Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
11-22-2010, 07:06 | #3887 (permalink) |
No Life Poster Join Date: Jul 2009 Location: .::Gsm::.
Member: 1081011 Status: Offline Sonork: 100.1594100 Thanks Meter: 463 | 6120c camera .::General Feature Not Supported::. Change Camera............... But Always Show .::General Feature Not Supported::. Always change camera ic |
11-22-2010, 12:42 | #3888 (permalink) |
Insane Poster Join Date: Aug 2007 Location: KSA
Member: 561026 Status: Offline Thanks Meter: 3 | e66 flashing with hwk this error anybody can answer 1ST BOOT : C0,07 [Rm-343] [2.1.0.1] RAPx ID : 000000010000022600010006400C192101051103 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 0E200014802900529196E3A414E06601C1764E25 RAPx MODE : 00 RAPx HASH : 479C6DDE3942E12C429C1D6ADED80371 RAPx ROID : 4B9B75103E691FF8 CMT 1ST Boot OK Boot not Found: ASIC not Supported CMT 2ND Bt: ASIC not Supported BAD BOOT ERR: CMT 2ND Boot Rebooting Mobile BB5 Loaders Path: C:\Program Files\Nokia\Phoenix\Flash\ RAP ASIC Second Loaders: RAPGSMv10_2nd.fg Version: 1.12.0 Size: 31769 RAP3Gv2_2nd.fg Version: 1.21.0 Size: 48542 RAP3Gv3_2nd.fg Version: 9.11.1 Size: 74005 RAP3Gv4_2nd.fg Version: 1.42.0 Size: 60624 RAP ASIC Flash Loaders: RAP3Gv3_algo.fg Version: 9.17.0 Size: 345031 RAP3Gv3_algo_fps8.fg Version: 1.12.5 Size: 117364 RAP3Gv3_algo_nand.fg Version: 1.12.5 Size: 190436 RAP3Gv3_algo_xsr15.fg Version: 1.40.0 Size: 354943 RAP3Gv3_algo_v1331.fg Version: 1.33.1 Size: 342783 RAP3Gv4_algo_xsr16.fg Version: 1.42.0 Size: 378414 RAPIDO ASIC Second Loaders: RAPIDOv100_2nd.fg Version: 1.15.9 Size: 43391 RAPIDOv102_2nd.fg Version: 1.24.0 Size: 47806 RAPIDOv11_2nd.fg Version: 1.37.1 Size: 58270 RAPIDO ASIC Flash Loaders: RAPIDOv1_algo.fg Version: 1.16.3 Size: 281164 RAPIDOv11_algo.fg Version: 1.40.0 Size: 356247 RAPU ASIC Second Loaders: RAPUv11_2nd.fg Version: 1.37.1 Size: 58014 RAPU ASIC Flash Loaders: RAPUv11_algo_xsr16.fg Version: 1.40.0 Size: 388247 HELEN ASIC Second Loaders: helen3_2nd.fg Version: 1.35.0 Size: 33427 HELEN ASIC Flash Loaders: h3_sam_nand_gbbm.fg Version: 1.33.0 Size: 70587 h3_sam_nand_xsr.fg Version: 1.49.0 Size: 192377 h3_sam_nand_xsr_small.fg Version: 1.35.0 Size: 88290 h3_xsr15_flash_alg.fg Version: 1.49.0 Size: 204441 OMAP ASIC Second Loaders: omap2420_2nd.fg Version: 1.12.0 Size: 20278 omap2420_m1_2nd.fg Version: 1.41.0 Size: 59487 OMAP ASIC Flash Loaders: teflon_sam_nand_xsr_m1.fg Version: 1.47.0 Size: 300110 teflon_sam_nand_xsr151_m1.fg Version: 1.57.0 Size: 324894 NOMADIK ASIC Second Loaders: nomadik8815_2nd.fg Version: 1.43.0 Size: 72039 nomadik8815A1_2nd.fg Version: 1.32.0 Size: 36735 NOMADIK ASIC Flash Loaders: nomadik8815_alg.fg Version: 1.57.0 Size: 362040 nomadik8815_A1.fg Version: 1.42.0 Size: 209215 |
11-24-2010, 09:30 | #3889 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006
Member: 276537 Status: Offline Thanks Meter: 31 | hi all, i have a nokia N95 RM-159.that phone have a problem of auto restart.regarding that problem already i have modified something here.here in below that pictures are there which i have modified.so please someone give me other solution if there is some other solution exesist. so please help..thanks ranjieet karmackar |
11-27-2010, 06:24 | #3890 (permalink) |
Junior Member Join Date: Apr 2008
Member: 758684 Status: Offline Thanks Meter: 1 | plz help me nokia 5130c-2 1ST BOOT : C0,07 [Rm-495] [2.1.0.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 21C00104ECB77D561AED5C79A079083D13F66941 RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : 0C917F11196FDB7378C18EF7260698CA4489DCA0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : C5F02102_rm495__07.97.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00040000-000BFFFF CMT NOR Erase Area: 0x000C0000-0013FFFF CMT NOR Erase Area: 0x00140000-0137FFFF CMT NOR Erase Area: 0x01380000-0151FFFF CMT FLASH ERASE OK, Time: 00:10 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x013BC400, 03 ERR: CMT FLASH WRITE D_BLK C7012D0103CD000010000000F172, LN: 0x004000, Time: 00:13 Process Failed, Repowering Mobile [email protected] |
11-29-2010, 18:24 | #3892 (permalink) |
Junior Member Join Date: Dec 2006
Member: 411332 Status: Offline Thanks Meter: 0 | So here's the problem: I have a Nokia E61i and and I can't ear nothing unless I'm at home or in a place completely silent!! I sent it to Nokia and they said it was oxidized and they wouldn't repair it. -.-' I suppose that that is the earpiece because the speaker works perfectly...I searched on the web and I found more people with the same problem: NOKIA E61i LOW VOLUME FIX/ HACK I downloaded the Service Manual and I found what I needed to change the earpiece but there's something I can't understand. They say if I change the earpiece I have to change the LCD Shield Assy too. Do I really have to change it? Because I can't find it on ebay -.-' So do you think the problem comes from the earpiece or is something else? |
12-01-2010, 02:19 | #3893 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1454753 Status: Offline Thanks Meter: 0 | As i am on mobile cant search forun proply and i need solution urgently.. lets come to topic... my n95 had big network problem. it manually searches all networks available but shows NO ACCESS when we select network. for that resion i had changed PF IC. after that it was working fine for 2-3 days and then after same problem persists.. i had changed PF Ic 3 times and every time same problem. so frendz please give me solution of that problem and please dont use much technicl words as i hv very less technical knowledge.... experts plz plz give me permanent solution for that... |
12-01-2010, 14:21 | #3894 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | 6680 battery discharge rapidly with in three hour battery sleeps no short on mkey bt_wakeup fail when switch on the set current draw by the circuit with lcd is 150mA only charging not stopped to show battery full after charger on desktop battery again takes only three to four hour to discharge some authenticated suggessions required thanks thanks to you all by gsmzaman |
12-02-2010, 11:37 | #3895 (permalink) |
Freak Poster Join Date: Aug 2009 Location: nobody is perfect and i'm 1
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | urgent please i have nokia 5800 xpressmusic..everything is correctly working the only problem is when u make a call the screen goes off whiles the call is on,onless u press a key .the same thin happens when call comes.please help |
12-02-2010, 19:11 | #3897 (permalink) | |
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | Quote:
no answer within one hour uptill now i have solve the problem full flash the phone formate with box c,d,and z drive of phone formate with * 3 send and power button thanks to you all by gsmzaman | |
12-03-2010, 10:31 | #3898 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 49
Member: 79152 Status: Offline Thanks Meter: 9 | 5800 charging problem hi can help me with nokia 5800 charging problem? when phone is turn off, when plug in the charger, the phone lights up and come out "nokia" but the battery indicator on the top right isnt moving up and down. When then phone is turn on, plug in the charger, it did not come out any charging message, nothing, the indicator didnt move too. do u have solution for this? thanks in advance =) PS: i flashed with newest version 52.0.007 |
..::Get ALL SonyEriccson Problems I Solved In Only 1 hours::.. | 786786 | Sony Ericsson Hardware Repair | 2480 | 05-02-2020 14:46 |
.....::::: Get Me Ur Problem I Solved In Only 6 Hours::::.... | 786786 | Motorola Hardware Repair | 315 | 06-08-2013 17:55 |
..::Get ALL DCT4 Problems I Solved In Only 1 hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 5 | 11-26-2010 18:12 |
post all bb5 problems in here | GSM SHADOW | Nokia Base Band 5 ( BB-5 ) | 454 | 04-26-2010 09:25 |
ALL BB5 phones SIM FREE In Poland form 2009 SOON others nets in World | maniek27 | Nokia Base Band 5 ( BB-5 ) | 16 | 01-31-2009 13:44 |
