Main Sales Section This is the Main Sales Advertisement Section, Used By Dealers |
11-13-2004, 22:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | -= ONLY 59 EUR for eXtreme USB BOX - STOCK AVAILABLE =- IF YOU ARE A USER DIFFRENT BOX THAT UNIVERSAL V2.0, V3.0, ULTRALOGIC YOU CAN BUY SAMLL CONVERTER COST ONLY 1,50 EUR AND USE EXTREME WITH YOUR EXISTING CABLES FROM USPIU, REDBOX, UDK, UNIVERSAL BOX V1.07, China USB Box or BLUEBOX SO OVERALLY CHINA STANDARD CABLES ACT AS A ORIGINAL VYGIS USB-RS232 BOX IN ONE OF SWITCH POSITION ACT AS A ORIGINAL S2GSM USB CABLE IN ONE OF SWITCH POSITION ACT AS A HIGH SPEED UNIVERSAL BOX WITH TRANSMIT RATE UP TO 1 MBIT/S ONE OF SWITCH POSITION General information: - advanced hardware working on USB port in v1.1 standard allows to transfer data up to 921000 kb/s (~1Mbit/s !) - work without any problems under all operatign systems as Win95/98/Me/2000/Xp - work with full speed 460800 kb/s at such phones as Alcatel, Mitsubishi, Siemens, LG using S2GSM or Vygis softwares on all PC’s - abbility to flash Siemens with cutted tracks using normal SWUP’s due build in AutoIgnition mode at full speed up to 1 Mbit/s ! - easy change mode of S2GSM/Vygis/Normal by 3 position switch on back cover of device - Box connect to PC using 1 USB cable – no need to have LPT, COM, power supply so it’s totally movable between your area - to one computer you may connect up to 127 eXtreme Box – you can flash up to 127 phones at once !! - profesionally maked PCB in fabric with ISO9001 with full electrical tests - possible to change mode to work from 3V to 5V logic – by this device will work as MAX3232 3V standards or MAX232 5V standard. This is needed for most newest phones such as OT756 How it works in practic: Box works as a virtual port using Windows API – when you connect device for first time to your PC it will first recognise USB HUB and install it automatically. Since drivers for HUB controller are build into Windows shell then it will not request any drivers from you. After this will be finished your system will find device called S2GSM cable or Vygis Box or eXtreme. The type of device that it will recognise first depends on position of switch that are on back cover of hardware. If it’s set to S2GSm first found device will be S2GSM cable, if it’s set to Vygis first device will be Vygis, if to Normal first found device will be eXtreme Box. Driver are installed only once so we suggest to switch to all position at first runing to install all drivers – in future system will not request any drivers and load them automatically when it will only found proper device. After this your equipment are ready to work – in complete you will find small software that enable to change association for COM ports. Now just chosen software and you can start servicing phones. NOTE: Some phones such as newest OT756 requires 3V logic so you need to change switch to 3V Technical data: - transfer up to 921000 kb/s via USB port (~1Mbit/s) - build using chips FTDI FT232BM + USB HUB Alc. Mic. 925 - easy logic voltage change mode from 3V to 5V by just moving a dip switch - easy change mode of working type device by three position dip switch - S2GSM, VYGIS, NORMAL - LED’s of PWR (USB power supply), Rx (data from phone), Tx (data to phone), 5V (LED that gives information that 5V are powered on so device works in 5V logic state) - build on USB HUSB using Alc. MIC. AU925 chipset - max. Power take by Box (USB standards) - 500 mA - working on all cables from Universal Box v2.0, v3.0 or UltraLOGIC and buy buying additional converter also with China standard cables that fit to UDK, USPIU etc. - aluminium casing Advantages over other products: - don’t need to buy other USB devices with full complete set of cables if you already got Universal Box v2.0, v3.0 or UltraLOGIC – all cables from these Box will fits to this unit. If you got USP, UDK, China BOX with Tele-way standard pinout you may buy small converter for 1,5 EUR to support all cables of their by this BOX - full mobility – don’t need external power supply - full hardware support for S2GSM and Vygis hardware like also normal softwares - free support THIS GREAT EQUIPMENT COST ONLY 59 EUR - VISIT RESSELERS ON HTTP://EXTREMEUSBOX.COM FOR BUYING THIS ITEM RIGHT AWAY Package contains: * eXtreme USB Box * drivers on CD (Extreme/S2GSM/Vygis) * instruction in EN/PL on CD * software for association of COM port on CD * warranty card WE ARE LOOKING FOR WORLDWIDE RESSELERS - MORE ON HTTP://eXtremeUSBox.com PRICE ??? VERY, VERY LOW - ask at [email protected] |
Best Best Price !!! UST PRO 2 & USB SMART STOCK Avail UK and Pakistan !!! | TaHiR | Main Sales Section | 0 | 12-25-2005 22:32 |
New USB-Smart Stocks Available!!! | blutac | Main Sales Section | 0 | 09-24-2005 16:31 |
Crazzy NEC Unlocker, eXtreme USB Box, Smart-CLIP, Griffin, Tiwsters | Multi-COM | Main Sales Section | 0 | 12-10-2004 14:55 |
HOT: eXtreme USB Box...soon available for sell ! | Multi-COM | Unibox | 7 | 11-29-2004 16:23 |
