Could anyone calculate code for me please Nokia 6630 IMEI 354349009725402 T mobile:confused: |
culd you unlock my movil is a 6630 |
could you unlock my fhone is a 6630 |
6600 no network found hi i have got 6600 for bluetooth error i removed the bluetooth module,but know it shows no network found. changed antenna switch , reheated mojoiner ic .pls help. |
7600 on/off switch DESTROYED the two left PIN has been detached from the PCB what is the modification? |
6600 white DISPLAY and freeze and stay on the wite DISPLAY.... with backlight keep ON |
so u have to replace it, as it's an rf module, i think that it's related to network too. |
Hi Tajinder.. First of all resolder a new BT Module..and chk if network is ok but if problem persists..then u must have damaged ur UEM by over heating..cause its on the other side of the PCB.. Try Adampur Hawks |
Just format with UFS or with JAF If still not ok.. Flash with the higher version.. Adampur Hawks |
Hi Mate There is no solution for unlocking 6630,6680, & 6681. Wait for some time cause we are also waiting for it for two years.. Adampur Hawks |
I have a Nokia 1100 with a mic that doesn't work. This is the second one....how to fix? |
disable bt flash and then flash it |
there is a track from left top 2nd no. pin make a jumper to antena switch problem 100% solved |
