Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
07-18-2005, 07:39 | #182 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | clean the keypad attchment or flux the ic near to conn or remove the keypad sticker and wash with cleaner best if ipa |
07-21-2005, 08:41 | #187 (permalink) |
Freak Poster Join Date: May 2004 Age: 58
Member: 65419 Status: Offline Thanks Meter: 4 | 7260 earpiece not working hello and good day to all.... i have a nokia 7260 which is dropped and earpeice is not working. most probably there is a cut on the lines.i dont have a schematic diagram for this unit and anyone who have please share it..... any possible connection which i can put a jumper in order to work this out? the headset is working and also tried to change the earpice but no luck... thanks/brgds meneleo |
07-21-2005, 10:07 | #188 (permalink) |
Insane Poster Join Date: Jul 2003 Location: india Age: 51
Member: 33445 Status: Offline Thanks Meter: 18 | 3200 key pad hang & switch off after 60 sec please give the solution for nokia 3200 , when i switched it on after few sec key pad hangs & approx after 60 sec it turns off ??? |
07-22-2005, 20:13 | #191 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 55
Member: 127428 Status: Offline Thanks Meter: 51 | 3310 power switch problem pls. kindly help, i have nokia 3310 that have power switch problem, [the two lower contact of the power switch in the mother board, i e the panel screp off but the upper ones is still]. pls. with the help of diagram with pictures, how and where will i run wire so that the phone will power up normaly through the power switch again?. |
07-23-2005, 11:39 | #193 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: www.sevgigsm.net Erkan Yasar Age: 61
Member: 81576 Status: Offline Thanks Meter: 2,128 | Quote:
3310 power sivicth ways searc | |
07-25-2005, 10:54 | #195 (permalink) |
Freak Poster Join Date: Jul 2005 Location: cebu Age: 43
Member: 164237 Status: Offline Thanks Meter: 12 | ive got problem with my 6230 here. it does charge but it it wont power. i suspect that it does have a broken trace along the power switch to the UPP. can somebody help me with it. its better if somebody is kind enough to show it in pictures. tnx |
all nokia hardware solution | Harkishan singh | Nokia Hardware & Hardware Repair | 4 | 04-23-2010 12:53 |
All Nokia Hardware Solution In One Player | morshed | Nokia Hardware & Hardware Repair | 0 | 06-17-2008 17:37 |
All nokia Hardware Solution | najafi | Nokia Hardware & Hardware Repair | 9 | 04-25-2007 06:30 |
all nokia hardware solution with pictures | sainianil | Nokia Hardware & Hardware Repair | 16 | 12-09-2006 12:35 |
