Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 08-19-2003, 17:45   #1 (permalink)
Mobile Lab's Avatar
Member: 17651
Sonork: 100.81230
Thanks Meter: 318
nokia 3650 Memory card password
when i try to reach my 3650 memory card in menu option its asking about pasword.?
how to remove that ..?
Thanks n Regards
Old 09-11-2003, 10:22   #2 (permalink)
Member: 38210
Select the memorycard-icon on your phone. It will then display cardname, capacity and so on. push "select"-button and select password. From here you can enter password. Use blank for no password.
Old 09-11-2003, 22:29   #3 (permalink)
kingofhearts's Avatar
Member: 8710
Sonork: 1576303
Thanks Meter: 197
Hey format your MMC card in 9210 instead of 3650. It will lost all the data. Try and post the results. I've got this solution for password locked memory cards.
Cheers!
Old 09-13-2003, 13:52   #4 (permalink)
M@TRIX's Avatar
Member: 17865
Sonork: 100.73724
Thanks Meter: 266
for this tim no format the mmc must aske the pass
so no way for this time
Old 09-14-2003, 09:50   #5 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 115
i also had this problem....but simply restarting the phone helped me.....
WBR
Syed
Old 10-25-2003, 07:18   #6 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
i have 3650 with memory card locked
how to format ?
Old 12-27-2003, 07:18   #7 (permalink)
Member: 47525
i bought my 3650 3 mos ago and it went memory full. It hanged and i brought it for repair in nokia-care. (They say that 3 flash ICs are damaged) After paying Php3000 (USD54), it was ok again. But the problem now is that my MMC is locked for some reasons. I am sure that i did not put any passcode on it when my 3650 is still ok.
Is my MMC damaged?
Can i still use it?
MMC readers cannot eventually read it.
Will formatting it in other device (say N9210) can do any good?
HELP!!
Old 01-05-2004, 12:57   #8 (permalink)
Egypt Unlocker's Avatar
Member: 7093
untill now the security of memory card - didn't solve
SO you just wait a little may be ...
Old 05-03-2004, 18:55   #9 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 487
Any Solution for memory Card locked
Still no Satisfying result in this thread ???
Old 05-03-2004, 20:03   #10 (permalink)
Member: 49032
use '' infinity usb phoenix '' device to read ,erase sec-codes.
ordinary MMC reader writer device doesnot formate,unlock,even read locked
mmc.
Old 05-04-2004, 02:03   #11 (permalink)
balal_boss's Avatar
Member: 61743
Thanks Meter: 11
Talking
use 9210i and format memory card no your memory card and after you see ok or cancel now chaneg memory card ant got on your memory card and ok format this is bthe best Solution really .
Old 05-04-2004, 02:05   #12 (permalink)
balal_boss's Avatar
Member: 61743
Thanks Meter: 11
Talking
use 9210i and format memory card no your memory card and after you see ok or cancel now chaneg memory card and got on your memory card and ok format this is the best Solution really .
Old 03-10-2006, 03:41   #13 (permalink)
Member: 82538
use JAF and MMC CABLE and jast make format mmc,
will be done!!!
Old 03-10-2006, 05:45   #14 (permalink)
bingo_888's Avatar
Member: 234955
Thanks Meter: 19
will be done!!!
hey snick this post is almost 2 years ago
Old 03-10-2006, 12:03   #15 (permalink)
Member: 183390
Thanks Meter: 73
Is my MMC damaged?
Can i still use it?
HELP!!
No is in the software ver . there puting in the phone basically . Because I already encountered that problem . Probably the ver of your fone and the ver. of the software there putting in your fone are different . jjthats why your having . memory password lock. thry to flash your fone with lower the ver. im sure it will work out just fine.
Nokia N82 _ micro sd card memory card password remover amit_varietymob Nokia Base Band 5 ( BB-5 ) 12 10-25-2008 03:48
Memory Card Password Sollution Found stanner_austin Nokia Multimedia 76 08-29-2006 04:50
nokia 3650 memory card souri4life Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-18-2005 11:40
3650 Memory Card 70svn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-07-2003 12:57
3650 Memory Card locked, please help me! hoang WD2 & APE (Symbian Phones) 11 11-12-2003 22:09
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17976 seconds with 8 queries
