03-30-2006, 21:31 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 45
Member: 66871 Status: Offline Thanks Meter: 34 | vodka update failed help me.. > Waiting for clip ! > Ack received ! > Genuine Vodka HW detected. > Programming empty Vodka HW. > Connecting ... > Connecting to 217.xxxxxxxx > Connected. > Checking login ... > Device SN: 0071xxxxxx > Waiting data from server ... > Received ... > Waiting data from server ... > Received ... > Flashing FS ... > Operation failed ! > Disconnecting. > Disconnected. |
03-30-2006, 21:59 | #2 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | Quote:
Br | |
04-01-2006, 10:45 | #3 (permalink) |
Member: 66871 Status: Offline Thanks Meter: 34 | i have one more clip when i connect that clip it easily can be updated with the same internet connection and same voltage ! That's the point that i can not figure it out .. i will be waiting for suggestions , Last edited by gsmrepair1; 04-01-2006 at 11:01. |
04-01-2006, 11:01 | #4 (permalink) |
Member: 66871 Status: Offline Thanks Meter: 34 | i have one more clip when i connect that clip it easily can be updated with the same internet connection and same voltage ! That's the point that i can not figure it out .. i will be waiting for suggestions , |
04-01-2006, 11:32 | #5 (permalink) | |
Br | |
04-05-2006, 07:24 | #6 (permalink) |
Junior Member Join Date: Oct 2004 Location: UK
Member: 88101 Status: Offline Thanks Meter: 1 | Hi, I too had a failed update last night. At the end i get a "bad CRC . operation failed". I have tried on 2 other PC's and the same result. Does this sound like a faulty unit also. Thanks... WBR FM |
04-05-2006, 15:44 | #7 (permalink) | |
Br | |
04-05-2006, 16:20 | #8 (permalink) | |
Member: 88101 Status: Offline Thanks Meter: 1 | Quote:
Had i of used a battery i might of agreed with you. I used a 9v regulated supply which i used when i first updated clip and there was no problem then. Any other ideas ..?? WBR | |
04-05-2006, 17:48 | #9 (permalink) | |
Br | |
04-05-2006, 17:55 | #10 (permalink) | |
Ok thanks for reply. I have just tried again with a 2A regulated supply and still i get <bad CRC ! <operation failed Serial No is AAAAAAAAA I try with the reseller Allgsm for exchange. WBR Last edited by .:hack3r2k:.; 04-05-2006 at 19:32. | |
04-05-2006, 19:32 | #11 (permalink) | |
Br | |
04-14-2006, 00:36 | #12 (permalink) | |
Have had clip replaced, now unlocks fine but makes a miserable attempt at speaking , it is very quiet and garbled. I'm not certain i want to try reflashing it after the last attempt failing. What is the solution now ?. Is it possible to get a fully working replacement ?. WBR | |
Smartclip died during update, now every update fails | smartmod.de | Smart-Clip | 41 | 01-09-2008 17:01 |
update fail .please authorize to update | zeozea | Smart-Clip | 1 | 10-02-2007 10:11 |
Vodka Update Error | aaneel | VoDKA-CLIP | 2 | 03-16-2006 21:31 |
re Vodka updating ? | Faxman | VoDKA-CLIP | 3 | 01-02-2006 00:41 |
