Age: 39
Member: 19460 Status: Offline Thanks Meter: 1 | Could somebody please make a patch, to remove the stupid "Keys locked press & hold '#' to relase" message? It is really useles and annoying. Thanks and regards, Mike |
05-01-2004, 11:16 | #75 (permalink) | |
;S55v20 - Disable Message "Keypad Locked" ;(c) avkiev 321EDE: DA72 0D01 | |
M55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 880 | 01-25-2010 05:37 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 20:40 |
S55 flash with wrong flash file. | WillGsm | E-Gold Based Phones | 2 | 01-29-2005 13:58 |
