WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
09-30-2007, 18:56 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | 7610 hang on nokia I format user area.but nothing. then erased and flashed with the latest flash files available. then write pm and ui setting. but nothing then disassemble the phone and wash with ctc but nothing then give some heat to flash ic and then repeat the flash process again but no changes.what should i do now. |
10-01-2007, 00:10 | #2 (permalink) |
Freak Poster Join Date: Mar 2004 Location: United Arab Emirates Age: 33
Member: 60500 Status: Offline Thanks Meter: 2 | try to use the erase file in the mcu and ppm...then flash the phone again with new version...and upload good pm and unlock it just and then chek the phone and if phone not ok and gives contact retailer so then make full factory setting and format user area if needed....hope this solution will work for you. and if you are using UFS then try on other tools lik MT box or JAF. BR Muneer Ahmed |
10-02-2007, 07:18 | #3 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | Quote:
bro, try to reheat cpu may helpful to you | |
10-02-2007, 07:28 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
today im tested solusion it work white display and goo off and show only nokia not open mobiles ect..... | |
The Following 3 Users Say Thank You to .::AZEEM::. For This Useful Post: |
10-02-2007, 11:39 | #6 (permalink) |
Member: 60500 Status: Offline Thanks Meter: 2 | Flash the phone with the chines version of flash file first and then check it because 80% of this problem is software and if it is not ok then the problem is hardware. In hardware you need to rehot the RAM ic otherwise change that ic and phone will be 100% ok and working. It is tested. BR Muneer Ahmed |
08-11-2009, 08:26 | #9 (permalink) |
Junior Member Join Date: Dec 2008
Member: 926051 Status: Offline Sonork: Blind Thanks Meter: 5 | I have the same prob...that I have Flashed with the last version....>>> Still the same. any idea? I 've follow Mr..::AZEEM::.'s way. the same too..... Last edited by Br_LEE; 08-11-2009 at 08:32. |
08-25-2009, 13:44 | #10 (permalink) |
Freak Poster Join Date: Nov 2007 Location: parungpanjang.BOGOR.Indonesia Age: 42
Member: 631494 Status: Offline Sonork: 1640748 Thanks Meter: 26 | first erase flash ic manual or full erase, then full flash if still failed, chek local mode if ok, chek imei, rehot RAM ic, last change zocus ic, good luck |
7610 hang on logo | ata_evanescence | Nokia Hardware & Hardware Repair | 27 | 11-19-2010 05:22 |
7610 hang on NOKIA | williamvirk | Nokia Hardware & Hardware Repair | 17 | 10-24-2010 07:45 |
7610 Hangs On Battery Signal | mobile_mania | Nokia Hardware & Hardware Repair | 0 | 09-01-2008 09:07 |
7610 hang on whit any slotion | mateenskl | Nokia Hardware & Hardware Repair | 3 | 12-10-2007 16:46 |
7610 hangs on nokia ( 4x blink) | Moosani | Twisterflasher | 2 | 07-14-2005 02:53 |
