hi HPDebug, May your phone has damaged "RAM". Try replacing it! |
Have u tried manualy formatting ur phone before changing ur flash IC. If yes then there must be a problem in ur RAM IC try to reball it or change it.. Try and post me ur reply Regards Adampur Hawks |
6230 with camera problem, the camera has no preview , when i take a shot, it save it normally, also the video preview is very very slow, i full erase the phone, flash it, full factory setting, write pm, all sw procedures but no help, i also change the screen, change the camera, still the same ... pls help |
hello sir. 6600 no opreter found after flash........plsss help me sir... |
try to resolder or heat the headset ic ...... good luck....... |
adampurhawks i have 7610 cannot on.. meansure with power supply 0v, pls show me the right way to solve it step by step( where should i check 1st ). thx |
N 70 Water Damage Hiiiii, I hv Nokia N70 ..Its water damage ...i cleaned the board ...its working now but its getting hot ....& no bettary Backup ....Pls send me the solution:( |
6600 gallery not opening i do the the format flash with ufs but not ok it is hrdware problem |
can u tell how can v install or format our phone and install SymbianOS in to our nokia mobile phones?? and wat is this JAF and UFS and wat is meant by "Flash with higher version"???? plzz reply me |
i have here 3650, init normal mode ok. no power on battery. am using twister and jaf. i'dd also check board for missing parts . does anyone encountered the same problem and has a solution. |
i writed already but same condition.plsss help me |
i have N70 and if i chose the edit image it says "Not enough memory to perform operation. Delete some data first." I have a 256Mb dv rs mmc and a newly updated firmware to 5.0616.2.0.3 24-4-06 RM-84. pls help me |
3220 , was signal problem. i rehot all board components , signal back for few days , phone back with no signal , i rehot board again , phone is not power on . flashed with newest flash np , phone power on with jaf , but not with battery. power switch is good . ideas ? 3220 power ways ? |
