Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 01-30-2003, 15:14   #1 (permalink)
Member: 20543
Thanks Meter: 2
SLIKv56: Flash patches
I thought it would be great to list all the flash patches discussed in this forum. Some people have been doing some excellent work and it would be a shame to see it forgotten in a few weeks time.
We could keep the first post as a table of content, and each further post as an individual patch. Here are the first patches:
[list=1][*]Create new shortcut for Inbox SMS (located on the SIM card)[*]Create new shortcut for Outbox SMS (located on the SIM card)[*]Eliminate the additional "_nnn_nnn" string when moving SMS to the archive folder[*]Get access to "SIM Location" directly using front UP Arrow key[*]Add "Send via IrDA ..." options in CardExplorer[*]Overwrite "VoiceDialling" shortcut with "Display" shortcut[*]Overwrite "VoiceDialling" shortcut with "Illumination Toggle"[*]Use # short button to release the key-lock[*]Use * [GREEN] as an Illumination Toggle shortcut[*]Disable "Do you want to copy all SIM Card content to the phonebook" message when change SIM Card[*]Use * 0 and # followed by [GREEN] button as shortcuts[*]Use LEFT Arrow key as a "SIM-Location" shortcut[*]*NEW* Long press of left side [+] button for "Illumination Toggle" and its short press for IrDA[*]*NEW* Overwrite selectable "User Group" shortcut/hotkey with "Archive"[/list=1]
Instructions for fast modification without full-flash:[list=1][*]The patch shows at which address the bytes need to be changed. Each address is in the form: 0xYYZZZZ[*]Download the flash from address 0xYY0000 with a size of 0x10000 (use UniSiemens or other suitable software)[*]Save the downloaded block as a local file, name it sl45_YY.bin (use the actual digits instead of YY)[*]Open the file in your favourite hex editor (I use UltraEdit)[*]Navigate to address 0xZZZZ[*]Verify that the bytes to be modified have the correct value; if they don't, do not perform the patch: you might be using a different firmware version which requires a different patch or location[*]Modify the bytes as intructed in the patch[*]Save the modified flash file as sl45_YY.bin[*]Repeat the operation for any other location that needs to be modified until all the bytes have been changed. You might end up with more than one file[*]Upload the modified sl45_YY.bin file(s) to the phone at address 0xYY0000 with a size of 0x10000[/list=1]
The Following User Says Thank You to arman68 For This Useful Post:
Old 01-30-2003, 15:16   #2 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
* overwrite 'Profile' shortcut
* use your full-flash file
0x18E3AC : 2A 08 ==> 5A 03
0x18E3E0 : 0B 02 ==> D3 00
0x18E524 : 2A 08 2A 08 ==> 5A 03 5B 03
0x3AE412 : DA DF 94 4C ==> DA D9 EE 0A
For fast modification, if there is no full-flash yet, just download the flash from address 0x180000 with size 0x10000 and from 0x3A0000 size 0x10000 (partials). Name the first one as sl45_18.bin and the 2nd as sl45_3A.bin
Addresses to be modified from file sl45_18.bin is : and E3AC, E3E0, E524.
Address to be modified from file sl45_3A.bin is E412.
After the modification, upload sl45_18.bin to the phone at address 0x180000 with size 0x10000, and sl45_3A.bin to 0x3A0000 size 0x10000.
Old 01-30-2003, 15:18   #3 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
* overwrite 'Conceal ID' shortcut
0x18E38A : 49 ==> 92
0x18E3BE : 4A 01 ==> 69 00
0x18E416 : 49 01 49 01 ==> 92 01 92 01
0x3AE308 : DA DA 04 A3 ==> DA D9 F8 0A
0x18E38A is address in the full flash file, 49 is the original value(s), and 92 is the new value(s)...
Addresses to be modified from file sl45_18.bin is : E38A, E3BE, E416.
Address to be modified from file sl45_3A.bin is E308.
Old 01-30-2003, 15:19   #4 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
0x39FE5C : 88 60 F0 C8 ==> FA D9 02 FF
Old 01-30-2003, 15:21   #5 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
original:
0x3B0366 : EA 20 3C 04 48 C3 EA 20
0x3B036E : 3C 04 46 FC 20 00 EA 20
0x3B0376 : 5A 04 48 C6 EA 20 82 04
modify to:
0x3B0366 : 2D 6A 48 C3 2D 68 46 FC
0x3B036E : 20 00 2D 74 48 C6 EA 20
0x3B0376 : 82 04 46 FC 21 00 2D 7E
original:
0x3B0474 : E0 0C E0 0D E0 0E DA D4 AC 70
modify to:
0x3B0474 : DA DB 3C EF 0D 02 DA DB 46 EF
Old 01-30-2003, 15:22   #6 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
This patch will *overwrite* ---Help--- menu inside the Sort menu
with the new "Send via IrDA" options.
0x18A3E4 : 28 01 28 01 => 21 02 21 02 (change the text)
0x18A3FE : AE AB => A4 7D (change the function address)
Old 01-31-2003, 11:45   #7 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
Use Left side button [+] to access VoiceDialling.
0x18E3A0 : 4E 02 --> 60 00 (shorcut Start: text)
0x18E3D4 : 4F 02 --> 60 00 (upper-right button text)
0x18E4A6 : 4E 02 4E 02 --> 60 00 60 00 (menu item text)
0x3AE3B2 : DA E6 F8 A9 --> DA D5 6A F2 (function entry-point)
It will give the access to the "Display" menu directly.
Old 01-31-2003, 11:49   #8 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
0x18E3A0 : 4E 02 --> 82 00
0x18E3D4 : 4F 02 --> 82 00
0x18E4A6 : 4E 02 4E 02 --> 82 00 82 00
0x3AE3B2 : DA E6 F8 A9 --> DA DC 80 46
It can be used to assign a single button for doing Illumination Toggle as in SLCK firmwares.
Old 02-04-2003, 12:22   #9 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
0x3B07C4 : 1E -> 14
0x3B07C7 : 03 -> 04
0x3B07CA : 1F -> 21
0x3B07CE : DA A2 18 4C 48 40 2D 10 -> 0D 03 DA DA EC F6 0D 0F
If you want to use * instead of #, modify 0x3B07CA with 13.
For other button, use the value listed in the button code table.
* That patch also unhides a VoiceDial function * Press UP arrow key when the key is locked to activate the VoiceDial function. If you want to use another button, just modify the value in 0x3B07C4 with the listed button code.
Button Code:
5C : UPPER LEFT
05 : GREEN
01 : RED
03 : UPPER RIGHT
22 : RIGHT ARROW
20 : DOWN ARROW
21 : UP ARROW
23 : LEFT ARROW
13 : *
14 : #
15 : DIGIT 0-9
1F : LONG #
0E : LEFT SIDE +
0D : LEFT SIDE -
62 : LEFT SIDE PLAY
Old 02-04-2003, 12:27   #10 (permalink)
Member: 20543
Thanks Meter: 2
Use[*][GREEN] as an Illumination Toggle shortcut
Firmware: SL45 v56
Author: RizaPN
0x3AD7A4 : E6 FC 0A 00 E6 FD 36 00 -> E6 00 36 00 F3 FC 0A 00
0x3AD7AC : DA DB 00 30 48 40 3D 21 -> 47 FC 2A 00 3D 04 DA DC
0x3AD7B4 : E6 00 36 00 CC 00 -> 80 46 EA 00 04 DA
If you want to use 0[GREEN], just modify 2A (0x3AD7AE) with 30.
If you want to use #[GREEN] use 23 ...
Old 02-04-2003, 12:29   #11 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
0x44EB9E : 3D -> 0D
Old 02-04-2003, 12:35   #12 (permalink)
Member: 20543
Thanks Meter: 2
Use[*] [0] and [#] followed by [GREEN] button as shortcuts
Firmware: SL45 v56
Author: RizaPN
0x3AD7B2 : 2D 19 -> 2D 12
0x3B3000 : F0 ED 70 EC 2D 0B DC 4D -> E0 14 27 FC 23 00 3D 03
0x3B3008 : A9 2C 47 F2 -> DA D8 B4 E1
([#] button function)
0x3B300C : 30 00 2D 06 47 F2 -> 0D 09 29 C7 3D 03
0x3B3012 : 2A 00 2D 03 -> DA DC 80 46
([*] button function)
0x3B3016 : 47 F2 23 00 3D 02 -> 0D 04 29 C6 3D 03
0x3B301C : E0 04 DB 00 -> DA D9 62 0A
([0] button function)
0x3B3020 : E0 14 DB 00 -> E0 04 DB 00
It will assign :
[#][GREEN] as a shortcut to "Java",[*][GREEN] as a shortcut to "Illumination Toggle",
[0][GREEN] as a shortcut to "Write Message" ...
Remark: if you already apply patch : "[*][GREEN] as an Illumination Toggle shortcut" then you need to reset some addresses back to their original values.
Old 02-04-2003, 12:38   #13 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
* If you already apply patch for UP Arrow as a "SIM-Location" shortcut, and want to apply this patch, please reset them back to the original values *
[font=courier new]
0x3B03B0 : EA 20 0A 05 46 FC 14 00 -> 8D 04 46 FC 15 00 EA F0
0x3B03B8 : EA 20 0A 05 46 FC 15 00 -> 0A 05 46 FC 23 00 2D 5D
0x3B0474 : E0 0C E0 0D E0 0E -> DA DB 3C EF 0D 02
0x3B047A : DA D4 AC 70 -> DA DB 46 EF
[font]
Old 02-04-2003, 12:39   #14 (permalink)
Member: 20543
Thanks Meter: 2
Use RIGHT Arrow key as a "Card-Explorer" shortcut
Firmware: SL45 v56
Author: RizaPN
It will overwrite the previous function (entered to the Main Menu)
0x3B0368 : 3C -> 54
0x3B0450 : F0 C4 DA E5 -> EA 00 EE 07
0x3B0454 : 24 3A EA 00 F4 07 -> DA D8 CA E1 0D 23
Old 02-06-2003, 10:26   #15 (permalink)
Member: 20543
Thanks Meter: 2
Firmware: SL45 v56
Author: RizaPN
0x3B04A4 : DA A2 18 4C 48 40 EA 20 -> DC 59 98 C8 A8 D8 DC 4D
0x3B04AC : F6 07 DC 59 -> D4 8C 04 00
0x3B04B0 : 98 C8 A8 D8 DC 4D -> 46 F8 EB 00 2D 03
0x3B04B6 : D4 8C 04 00 -> DA DC E8 46 ... (*)
0x3B04BA : 46 F8 EB 00 EA 30 F6 07 -> 0D 07 E0 1C E6 FD 82 00
0x3B04C2 : E0 1C DA F0 -> DA E6 98 F1
0x3B04C6 : 50 83 EA 00 -> DA DC 80 46
0x3B04CA : D6 07 -> 0D 0B
* Known bug : IrDA will also toggled for long-press ...
If you want to apply this patch withour IrDA capability, use :
0x3B04B6 : D4 8C 04 00 -> CC 00 CC 00 ... (without IrDA)
SLIKv56: Flash Patching (3rd part) ... rizapn x4x, x5x Flashpatching 2900 12-24-2007 10:51
TOC for Sticky: SLIKv56: Flash patches. StevieRay x4x, x5x Flashpatching 17 10-15-2005 08:26
"Bugs" in Thread SLIKv56: Flash patches trustkill Siemens-Benq Flash Patching 2 07-13-2004 07:33
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Where can i download riza's SLIKv56: Flash Patching (3rd part) Gabriel_he Siemens-Benq Flash Patching 2 04-04-2003 03:20
Page generated in 0.30501 seconds with 11 queries
