WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
01-13-2005, 09:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Croatia ( Zagreb ) Age: 45
Member: 6247 Status: Offline Thanks Meter: 0 | 9500 charging I readed that 40% of this phones have this foult but can someone please write here how this is posible that 40% of this phones have this and others not, because all have the same battery, same firmaware and same charger. I tryed on 3 chargers and it is allways the same and i noticed that when i unplug it from charger before charging is comlete it shows 3/4 battery level and after some time 20min it shows full battery.. Regards, Mali ( Kruno ) |
01-13-2005, 10:33 | #2 (permalink) |
Member: 6247 Status: Offline Thanks Meter: 0 | after google and gsm forums there is some solution for this: before charging mobile must reboot with reboot software.. I will test this next time when i need charging.. but if this is the problem than it is firmware bug and i hope it will be solved in next update. Regards, Mali ( Kruno ) |
01-18-2005, 16:04 | #3 (permalink) |
Member: 6247 Status: Offline Thanks Meter: 0 | i tested this solution and it works... If your 9500 newer ends charging, just reboot it before you conect phone to charger... you can use this software ( its free ) http://www.romankeller.ch/pafiledb/p...=download&id=2 Best Regards, Mali ( Kruno ) |
07-12-2007, 08:23 | #5 (permalink) |
No Life Poster Join Date: Sep 2006 Location: in the office Age: 38
Member: 352329 Status: Offline Thanks Meter: 38 | BROTHER http://www.romankeller.ch/pafiledb/p...=download&id=2 LINK IS NOT WORK DO U HAVE ANOTHER ANY SOLUTION????????????? THANKS |
samsung e330 problem charge? | cerimobil | Samsung Hardware Repair | 1 | 08-01-2012 10:40 |
9500 charging problem | alex yong | BlackBerry (RIM) | 2 | 07-27-2011 19:43 |
Need Blackberry 9500 Charging Ways | Sydney_Unlocker | BlackBerry (RIM) | 0 | 12-20-2009 01:17 |
nokia 9500 charging ways pls>>>> | hiteshhitesh | Nokia Hardware & Hardware Repair | 3 | 10-27-2008 16:54 |
9500 charging | linekbp | Nokia Hardware & Hardware Repair | 2 | 07-07-2007 06:09 |
