X6x Flash patching(THE Thread for discussing) : This is thread for discussing about flash patching for siemens x6x. WBR Zdob |
hi im new. but pls tell me is the test point necessary for a c60 for it to be patched?can it be done without?what exactly does this testpoint and track cut do? |
C60 increase flex memory Hi ! I was trying to patch C60 fw25 with more flex mem patch, but this not worked! Anyone know how to have this patch realy works? incflex3.vkp http://vi-soft.com.ua/forum/index.ph...d=2317&index=0 Some good translation from russian to english needed! Please help! |
where is any working patch for c60? example. debug patch? anyone knows the memory map? i tried discover the memory map from a full backup: 00.0000 - 1f.ffff 2048K firmware 20.0000 - 2b.ffff 768K FFS_B - b:\ 2c.0000 - 4f.ffff 2304K ??? code ??? 50.0000 - 6f.ffff 2048K FFS - a:\ 70.0000 - 7f.ffff 1024K not used 80.0000 - 87.ffff 512K RAM ??? 88.0000 - bf.ffff 3584K hole C0.0000 - f7.ffff 3584K ??? code ??? f8.0000 - fb.ffff 256K not used fc.0000 - ff.ffff 256K "eeprom" area i don't understand why sad some programs the firmware is 0x000000 - 0x200000 because i found codes on other locations like 0x2c0000 - 4fffff and on others see above... |
what is that 'java class verification' ? |
I don't have a x60 mobile (i just run into this thread) Anyway in SL45 and i presume in all mobiles, java class verification is a process that actually verifies that the jar file contains a java midlet. If the jar file is a jre (pc) application, then the java class verification will not launch the midlet. Generally in Sl45 we disable java class verification, because it speeds up the loading proccess around 70%. However some midlets will not start without it. (This is because some java bytecodes must be changed by the javaclass verification routine before running) (an example of such a midlet is jubble bobble - must be something like this for x6x) |
which are the files in siemens phone? how many memory there are inside? how can i write all memories. i flash my c62 with different versions and "flash programmer" says "succesfully" every time but phone is still dead. i think i need to write files or memories inside the phone that now with flash programmer i'm not writing. many persons have problem like this and much of them loose patience on it...i'm on the way. help! |
please i need java patch for a60 v10 thanx all |
hi, everybody .. I need to know new X65 model can branding change and how!! |
Confirm switch on Hi guyes, Please, patching c60 flash file can cancel Confirm switch on ? I have problem with this left menu key ! Regards Laser |
Please darling post some simple Patch to enable Net Monitor in Cx65 series... I NEEEEEEEEEEED to Live Siemens! bob http://digilander.libero.it/m_50 |
I have been trying to upgrade my CX65 with winswup32 (160100_eng.exe) with my SIEMENS SERIAL cable, but I kept recieving the message: Error on waiting for Ack EOT Is there anyone who can suggest a solution to this? Thanx in advance lads... |
Hi.I need patch that make more faster for deskey soft like sl45 patch by Mamaich. IS there anybody know c55,c60 communication transfer rate for file download,upload by Deskey soft by Siemens to pc? 56k or 115k? Is there exist any patch make it faster like Mamaich patch for sl45i? Thank you. |
MC60 Siemens I have a new MC 60 phone. I have Freija 15, and i cut de wire from the CPU. Now, my phone is stil unlocked and i can not use *0# anymore. what did i do wrong? :( |
First phone must be full charge, second phone must be close and right side stand 2option and u must click them, than must be updated. www.gsmflasch.com |
