Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x6x and x7x Flashpatching
x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones).
Old 03-29-2005, 20:20   #1 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
SL65 Bootloader JAVA patcher ?
Hi again,
Tried to patch the bootloader on SL65 by x65 JAVA patch, but it seems that not work. Says "java.lang.ArrayIndexOutOfBoundsException"
I´m forgetting something, or is not for all x65? Or I´m using wrong patch?
Thanks for any help
Old 03-31-2005, 02:14   #2 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
No one can help ?
Old 03-31-2005, 11:47   #3 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
Contact me private!
Maybe I can help you!
Old 04-09-2005, 12:54   #4 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Ok, solved it... finnaly patched the boot
Once again, thank you Chris
Old 04-18-2005, 06:10   #5 (permalink)
Member: 86213
could you post it here how u solvedit?
br fedjak
Old 04-18-2005, 12:23   #6 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
You need to downgrade the phone version.
Old 04-18-2005, 22:11   #7 (permalink)
Member: 55536
If You can downgrade firmware version, then You don't need patch bootcore - You don't need patch bootcore at all!
Use BootPassword method.
Old 04-18-2005, 22:55   #8 (permalink)
Member: 56961
Thanks Meter: 5
I see sl65 v41 and i cann't download the version, how can i unlock?
Old 04-19-2005, 04:18   #9 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
You can downgrade without touch in the bootcore, but to use with 3rd party tools u need to "touch" on bootloader otherwise no sw will recognize the boot of your phone. And this means, no unlock / read&write full flashes or partials.
This is why u need to patch the bootcore.
Of course that to downgrade you can only use Winswup updates no need to patch anything. But to read full flash for example, need to have bootcore patched to some 3rd party sw can recognize the phone and actually read a full flash (around 33MB).
@Widel
You must downgrade version, I advice lower then or v16 at least.
Old 04-19-2005, 08:23   #10 (permalink)
Member: 56961
Thanks Meter: 5
But the mobile denied the action to download i used winswup 25 and the mobile denied me always
Old 04-19-2005, 13:49   #11 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Try using v16 or lower. And make sure u use correct cable.
Old 04-19-2005, 13:54   #12 (permalink)
Member: 56961
Thanks Meter: 5
ok, thks i try it and i will say here
Old 04-20-2005, 00:15   #13 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
If can´t find correct swup versions, look here:
http://forum.gsmhosting.com/vbb/show...highlight=SL65
Old 04-21-2005, 01:42   #14 (permalink)
Member: 56961
Thanks Meter: 5
thks inow i need wait i have one siemens :P
Old 04-22-2005, 09:22   #15 (permalink)
Member: 56961
Thanks Meter: 5
i used this file CX65160400.xbz_update.exe and denied too
CF75 unlock java patcher?? pegonlo S-Gold Based Phones 22 12-19-2008 13:42
Java Patcher + Boot Pass Questions ?? mbcommunication SST-Dongle 5 02-17-2006 17:43
cf75 java patcher, please sst check gsmuy SST-Dongle 0 01-12-2006 12:55
cf62 can be unlock with java patcher? robertogsm E-Gold Based Phones 5 12-13-2005 09:48
java patcher koko12 Siemens-Benq RingTones and WallPapers 0 03-12-2005 12:54
Page generated in 0.27157 seconds with 10 queries
