Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 12-24-2005, 13:11   #1 (permalink)
nofear197979's Avatar
Member: 68311
Thanks Meter: 34
very big problem with 7610
i have 7610 it shows only nokia logo i have maked full eares and changed everything eccept the lcd like cpu, 2flash, uem ect...
so plz wgat is the solution?
Old 02-08-2006, 13:18   #2 (permalink)
Member: 68311
Thanks Meter: 34
do any 1 have solution for this?????????
Old 02-08-2006, 19:18   #3 (permalink)
Member: 230251
1 try to update with latest version
2 write good PM
3 unlock
I solved 2 7610 with this solution
br
Old 02-11-2006, 08:02   #4 (permalink)
Member: 68311
Thanks Meter: 34
can u upload a good pm for it , plz???
Old 02-15-2006, 10:53   #5 (permalink)
Member: 68311
Thanks Meter: 34
plzzz i need the solution i have 7 phones the same problim????????
Old 02-15-2006, 16:25   #6 (permalink)
Member: 233264
try this one, 6670 full erase then format after, full flash using ur updated version, if not working that would be hardware, ram ic or power regulator near ringer ic. good luck
Old 02-16-2006, 12:40   #7 (permalink)
Member: 68311
Thanks Meter: 34
sir this not working
Old 02-17-2006, 03:57   #8 (permalink)
Member: 180155
i dont know how to solute this,but i am so sorry to hear this.
Old 02-17-2006, 16:01   #9 (permalink)
Member: 68311
Thanks Meter: 34
dont worry sir and thank you sir
Old 02-18-2006, 05:04   #10 (permalink)
Member: 58375
Thanks Meter: 12
flash with latest version , full pm , unlock, then format user area , hope fone ll b OK
Old 02-21-2006, 19:18   #11 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
there are 3 100% way to repair "only NOKIA logo" problem for both 7610 and 6670:
-1-
- Full erase (also eprom and user area)
- flash with newest firmware
- upload good pm
- unlock and format user area
if problem still same then second way
-2-
- check or change N130 (especially when water demaged)
- if still same, do all -1- options after change N130
if problem still same then go third way
-3-
- make pm backup from 0 to 255 and save
- change flash chips by order bank1 and bank2
- flash phone with last firmware
- create RPL with the soft PM to RPL by invisible( thanks to invisible, http://invisible1.da.ru)
- upload RPL and calculate flash IMEI
that's all. good like!
File Type: rar 7610_full_erase.rar (742 Bytes, 586 views)
The Following User Says Thank You to KUBAT1 For This Useful Post:
Old 02-22-2006, 08:13   #12 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
i will try but maybe ram problem
Old 02-25-2006, 10:25   #13 (permalink)
Member: 15539
Thanks Meter: 100
hai
try to change N130
Old 02-27-2006, 22:30   #14 (permalink)
Member: 68311
Thanks Meter: 34
-1-
- upload good pm
-2-
-3-
thanks for ur help i will try it sir
Old 03-10-2006, 23:19   #15 (permalink)
Member: 164505
Thanks Meter: 16
hi
pleas where i can fiend create RPL with the soft PM to RPL by invisible and how i can use it
thankes
very interesting problem with 7610 keypad! KUBAT1 Nokia Hardware & Hardware Repair 2 11-01-2006 11:19
I have VERY VERY realy VERY BIG!!!! problem with signal Lipper NEC 7 06-29-2006 21:43
Motola MPX200 very big Problem with unlock CODE winiu Motorola ODM 6 02-02-2006 18:44
Julvir... very very big problem with C4-2 Spalato Redbox 1 12-30-2005 00:31
HELP!Very big problem with network on S300 - SOFT or HARDWARE?????? bolt_gsm Trident/AGERE Platform 1 09-07-2003 07:48
Page generated in 0.27258 seconds with 10 queries
