02-12-2003, 16:45 | #31 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13636 Status: Offline Thanks Meter: 0 | this is for the mp3-player: DA D8 C4 E1 : B8 01 : MP3Player is this right? can i put it on the ptt-button (where normally voice dail is)? Last edited by vikado77; 02-12-2003 at 21:19. |
02-12-2003, 16:55 | #32 (permalink) |
Member: 13636 Status: Offline Thanks Meter: 0 | @rizapn why put you voice-dial on the ptt-button. Is is original on voice-dial. (my sl45 ver56 has this funktion without flashing) what is thedifference here to your edit? Last edited by vikado77; 02-12-2003 at 21:23. |
02-13-2003, 00:28 | #33 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @vikado77: 1) What is different? Using that patch, you don't need to press # for a long time and you can use UP arrow to activate VoiceDial also... 2) Yes, that was almost complete table of each function entry-point. Just try them. I also like to try by myself. It sound usefull... RizaPN Last edited by rizapn; 02-13-2003 at 01:05. |
02-13-2003, 16:38 | #34 (permalink) |
Member: 13636 Status: Offline Thanks Meter: 0 | @rizapn i don't understand, what you mean! What have i to do, to open the mp3-player with the ptt-button. You don't write, where i must put the code for the mp3-player to do this. Can you help me please? It will be nice, if you can skip the mp3-´titles with the ptt-button, when the plyer is playing (no fast forward-play) And if you stop the play, you can't start the play with the ptt-button. it's bad. Is it able, to change it? It will be nice, if you can find out! The play-button on the left side of the SL has the same problems! edit: i found out, that it is different, if i open the mp3-player with the shortcut of your list, or if you put the play-button/chose the mp3-player with the voiceDial If you put the play button or open the player about the voicedail, than the play starts automatically. But not if you open the player for example about the 3-button. (Only for information!) Please, help me - this function is importand for me! Last edited by vikado77; 02-13-2003 at 22:08. |
02-14-2003, 03:00 | #35 (permalink) |
Junior Member Join Date: Feb 2003 Location: philippines Age: 44
Member: 20779 Status: Offline Thanks Meter: 0 | In my opinion, it will be nice if the PTT Button will remain as is! because when you are on the move (like i am) and you want to make a call, you can always use the PTT Button to voicedial even if the phone is keylocked (thanks to RIZAPN for the patch)! you can always use it to activate the mp3 via voice command! so in general, it is a multi-function button! cheers |
02-14-2003, 06:19 | #36 (permalink) |
Member: 13636 Status: Offline Thanks Meter: 0 | but you forget a thing: if you start the mp3-player about the voice command, than some important functions are missing: you ca'tn skip the mp3-´titles with the ptt-button, when the plyer is playing (no fast forward-play) And if you stop the play, you can't start the play with the ptt-button! Am I right? |
02-14-2003, 07:12 | #37 (permalink) |
Member: 20779 Status: Offline Thanks Meter: 0 | fast forward is possible... just hold the PTT button! try it! anyway why would you store a song that you tend to skip! why not store the song you like? i think thats more logical! cheers |
02-14-2003, 08:08 | #39 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @sl45i: *) By yourself? Use disassembler, hexa-editor, and flasher. *) By me? Sorry, but I have no plan to use that firmware... *) By others? I don't know... If you want to use all of these patches, just upgrade your firmware to SLIK v56. If you never do firmware-upgrade before, please search in this great Forum. There are so many summary/clue or instruction... RizaPN |
02-14-2003, 10:11 | #40 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Assign Any Melody to Any Phone Number *** Assign Any Ringtone to Any Phone Number *** Firmware : SL45 v56 Author : RizaPN *) This is very long patch, please be very carefull *) This patch will use VIP group setting for distinguishing each number's ringtone. Set VIP melody to the 1st discreet (Menu - Audio - Melodies - VIP - Discreet - 1 - OK), otherwise it will not be used. *) Each name should be ended by 1 additional character which is related directly to the ringtone ID. Usually, SL is using "!" char for VIP group. It will be listed as a VIP in the Phonebook or Addressbook. See the list ... ~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 0x3EC1F2 : DA F1 90 9E -> DA C7 80 D0 0x3EFDAC : DA F1 90 9E -> DA C7 80 D0 0x27D080 : FF FF FF FF FF FF FF FF -> DA F1 90 9E 88 60 E6 F6 0x27D088 : FF FF FF FF FF FF FF FF -> B0 10 D7 40 1F 03 99 96 0x27D090 : FF FF FF FF FF FF FF FF -> 2D 0B 41 98 3D FA 26 F6 0x27D098 : FF FF FF FF FF FF FF FF -> B1 10 D7 40 34 00 F6 F6 0x27D0A0 : FF FF FF FF FF FF FF FF -> 1A 3E E6 F4 21 00 0D 01 0x27D0A8 : FF FF FF FF FF FF FF FF -> E0 04 98 60 DB 00 CC 00 0x27D0B0 : FF FF FF FF FF FF FF FF -> 23 40 5C 26 A7 2E 2C 3F 0x27D0B8 : FF FF FF FF FF FF FF FF -> 21 2B 2D 3A 22 27 3B 2A 0x27D0C0 : FF FF FF FF FF FF FF FF -> 2F 28 29 3C 3D 3E 25 20 0x27D0C8 : FF FF FF FF FF FF FF FF -> A3 24 A5 C9 E9 E8 F6 F1 0x27D0D0 : FF FF FF FF FF FF FF FF -> F2 C6 D8 C5 E6 F8 E5 DC 0x27D0D8 : FF FF FF FF FF FF FF FF -> FC F9 C4 E4 E0 00 00 00 0x4646F2 : E1 12 F0 6D -> DA C7 F0 D0 0x27D0F0 : FF FF FF FF FF FF FF FF -> E1 12 F0 6D 46 F6 1B 00 0x27D0F8 : FF FF FF FF FF FF FF FF -> 3D 04 D7 40 34 00 F2 F6 0x27D100 : FF FF FF FF -> 1A 3E DB 00 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Melody and Characters Group : Standard (1-5) : # @ \ & § (key #) Classical (1-18) : . , ? ! + - : " ' ; (key 0) * / ( ) < = > % (key *) Traditional (1-4) : space £ $ ¥ (key 1) Discreet (1-6) : É é è (key 3) ö ñ ò (key 6) Pop music (1-6) : Æ Ø Å æ ø å (key 9) If you want to modify them, just modify the values started from address 0x27D0B0 ... ~~~~~~~~~~~~~~~~~~~~~~~~~~ RizaPN Last edited by rizapn; 02-19-2003 at 00:40. |
02-14-2003, 12:53 | #42 (permalink) |
Member: 13636 Status: Offline Thanks Meter: 0 | i think, you don't really understand me. Of course I know, that you can play fast farward, but i think, that it is more usefull, to skip the titles instead of play fast forward or both functions ( shorttoch for skip and long touch for fast forward) for example: if you had love, to play a special song today I have a 128 mb MMC with 50 mp3-files!!! If i have play fast forward to find the song i like to hear, that i a long time, till i find the song! I hope, you understand me yet! @rizapn: is it possible? |
02-14-2003, 19:44 | #43 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Latvia, Riga Age: 46
Member: 20879 Status: Offline Thanks Meter: 0 | Hello Riza!!!! One more excellent patch, and bla bla bla!!! Any way, You ideas is as a small, but wery powerfull bullets You know, I am an SL user for a long time, but only now I have that comfort, what I was payed for Tell me please, isn`t better to make more groups, (not only VIP and STANDART) and make a Ringtone for each Group, as in S45 etc. ??? and GPRS |
02-14-2003, 23:07 | #44 (permalink) |
Member: 20879 Status: Offline Thanks Meter: 0 | Allredy patched works great.. From now I have 13 different ringing tones am I right ??? Or maybe it is more?? If I have understud the ASCII Sequence is: {.,?!+-:i"`;_} etc.... Ohh.. have an Idea.. need to try {*/{}=%~} etc. But now, names in adressbook seems a little bit uggly |
02-15-2003, 00:05 | #45 (permalink) |
Member: 13636 Status: Offline Thanks Meter: 0 | Hi, I have an idea to my ptt-problem: Can i change the fast forward to fast rewind (because if you put fast rewind during the play than the SL skip the title! @rizapn How can I change fast forward to fast rewind on the ptt-button? Another problem at the patch: Short # to unlock keypad, UP arrow and PTT button for VoiceDial when keypad is locked : When the keypad is locked and i put the ptt-button,than the illumination is without function. Why? |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
Problem to flash 7200! 2nd Boot Error | Maurone | Twisterflasher | 1 | 03-26-2005 18:17 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
Dead SLik.. Unknown flash type. Pls Help | Death_star | Siemens-Benq RingTones and WallPapers | 12 | 03-16-2003 00:30 |
Dead SLik.. Unknown flash type. Pls Help | Death_star | x1x to x45/x50 | 18 | 03-07-2003 17:13 |
