11-12-2005, 08:54 | #526 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | ; ; (c) abomin 12.11.05 ; Undo previous version. #pragma enable old_equal_ff 224750: DAC21E48 DAE0C6C7 ; unplug HF - profile 0 224782: DAC21E48 DAE0A0C7 ; connect HF - profile 1 0x40C7A0: D7400D00F2FD8864E6000E00CC00F6FD 0x40C7B0: 58BFF6FC56BFE6FC0303D7400D00F6FC 0x40C7C0: 8864FAA44A98E6000E00CC00F2FD56BF 0x40C7D0: 48D23D07F2FC58BFF6FD58BFF68E56BF 0x40C7E0: 2DECF6FD58BFF6FC56BFDB00 40C7B8: 0303 0101 ; wished profile ;----------------------------------------- |
11-13-2005, 14:45 | #528 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | ; EBIN FAM3.2/BFA2.2 Patch2Patch (C)2005 by Rst7/CBSIE ; ; Need FAM3.2 and BFA2.2 patches ; ; Apply after EBIN, don't undo EBIN! ; ; For original BFA2.2 0x447388: E085E004FAE4F87F F0ECF0FDFAE49849 ; ; For BFA2.2b - readressed to 0x4F3640 ;0x447388: E085E004FAE4F87F F0ECF0FDFAEF4836 ; ; For details of "EBIN.Entry points for binary file" see this thread: ; http://forum.gsmhosting.com/vbb/show...&postcount=417 |
11-17-2005, 23:39 | #529 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Poznan, Poland Age: 37
Member: 94448 Status: Offline Thanks Meter: 0 | Playlist Converter v.1.0 Add a posibility to convert Winamp m3u file into Siemens mpl playlist. http://www.geocities.com/sc0typl/bin/bin_playconv.zip Last edited by sc0ty; 11-17-2005 at 23:49. |
11-25-2005, 12:11 | #530 (permalink) |
Member: 94448 Status: Offline Thanks Meter: 0 | Playlist Converter v.1.2 Add a posibility to convert Winamp m3u file into Siemens mpl playlist. New wersion 1.2 - convert also XMPlay playlist (pls) http://www.geocities.com/sc0typl/bin/bin_playconv.zip |
11-26-2005, 23:37 | #531 (permalink) |
Member: 94448 Status: Offline Thanks Meter: 0 | Playlist Converter v.1.3 Add a posibility to convert Winamp m3u file into Siemens mpl playlist. New wersion 1.3 - you can change drive letter to a:\ http://www.geocities.com/sc0typl/bin/bin_playconv.zip |
11-27-2005, 00:17 | #532 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | Ted Damn ! I don´t know the reason why no one published TED (Text viewer/Editor) here... It is a nice .txt reader and works very good ! All you need is FAM32, FTA2 & ESI. A big "Thank you !" to Rst7//CBSIE. What about "ä,ü,ö,ß" ??? |
11-28-2005, 12:48 | #533 (permalink) |
Major Poster Join Date: Oct 2005 Age: 48
Member: 187352 Status: Offline Thanks Meter: 0 | ;**** block digits + # key combination v2.0 ; ; Firmware: SL45i v56 ; Author: greenteas ; v2.0 ;If you use the"KLP v1.2 3in1",you can find a bug:block digits + # key will in sim-location.this patch v2.0 Modification it. ;Pls undo v1 2D9EE: 3D 0D vkp: 0x02D9EA: 47F22300 DABF30B9 0x1FB930: FFFFFFFFFFFFFFFF 88C0DAA3924098C0 0x1FB938: FFFFFFFFFFFFFFFF 48402D0347F22300 0x1FB940: FFFFFFFFFFFFFFFF 0D0247F2FF00DB00 |
11-28-2005, 15:15 | #534 (permalink) |
Member: 187352 Status: Offline Thanks Meter: 0 | *** move softkey text Position *** ;FirmwArE: SL45v56 ;Author: sOLO&greenteas ;Created: 2005-11-28 0x20DFDC: E016 CC00 0x20DFB0: 26F01C00 DAE000C8 0x40C800: FFFFFFFFFFFFFFFF D7400E00F2F1423A 0x40C808: FFFFFFFFFFFFFFFF 9AF10450E0068018;50-function 6 0x40C810: FFFFFFFFFFFFFFFF CD01E02626F01C00 0x40C818: FFFF DB00 ;Like this |
11-28-2005, 16:56 | #535 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | *** Move softkey text position v1.1*** ; Firmware: SL45v56 ; Author: sOLO&greenteas ; Created: 2005-11-28 ; moved to free (i hope) area by trustkill ; (does not collide with "Midlets through entrypoints") ; 0x20DFDC: E016 CC00 0x20DFB0: 26F01C00 DAE070C9 0x40C970: FFFFFFFFFFFFFFFF D7400E00F2F1423A 0X40C978: FFFFFFFFFFFFFFFF 9AF10470E0068018;70-function 8 0x40C980: FFFFFFFFFFFFFFFF CD01E02626F01C00 0x40C988: FFFF DB00 |
11-28-2005, 23:07 | #536 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | ; *** ###. ### -> MainMenu Everywhere *** ; Idea - from x65 devmenu ; Author: seklth ; Firmware Sl4x v56 ; Press three "#" to enter menu wherever you are ! ; 0x21EAC0: 3D02E108 DAF2B0FF 0x52FFB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D05E108DB00DAC1C6EADB00DAA39240 0x52FFC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48402DF9E6000E00CC00C2FCB539BB12 0x52FFD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DF2BB0B3DF0BB093DEEF3F4B5B90941 0x52FFE0: FFFFFFFF F7F4B5B9 0x52FFE8: FFFFFFFFFFFFFFFF 0DE448C03D02E6FC 0x52FFF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 160028C2F42CB73947F22300CB00 ; ; calls Main_Menu_create ; 0x52FFE4: FFFFFFFF DADBC440 |
11-29-2005, 09:58 | #537 (permalink) |
Junior Member Join Date: Sep 2003 Age: 42
Member: 40477 Status: Offline Thanks Meter: 0 | ; *** INA. Inproved Net Indicator Antenna Symbol Addon*** ; Firmware: SL45v56 ; Author: thE prEtEndEr ; Release: November 29, 2005 ; This patch adds a small antenna symbol right before the ; Improved Net Indicator bars. ; You will need Improved Net Indicator patch and ; A1P patch (only when using image #817) ; Change 0x40CA04 to use another image than #817 ; change hooks of Net Indicator to new location 0x454BD0: DAC1EC22 DAE002CA 0x3B36EA: DAC1EC22 DAE002CA ; draw antenna symbol 0x40CA02: FFFF E6FE 0x40CA04: FFFF 3103 ; 331h = image #817 (need A1P) 0x40CA06: FFFF E00C 0x40CA08: FFFFFFFFFFFFFFFF E6FD3A00DAC1EC22 ; sorry, I forgot to add these two lines ; adjust position of first indicator bar to have free space ; for antenna symbol 0x40CA15: 0C 6C ; xC -> x-position 0x40CA81: C0 C6 ; Cx -> x-position (need to change both values) ; ##### Picture 817 (Antenna Symbol) ##### 4BBE3E: 010101000000FC02 06090100E600EC02 1B00E6: FFFFFFFFFFFFFFFFFF 038BAB73232373FB03 Last edited by thE prEtEndEr; 11-30-2005 at 13:08. |
11-30-2005, 16:43 | #538 (permalink) |
Member: 40477 Status: Offline Thanks Meter: 0 | ; *** Invert Display Hotkey (and/or when keylocked) v3*** ; Firmware: SL45v56 ; Author: trustkill ; Homepage: www.gsm-modding.de ; Release: June 26, 2004 ; v2 -> rc-flitzer (September 25th, 2005) ; improvements ; v3 -> thE prEtEndEr (November 30th, 2005) ; now works with auto keylock mode, too ; Please undo previous versions. ; With this patch you have a hotkey for "Invert Display" ; instead of "User Group". It overwrites the patch "Flip Screen Hotkey" ; from arsh0r, you better undo that patch before. ; You can choose if you want invert display when keylocked. ; This patch also works with KLP (Keypad Locked Password) patch. ; Greetz to trustkill and rc-flitzer for their great job. ; Invert both softkeys & Display when APP Function 1 is selected, ; needs at least JAF.Funny Display & ISK.Invert Softkey selectable. ; Comment these two lines, if you don't have installed ISK or ; if you don't want inverted softkeys ; 0x27D6CB: C0 00 ; changes ISK app function no. from #13 to #1 ; 0x27D6E1: C0 00 ; changes ISK app function no. from #13 to #1 ; Hotkey Patch ; If you don't want to change "User group" to "Invert", comment following block 0x18E388: 8B00 A804 ;string #8B -> #4A8 0x18E3BC: 8C00 A804 ;string #8B -> #4A8 0x18E4B8: 8B008B00 A804A804 ;same thing 0x3AE310: DAD70245 DAC798E0 ;call to patch ; Invert Display when keylocked ; (More exact: changing App-function #1 when key locked/unlocked) ; If you don't want invert display when keylocked, comment these three lines 0x3AF6E2: DAA37A40 DAC7B8E0 ; --> call to patch before unlock 0x3AD292: E6003600 DAC7ACE0 ; --> call to patch if locked by # 0x3B02B2: DAA37440 DAC7A8E0 ; --> call to patch if auto keylocked ; Main patch block 0x27E098: FFFFFFFF D7400E00 ; extp #0Eh #1 0x27E09C: FFFFFFFF F2FC423A ; mov r12, mem_3A42 0x27E0A0: FFFFFFFF 9AFC1300 ; jnb r12.0, loc_C7E0CA 0x27E0A4: FFFFFFFF FAC7C4E0 ; jmps 0C7h, loc_C7E0C4 0x27E0A8: FFFFFFFF DAA37440 ; call auto keylock 0x27E0AC: FFFFFFFF D7400E00 ; extp #0Eh #1 0x27E0B0: FFFFFFFF F2FC423A ; mov r12, mem_3A42 0x27E0B4: FFFFFFFF FAC7CAE0 ; jmps 0C7h, loc_C7E0CA 0x27E0B8: FFFFFFFF DAA37A40 ; calls unlock 0x27E0BC: FFFFFFFF D7400E00 ; extp #0Eh #1 0x27E0C0: FFFFFFFF F2FC423A ; mov r12, mem_3A42 0x27E0C4: FFFF 0EFC ; bclr r12.0 0x27E0C6: FFFFFFFF FAC7CCE0 ; jmps 0C7h, loc_C7E0CC 0x27E0CA: FFFF 0FFC ; bset r12.0 0x27E0CC: FFFFFFFF D7400E00 ; extp #0Eh #1 0x27E0D0: FFFFFFFF F6FC423A ; mov mem_3A42, r12 0x27E0D4: FFFF DB00 ; rets |
12-01-2005, 14:39 | #539 (permalink) |
Member: 40477 Status: Offline Thanks Meter: 0 | ; *** INA. Inproved Net Indicator Antenna Symbol Addon (corrected)*** ; Firmware: SL45v56 ; Author: thE prEtEndEr ; Release: November 29th, 2005 ; Update: December 1st, 2005 ; The 1st version was optimized for a modified version of net indicator. ; This update should work with the common patch version. ; This patch adds a small antenna symbol right before the ; Improved Net Indicator bars. ; You will need Improved Net Indicator patch and ; A1P patch (only when using image #817) ; change hooks of Net Indicator to new location 0x454BD0: DAE010CA DAE004CA 0x3B36EA: DAE010CA DAE004CA ; adjust position of first indicator bar ; to have free space for antenna symbol 0x40CA15: 0C 6C ; xC -> x-position 0x40CA81: C0 C6 ; Cx -> x-position (need to change both values) ; draw antenna symbol 0x40CA04: FFFF E6FE 0x40CA06: FFFF 3103 ; 331h = image #817 (need A1P) 0x40CA08: FFFF E01C ; xC -> x-position 0x40CA0A: FFFF E00D ; yD -> y-position 0x40CA0C: FFFF DAC1 0x40CA0E: FFFF EC22 ; ##### Picture 817 (Antenna Symbol) ##### 4BBE3E: 010101000000FC02 06090100E600EC02 1B00E6: FFFFFFFFFFFFFFFFFF 038BAB73232373FB03 |
12-01-2005, 18:47 | #540 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | ; Speed up the animation of the Waiting Icon ; Author: dingol ; Date: 2004.11.6 ; Change to 10 frames from originally 5 frames per second ; Ported from SL45 5508 to SL45v56 by trustkill ; 0x1A21AE: C8 64 ;can change to 32, which may be too fast. The ultimate speed is 01. 0x1AF84E: C8 64 0x1AF87A: C8 64 |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
