WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
08-02-2005, 06:34 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Age: 43
Member: 164834 Status: Offline Thanks Meter: 2 | Nokia 6260 white screen |
The Following 2 Users Say Thank You to Toner0 For This Useful Post: |
08-03-2005, 17:42 | #3 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
try to pick right flash files n try again. Goodluck BR. | |
The Following User Says Thank You to Afzaal For This Useful Post: |
08-04-2005, 13:59 | #4 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | try to call if phone is working fine but white display hehehehe u have used the defective flex replacement......hint use original with black coating |
The Following User Says Thank You to benguetcowboy1 For This Useful Post: |
08-06-2005, 18:50 | #7 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 36
Member: 137928 Status: Offline Thanks Meter: 7 | hey all ive got n 6260 it shows mmc card currupt.even some times when mmc card is not in the problem is in the phone i guess so coz this card works perfactly with other handsets just not with this 6260 anyways thank u |
The Following User Says Thank You to i_m_dhruv2001 For This Useful Post: |
08-07-2005, 09:31 | #8 (permalink) |
Freak Poster Join Date: May 2005 Age: 49
Member: 148029 Status: Offline Thanks Meter: 9 | if its call going and coming flex trouble. i got one like same. first edge a little cutting flex i give one copper wire it was ok . so pls compire the connections with other one. good luck |
The Following 2 Users Say Thank You to abdullatheef For This Useful Post: |
03-13-2006, 22:57 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | I'VE TESTED ONE LIKE THAT WITH REMOVING THE ENGINE TO ANOTHER GOOD WORKING 6260 & its STILL WHITE. But when i put another Engine to the white screen, It displays great. SO, THE PROBLEM IS FROM ENGINE 10000000000000000% But is it: - SOFTWARE OR - HARDWARE in the engine? THAT IS THE QUESTION. |
The Following User Says Thank You to gambitjam For This Useful Post: |
03-23-2006, 01:07 | #11 (permalink) | |
Member: 113732 Status: Offline Thanks Meter: 90 | Quote:
I tested my board with another working phone & still white. & took a good working Board to my phone & my screen works good with my flex. So the problem is with Board. But i can receive & call with my Board. It most be the coonector head on the board or an ic on the board? But 100% is the BOARD. | |
07-04-2006, 08:15 | #13 (permalink) |
Major Poster Join Date: Jan 2005 Age: 54
Member: 104844 Status: Offline Thanks Meter: 0 | 6260 Nokia power on Nokia logo after 4 second white screen of my nokia 6260 when power on startup nokia logo after 4 second white screen. I change the flex cable and change good LCD,UEM also sw flash. rewrite rpl and formeting User area. But nothing result. in this time what to do now ? |
07-04-2006, 13:12 | #14 (permalink) |
Junior Member Join Date: Oct 2005
Member: 194812 Status: Offline Thanks Meter: 4 | 6260 White Screen I have encountered such problem with 6260. It flashes, but afterwards it is still white screen. What I did was to download the latest flash file and flashed it again. Problem Solved. |
03-17-2007, 19:56 | #15 (permalink) |
Freak Poster Join Date: Mar 2006 Location: india
Member: 239231 Status: Offline Sonork: 100.1615723 Thanks Meter: 110 | 6260 only nokia logo on startup i have a nokia 6260 it shows nokia logo on startup n no other function plz if anyone can help i worked 4 flashing on MT-BOX but it give me the error of BOOT UP FAILURE n tried on twister but the error was 1st Boot Err: Bad Resp UPP, 02 FF FF 72 1st Boot Err: Bad Resp DCT3 Rebooting Mobile thx in advnce |
6260 white screen then 15 sec turns off | sharkie2006 | Nokia Hardware & Hardware Repair | 3 | 09-28-2009 11:32 |
Nokia 6260 White Screen | ThongGSM | Nokia Hardware & Hardware Repair | 5 | 06-06-2008 08:05 |
6260 White Screen problem | wurmz | WD2 & APE (Symbian Phones) | 1 | 04-04-2006 01:22 |
Nokia 6260 white screen, but not after flashing... | vatera9 | WD2 & APE (Symbian Phones) | 0 | 03-26-2006 09:46 |
6260 white screen | jenlaire | Nokia Hardware & Hardware Repair | 3 | 02-21-2006 22:07 |
