Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 07-13-2004, 04:48   #1 (permalink)
Member: 60372
Error Flashing 6600
After Flashing 6600 with 6600_fullerase.fia this error appear..
Cannot Detect Mobile Brand
1st Boot Ok, WD2, UPP: 0082
2nd Boot Ok, FLID: 002088BE, St M28W640
Algorithm: w2_st_i.fia,
Area: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area: 0x00010000-0x007FFFFF Erased, Time: 01:56
Area: 0x02000000-0x027FFFFF Erased, Time: 01:56
Area: 0x04000000-0x047FFFFF Erased, Time: 01:57
Area: 0x06000000-0x067FFFFF Erased, Time: 02:08
Write Error: Unk Hdr
Process Failed, Repowering Mobile
Can some one pls Tell Me wat to do..
Old 07-17-2004, 14:37   #2 (permalink)
Member: 26983
Thanks Meter: 11
I have the same problem have solve it?
Old 07-17-2004, 16:08   #3 (permalink)
Member: 9870
try reinstal the fia packeage then use lastes prog 1.3
it will fix it
Old 07-17-2004, 16:36   #4 (permalink)
Member: 26983
Thanks Meter: 11
can you send me the soft please?
Old 07-18-2004, 14:28   #5 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Thanks Meter: 1,097
Disable BT flashing...
Someone already said this somewhere
Old 07-19-2004, 05:41   #6 (permalink)
ANUCHOPRA's Avatar
Member: 73815
Thanks Meter: 4
hi acomtech,
there r only 2 possibilities 4 ur problem
1. if ur using uf2 or ufs3 below 1.3a then u need an upgrade from ur reseller
2. if ur using 1.3a then try to reinstall the setup.
mine was the same problem &was solved by upgradation
NSS 1.0.37.2 error flash 6600 genocite Federal One 6 09-12-2006 18:22
6600 flashing error now 6600 dead kabeermaster25 Nokia Hardware & Hardware Repair 25 04-08-2006 02:31
Error flashing 6600 pazeth™ Nokia Hardware & Hardware Repair 6 08-05-2005 19:28
"BDBDADAD" GRIFFIN ERROR FLASHING NOKIA 6600 rovick Nokia Multimedia 2 10-18-2004 09:36
Page generated in 0.21419 seconds with 9 queries
