Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
08-26-2004, 13:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | After removal of glued UEM and glued uem removal video guide It happens to many of us when we remove the UEM. It takes a lot of effort you might have some tracks with no green lacqour ( specially on the light green boards ) What i made, is coating the board with a blue marker, and dry it with cold air (fan). When its dry, we have a small problem ! How do I fit the new or old reballed UEM without using flux ? I have solved it using the following method : 1 : For new uem A : Put some flux at the UEM IC balls and heat it with mid heat and the nozzel around 2 inches from the IC B : Clean the IC and the balls untill all balls are bright and shining C : Fit the UEM in place and use mid heat and mid air, but here you'll have to use longer time than usual, around 3 to 4 min Now your done ! 2 : For reballing the same UEM it's alot easier since theres still some solder left on the pads. Clean it up and fit the same way as above. N.B The success of this proccess depends on fitting the UEM exactly in it's place BR **Edited and proffread where nessesary for sticky** Last edited by GSM Coolhawk; 08-27-2004 at 11:23. |
The Following 28 Users Say Thank You to Raheeeeb For This Useful Post: |
08-26-2004, 23:30 | #4 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | @mia2 thank you a lot i hope it help any whom need it @king its nothing like your experince in samsung problems |
The Following User Says Thank You to Raheeeeb For This Useful Post: |
08-27-2004, 12:37 | #7 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | @ gsm coolhawk thanks a lot and more i ll post @visualtech i hope its help and another trick ll post soon |
09-03-2004, 19:05 | #12 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | @keany this comment from profissonal man with bright future in hardware @infinty thank you a lot i hope its help and more photo about lost trace ll b implemented @DineshDias thank you i hope i can help more @mafiaaa sure i remmber you but your a man many people looking for have your name but you to nick name from others .. this need to explain (mobile maafia belong to wael omar) sorry but i have to reply whom say good word for me i hope i don't break the forum roles |
09-04-2004, 20:18 | #14 (permalink) |
Freak Poster Join Date: May 2004
Member: 64341 Status: Offline Thanks Meter: 1 | ok. thanks raheeeeb. for us novis, on what instances do we need to change uem other than dct4 imei curruption? what are the risk and are there any other operations necessary to be carried out after changing the uem? |
09-05-2004, 16:51 | #15 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | @OKOKO reason to remove uem 1- water damage uem 2- burnt due to high voltage from the charger 3- 30 seconds autoshut off after repair the imie by griffin log 4- unable to flash the phone due the tx singnal high from phone to flasher i think in most of these you have to change it .. br.. |
The Following 4 Users Say Thank You to Raheeeeb For This Useful Post: |
..::i need video guide how to remove glued chip like omap, rap3g, combo flash,uem::.. | HUM | Nokia Hardware & Hardware Repair | 30 | 01-03-2010 18:33 |
Tutorial of Remove Glued rap and flash chip by Jovy RE 7500 | Raheeeeb | RE-7500 Reworking System & iSolder | 39 | 02-26-2009 11:33 |
removal of glued ics | akfrm | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 03-20-2005 17:29 |
